What motor is this
Discussion in '1st Gen. Tacomas (1995-2004)' started by yellowdog5, Feb 8, 2018.
  1. Feb 13, 2018 at 7:19 AM
    #41
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Here is a tip: TTORA site used to have FSM for some models on their site ( ), till they had to remove them for legal reasons. But once some stuff goes on the Internet, it will stay forever (this is a true warning for some young trolls). If you look way back into 2008 (http://archive.org/web/) you might find some stuff from the past :alien:
  2. Feb 13, 2018 at 10:19 AM
    #42
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '07 Black TRD OR xtracab 4.0L 4WD
    Pretty much stock right now
    P0300 - Random/multiple misfire. I'll attach the diagnostic for this code. It's pretty involved.
    If you have serious misfires, or your check engine light is flashing at any time, it's best not to drive the truck. Depending on your mileage, you may need coils pacs. All of mine went between 150-160K. It's not uncommon. It would fit with the age of your 2002 also.
  3. Feb 13, 2018 at 10:24 AM
    #43
    ghs57
    Chops
    Catskill Mts. NY
    If they turn out to be the problem, it's recommended to use Denso coils. They are the OEM part, and you can get them from places like Rockauto for around $100 each. Unfortunately, you need 4.
  4. Feb 13, 2018 at 11:24 AM
    #44
    yellowdog5
    yellowdog5 [OP] Well-Known Member
    2002 Tacoma SR5 4wd 2.7L
    Ok, I haven't driven it much, the light did flash once when I came up the steep side of our driveway in second gear, haven't done that since, just used it a couple of times to move hay around the place. I'm getting the plugs today and I'll try to figure out how to check the coils. Mileage is about 120k. I have ordered from Rock Auto before, they're great. Thanks.
  5. Feb 13, 2018 at 11:58 AM
    #45
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    There you go. The proper response.
    Running Board Man likes this.
  6. Feb 13, 2018 at 10:10 PM
    #46
    ectrd
    ectrd Well-Known Member
    '04DC
    4 tires, a steering wheel & a seat
    Some of the same kind of shit I'd see on TTORA... Only TTORA is worse...
  7. Feb 14, 2018 at 12:02 AM
    #47
    ghs57
    Chops
    Catskill Mts. NY
    Misfires can be worse when the engine is under a load, such as a hill, or when the rpms are high. The coil post can crack which allows the high energy spark to arc to the engine instead of the spark plug. Or the coil can just fail internally. They are firing thousands of times a minute, so age and mileage take a toll.
    They are easy to remove. 10mm bolt. Just unplug and pull out. They can be changed in minutes, except for those under the intake ducting.
    Let us know how it turns out.
  8. Feb 15, 2018 at 5:28 PM
    #48
    yellowdog5
    It has around 120k, I took the coils out today, one is cracked, and another has a lot of "soot" (like inside a bad distributor cap), I'm taking them to a shop to have them tested in the morning, hope I don't have to replace them all.
  9. Feb 15, 2018 at 6:41 PM
    #49
    ghs57
    Chops
    Catskill Mts. NY
    Glad you found something suspiscous. I have a cracked one that is fixed up with dielectric grease and a winding of electrical tape around the post that I keep for my spare. It works fine, but I hope to never need it.
    Good luck with the testing.
  10. Feb 16, 2018 at 5:46 AM
    #50
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    BTW...you can see the name of it on the block. It is on the side of the power steering pump and you can see through the driver side wheel well at the bottom where the oil pan meets it will be cast "3RZ".
    It won't be painted like this as it is all black, however, that is the location there.
  11. Feb 16, 2018 at 6:51 AM
    #51
    yellowdog5
  12. Feb 16, 2018 at 6:56 AM
    #52
    yellowdog5
    Found out my local (in the next town anyway) Autozone can get the Denso coils for $59.95, less than anything I've seen online
  13. Feb 16, 2018 at 7:26 AM
    #53
    ghs57
    Chops
    Catskill Mts. NY
    That's a very good price. Never have seen them that low.
  14. Feb 16, 2018 at 12:37 PM
    #54
    yellowdog5
    Ok I changed the plugs and replaced a couple of bad coils, I want to replace the pcv valve but can't find where it goes? here's the photo again plus a couple more005 (Medium).jpg 004 (Medium).jpg 001 (Medium).jpg 005 (Medium).jpg 004 (Medium).jpg 001 (Medium).jpg
  15. Feb 16, 2018 at 12:56 PM
    #55
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I believe its at the end of that fat hose in the middle of the last photo.
    Remove the hose at the valve cover end.
  16. Feb 16, 2018 at 1:18 PM
    #56
    RysiuM
    Rysiu
  17. Feb 16, 2018 at 3:58 PM
    #57
    yellowdog5
    Thanks I think you're right, but if I have to remove the whole valve cover to change it how badly does it need to be done? Here's a a photo with the hose off. Another question, the mechanic that checked the resistance on my coils showed me how, so when I got home I compared the old coils to the new ones, old read 2.00, new ones 2.26. So I have 2 of each, it's running great, is the discrepancy a problem?001 (Medium).jpg
  18. Feb 16, 2018 at 4:36 PM
    #58
    RysiuM
    Rysiu
    This is different from my 95. In 95 the PCV is pushed into grommet. Looks like in the newer engines it is screwed into valve cover. Here is the picture from 2003 FSM
    But yours looks different from both. Or maybe it is a push type.
    Regarding coils, FSM does not specify the resistance of them. My guess is it depends on version (manufacturer year)
  19. Feb 16, 2018 at 5:43 PM
    #59
    tan4x4
    Rick
    Folsom, CA
    Does the top of the new PCV valve look like that? That just looks like a fitting.
    What do you see if you remove the other end of the hose?
  20. Feb 16, 2018 at 6:32 PM
    #60
    yellowdog5
    The top of the new valve looks about the same, maybe a little shorter. Just looks like a regular PCV valve. The other end of the hose is bigger, I can look at it tomorrow when it gets light.
