What MPG are you getting with larger tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crzyrdr52, Dec 23, 2007.
  1. Dec 23, 2007 at 11:16 AM
    crzyrdr52
    crzyrdr52 [OP] Member
    Herb
    NorCal
    08 Prerunner V6 TRD Sport
    Bilstein 5100's set at 2.5", 2" AAL, Black Moto Metal 957 wrapped in 285/70/17 Firestone Destination A/T, Grillcraft, debadged, K&N drop in, yellow Lamin-X
    I was thinking of getting the 3" Toytec lift and installing larger tires. What kind of gas mileage are you guys getting with larger tires. With a 3" lift what is the largest size you can run? Thanks
  2. Dec 23, 2007 at 11:31 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    w/ a 3" lift, i think the max is 33's...i've got a 2.5" lift and i'm gonna run 32's
  3. Dec 23, 2007 at 11:51 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Original equipment on my rig was 245/75/16, I went to 265/70/16 and lost 3 miles to the gallon, only larger tells me more loss, go to a off road tire and even more so, how much more ? :(
  4. Dec 23, 2007 at 12:34 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    i have the 3" toytec lift and 33's.... went down to about 16mpg on the free way running about 75mph.... not sure what city mpg is.
  5. Dec 23, 2007 at 1:00 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    You guys may need to regear to regain some MPG and power back.
  6. Dec 23, 2007 at 1:06 PM
    concrete jedi
    Rochester N.Y
    Details ?
  7. Dec 23, 2007 at 4:57 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I have a 3" lift and 285/75 16 tires. You DON'T lose mpg! :frusty: You need to compensate for the tire size difference when you calculate mpg off the odometer/trip odometer numbers. Or get a scangauge calibrated for the different sized tires.
    For example, my 285's (32.8") throw the speedometer and odometers off by 7%. So when the trip says I've driven 300 miles, it's actually 321 miles.
    With that said, I was getting 17-18 mpg stock. Odometer calculations with the 285's say 16-17mpg, but the scangauge (or altered calculations with odometer reading) still shows 17-18mpg.
    Edit:
    You may find this useful:
  8. Dec 23, 2007 at 5:38 PM
    concrete jedi
    Rochester N.Y
    Yeah... did that, still lost 3 mpg according to the math, dividing gallons of fuel into miles driven. :frusty:
  9. Dec 23, 2007 at 5:47 PM
    L_Jackson
    Houston, TX
    i did that too, i divided miles drove by gallons used, and it equaled exxon being blood sucking money hungry leaches... is that what ur calculator said? or is mine busted??
    all jokes aside, i forget what mpg i had to begin with.... i thought it was low 20s, but thinkin back on it, i don't think it was, 18 sounds familiar... but im not sure....
    i know my wife has a kia scerento, and i was dissapointed when i checked both of our mpg. i really though both would have been better. we love both, but mpg kinda sucks. (hers is about 18 or 20 i think)
  10. Dec 23, 2007 at 5:57 PM
    concrete jedi
    Rochester N.Y
    Considering where you reside, your house is probably bugged, I would look out the window for ninjas or a red laser dot around your heart. I agree with you about Exxonmobile !:laugh:
  11. Dec 23, 2007 at 5:59 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Well, theoretically they should be the same! :laugh: Larger tire means it has to rotate less than a smaller tire for the same distance traveled. As such the transmission will spin at a lower RPM to maintain the same speed so the speedometer will show a lower speed, and the odometer will record less miles.
    Only things I can think of is heavier tires, heavier wheels, or the tread pattern. I still have the stock wheels so the weight is the same. Not sure of the weight difference between stock and Kumhos I have now so the only difference would be the diameter and width. They aren't mudding tires so they don't have massive lugs to cause more drag or friction. They are wider so that might increase rolling friction, but that also means the distribute the truck's weight more and have apply less pressure to the road so..... :confused:
    I just know I get the same MPG with both tires. And with all things being equal you should too.... That's where the weights and more aggressive tread patterns can come into play.
  12. Dec 23, 2007 at 6:10 PM
    concrete jedi
    Rochester N.Y
    I think it's probably a little of what you said, I went from Dunlop baloney skins to BFG's baloney skins, DOH ! Also I did this right around the weather change, nice/warm to cold and damp, with that came winter fuel. I doubled my fuel milage from my last truck so it's all good for me, if I had a 2.7 liter I would probably break into song... and none of you want that ! :eek:
  13. Dec 23, 2007 at 6:31 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah, the winter mix may have more to do with it than anything. Seems like I read somewhere that you can plan on a 3mpg loss with winter mix. Keep an eye on it come spring/summer time.
    Also, if you idle the engine at ALL to warm up that's gonna cut into it. Plus the engine doesn't run at peak efficiency until it's warmed up and that's gonna take longer this time of year. Damn NY weather! Almost wish I'd stayed in SC. Certainly don't get any of the, uhhhh, "casual" female clothing up this way! :laugh:
  14. Dec 23, 2007 at 6:39 PM
    concrete jedi
    Rochester N.Y
    You said a mouth full ! I love a tight sweater but it aint no g-string !
  15. Dec 23, 2007 at 6:44 PM
    L_Jackson
    Houston, TX
    jedi your crazy! tight sweaters suck! they scratch my neck and are just over all uncomfortable.... and g-strigs make me feel like a sinner.... i say 10 hail marry's every time i wear one.
  16. Dec 23, 2007 at 7:16 PM
    concrete jedi
    Rochester N.Y
    L_Jackson, my wife thinks there is something really wrong with me, Im out here laughing my donkey off, for what appears to be for no reason, you are too funny. :laugh: :eek:
  17. Dec 23, 2007 at 7:37 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I did not need that mental image before bed... :laugh:
  18. Dec 23, 2007 at 7:39 PM
    concrete jedi
    Rochester N.Y
    What's your weather like ? I just got about three inches of snow in an hour then it stopped. :eek:
  19. Dec 23, 2007 at 7:43 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Been in the 50's and raining all day. Had some flood warnings most of the day too. heh Good day to stay inside and bond with the couch. :D
  20. Dec 23, 2007 at 7:45 PM
    concrete jedi
    Rochester N.Y
    No doubt
