What Oil Filter Do You Use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tylershane17, Feb 5, 2013.
  1. Feb 17, 2013 at 6:18 AM
    #41
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I've used Purolator PureOne filters for years.
  2. Feb 17, 2013 at 12:06 PM
    #42
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    attached is a list of oil filter part #s for all toyotas as of 2011
  3. Feb 17, 2013 at 12:12 PM
    #43
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    OEM Toyota from the Dealer. Cheap and the best.
  4. Feb 17, 2013 at 12:29 PM
    #44
    deez
    deez Well-Known Member
    Darren
    The I.E. - SoCal
    2002 V6 SR5 TRD 4WD
    Too many to list
    Wow, that's a good price (and comes with gaskets). I just picked up another case for my FJ (even though I have 7-8 filters left from a previous case). Thanks!
    As for the OP's question, OEM for both my Toyotas. In the FJ community, OEM is consensus as well. For <$4 each, can't beat it IMO.
  5. Feb 17, 2013 at 12:31 PM
    #45
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    Purolator. . made in NC!
  6. Feb 17, 2013 at 2:08 PM
    #46
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    New Tundra, new FJ, Camry, and a lot of others (primarily V6 but not limited to them) are using the new cartridge filter.
    No more spin-on.
  7. Feb 17, 2013 at 2:10 PM
    #47
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
  8. Feb 17, 2013 at 2:56 PM
    #48
    Fightnfire
    Marysville, WA
    Why does anyone use anything other than OEM with what we know about filters?
    :confused:
  9. Feb 17, 2013 at 3:45 PM
    #49
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    ANOTHER reason to run them, thanks. :plane:
    I select filters based on what I know, the 'collective' be damned. :rolleyes:
  10. Feb 17, 2013 at 3:55 PM
    #50
    TOMZCENTRAL
    TOMZCENTRAL Member
    TOM
    PHOENIX
    X-TENDED
    Volant CAI Flow Master Cat back split rear dual exhaust 5100 all 4 corners w/1.75 front lift.
    K&P Enginerring reusable.
  11. Feb 17, 2013 at 4:06 PM
    #51
    Devout
    Seattle
    03 TRD 4X4
    None yet
    What micron does it filter down to? :confused:
  12. Feb 17, 2013 at 4:20 PM
    #52
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
  13. Feb 17, 2013 at 4:35 PM
    #53
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I normally use Wix or M1 filters. Gonna go OEM on my next oil change.
  14. Feb 17, 2013 at 4:39 PM
    #54
    Rackster
    Kevin
    Connecticut
  15. Feb 17, 2013 at 4:55 PM
    #55
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    OEM, Purolator PureOne or Wix
  16. Feb 17, 2013 at 4:57 PM
    #56
    Rackster
    Kevin
    Connecticut
    From the reading I've done, these aren't bad alternatives (see links posted earlier). However, based on price and performance, the Denso is the optimal purchase. However, the larger cannister may have a small benefit in relationship to engine temperature.
  17. Feb 17, 2013 at 5:04 PM
    #57
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Add Mobil1 and K&N to your list. :cool:
    Wix makes NAPA filters.
  18. Feb 17, 2013 at 5:43 PM
    #58
    Tacomanator
    Clam Slammer
    Southern Cali
    I try to buy Wix whenever I can, but they're always out of stock.
  19. Feb 17, 2013 at 7:41 PM
    #59
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    So is WIX, they have a huge factory in Gastonia
    I work for a CARQUEST and our filters are also made by WIX.
    I run Amsoil and an Amsoil filter, the only other manufacture that they recommend is WIX. ;)
  20. Feb 18, 2013 at 3:55 PM
    #60
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Who makes filters for Amzoil? :)
