What next?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trdman98, Jan 25, 2010.
  1. Jan 25, 2010 at 10:44 PM
    Trdman98
    Trdman98 [OP] Member
    98 tacoma 4x4 6"
    3" body, Toytec Coilovers, Dakars, Bilsteins, 33"BFGs, Intake, Exhaust
    So i'm currently driving a 98 3.4 with toytec ultimate lift with oem dakars and 5100s also have a 3in PA BL K&N CAI and gibsons SS catback sitting on 33x12.50 BFG AT 15x8 procomp steelies. Im wondering what are my possible lift options as i want to plan on running 37s. Im thinking of some kind of drop bracket and install a spacer on top of my coilovers. and the a block in the rear. I plan on adding some gears also. How would this setup look, any opinions, i live in virginia and the only wheelin i do is many during hunting season and hitting a yew mud holes[​IMG] Toytec lift with 3inch BL 33x12.50x15 15x8s
  2. Jan 26, 2010 at 12:30 AM
    1998tacoma4x4
    1998tacoma4x4 Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    Don't do a spacer lift, not strong enough for offroading at all. Also our trucks are not designed to perform with 37's unless they are heavily modified, in terms of axles and our trannys.
  3. Jan 26, 2010 at 5:59 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yes but i am sure he could get away with it with re-gearing. is that pic with only 3 inches of lift? that seems much taller? dont put blocks in the rear... from the looks of the pics you might be able to fit 37's in there maybe with a little body lift 9dont really the best way to go) and some trimming. if that really is only a 3 inch lift, then go to 6 inches and work from there.
    EDIT: just saw you have a 3 inch body lift...ok that makes sence your going to need to do a 6 inch lift if you cant fit them in already. without a bunch of redneck shit thats about as high as you can go. (9 inches)
  4. Jan 26, 2010 at 6:00 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    cut off the front suspension and put a solid axle up front
  5. Jan 26, 2010 at 4:03 PM
    Trdman98
    98 tacoma 4x4 6"
    SAS is in the future once i buy another truck but for now im looking for a dropbracket lift to use with my coilovers
  6. Jan 26, 2010 at 7:04 PM
    JimBeam
    JB
    2015 Tundra
    youre going to run into problems running 37s on those CV axles...you may run into problems using blocks in the rear...
