What Octane Gas Does Everyone Use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smurfio18, Oct 31, 2008.
  1. Oct 31, 2008 at 5:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Well, The 1GR-FE in the Tacoma has an 10:1 compression ratio, Output is 236 hp at 5200 rpm with 266 lb·ft of torque at 4000 rpm on 87 octane, and 239 hp at 5200 rpm with 278 lb·ft at 3700 rpm on 91 octane.
    Thats 12 more lb.-ft. of torque, at a lower rpm. And yes, it is very noticable.
  2. Oct 31, 2008 at 8:02 PM
    mitiko
    mitiko Well-Known Member
    lax
    05 prerunner trd
    I only use 91 LAX.
  3. Oct 31, 2008 at 8:15 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I usually run 87 or 89 in town. When I travel on the interstate I use 91.
  4. Nov 1, 2008 at 1:05 AM
    awymore997
    awymore997 Quitting is for Quitters
    Andrew
    Charlotte, NC
    08 Access Cab TRD OFRD 6 speed
    where did you get these numbers? Just curious I havent seen anything besides the factory numbers, I would like to see some dyno charts.
    Those numbers do make sense with the VVT engine, it is more prone to early detonation on the big cams, but at least with my truck the engine rarely sees anything above 3 grand. If your not at High RPM at WOT all the time it will be much of a change.
  5. Nov 1, 2008 at 1:16 AM
    vivafire
    vivafire Well-Known Member
    Galveston,Texas
    2024 TRD 4X4 OFF ROAD
    Just Amber LED turn signal lights for now
    87 at EXXON for 2.20
  6. Nov 1, 2008 at 1:19 AM
    JGUT
    JGUT Well-Known Member
    Yuma, AZ
    08 PreRunner Off Road Package
    2 Kicker 8" SL5, Kicker 750.1 mono amp, Kicker 200.4 amp, Kicker 6x9's front, Kicker 6.5's Rear, Pioneer AVH-P3200BT, Rear view camera
    I recently switched to 91 and I don't really notice a big difference but I do seem to get a little more mileage out of this.
    Besides if you read the manual it says 93 was used for the research so all those specifications were done with 93 not 87. It does tell you that you shouldn't use anything under 87.
  7. Nov 1, 2008 at 3:48 AM
    Chris-R
    Chris-R Member
    New England
    I use the cheapest gas at the pump except when it's time to plow snow. When I plow, I put 91 in my trucks because the engines really have to work.
  8. Nov 1, 2008 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those numbers ARE factory numbers. The 236 h.p. rateing is on 87 oct. fuel. The FJ is listed as 239 h.p., with 91 oct. The engine and tuning are the same between the FJ and Tacoma. In my owners manual, it even states best performance is achieved with premium fuel. :)
  9. Nov 1, 2008 at 11:09 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Premium (93) here.
    I can tell the difference.
    I hate it when people tell me it's all in my head. They can friggin walk instead of getting a ride in my truck.
  10. Nov 1, 2008 at 11:10 AM
    bambooshoots
    Kevin
    College Station, TX
    Well you also do get a bit better gas mileage, so it evens out.
  11. Nov 1, 2008 at 11:42 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I usually run 87. I think with gas the way it is, I'll start testing 89 to see any differences.
  12. Nov 1, 2008 at 12:04 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    can you all believe it? only couple of weeks ago it was up like $4.00
    now here NJ, $2.19. and keeps getting lower everyday, my old man told back in June said the gas will go down, he does not know when, but it will go down. My god, he was right!!!
    my old man talks about a lot of crap, but this one he hit the jackpot!
    it all of matter of when the gas will go back up again!!
    so u guys want to predict the when gas is going back up?
    i say right after the election! heheeh :D
  13. Nov 1, 2008 at 12:43 PM
    Kaddy08
    Kaddy08 Active Member
    Burbank IL
    08 double cab 2wd Prerunner SR5 OffRoad
    i put only 89, and only Shell or BP, No cheap gas in my trunk. The dfference in gas mileage is huge. All gas is the same, but its the additives that make the differance. And wait until the election is over, gas will go right back up. I wasn't suprised to see gas go down, happens every election. Its a game they play.
  14. Nov 1, 2008 at 2:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I've been saying for months on this forum that it will go down. I just don't buy into media hype like so many other folks out there. This increase followed the same exact pattern as the early 70's. Gas increased for 8 years and then sharply dropped.
    I don't believe gas will shoot up again anytime soon. When the economy improves (some experts think we've already hit bottom), gas will increase some but it won't go to $4/gal again for a long time. But, like you said, it really depends on who is in the White House. One candidate wants "windfall profits taxes" on oil companies. Now, considering businesses do not pay taxes, who do you think will be paying that tax?
  15. Nov 1, 2008 at 2:34 PM
    #35
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've only run 87 in mine, it's still fairly new, under 10,000 miles. I've been wondering, if I switch to 89 and then gas goes up, will I have any problems switching back to 87?
  16. Nov 1, 2008 at 2:37 PM
    #36
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^None at all. The computer automatically retards or advances the timing so you're good.
  17. Nov 1, 2008 at 2:39 PM
    #37
    oldtacomaguy
    Dave
    SE Conn.
    Thanks, maybe I'll try some.
  18. Nov 1, 2008 at 2:42 PM
    #38
    InaKoma08
    InaKoma08 INAKOMA08
    Nokesville, VA
    2008 TRD Access Cab
    FABTECH 6" Lift, 17x9 Moto Metal MO951, 35x12.50x17 Mickey Thompson Baja ATZ, Line Of Fire, Jardine Catback,
    So switching octanes like that is'nt bad for it? I know cars need/reccommend 93 and the same for 87. I was used to using 93 in my WRX all the time and the price change from 93 to 87 when I got my tacoma was awesome but is there really a performance gain if you use 93.. ie: better hauling, gas mileage, anything?
  19. Nov 1, 2008 at 2:50 PM
    #39
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Supposedly, 91+ is "recommended" for the Tacoma because the timing is retarded when using lower so you aren't getting the full hp/tq numbers (see chris4X4's post #30). But you can use any octane 87 or higher.
  20. Nov 1, 2008 at 2:53 PM
    #40
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I been running jet fuel. :D Talk about power
