what rear diff fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaforlife, Jan 19, 2012.
  1. Jan 19, 2012 at 6:11 PM
    tacomaforlife
    tacomaforlife [OP] Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    whats the besd rear diff. fluid to use?
  2. Jan 19, 2012 at 6:18 PM
    tacomaforlife
    Robbie
    AIKEN, SC
  3. Jan 19, 2012 at 6:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Mobil1 75w90 or royal purple 75w90 are both good. Mobil1 a lil cheaper,and you can get them local.
  4. Jan 19, 2012 at 6:24 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    is the front diff. the same as well? and is there a special socket needed to do it?
  5. Jan 19, 2012 at 6:25 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Chase from ECGS says Royal Purple is the worst gear oil that you can use. He recommends Lucas Dyno oil 85/140w
    http://www.tacomaworld.com/forum/2n...lation-e-locker-3rd-member-3.html#post4238749
  6. Jan 19, 2012 at 6:33 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Thats what I use
  7. Jan 19, 2012 at 6:42 PM
    robertcope
    robertcope Active Member
    College Station, TX
    1997 Tacoma SR5
    Grey TRD S/C, URD 7th Injector
    I like Red Line fluids. In the diffs, I use their 75W90 GL-5 gear oil. In the transmission and transfer case, I like MT-90.
    robert
  8. Jan 19, 2012 at 6:48 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    how many quarts does the diff take?
  9. Jan 19, 2012 at 6:49 PM
    Rebel Taco 22
    Like 3 or 4. Just pour it till it starts coming out and put the cap back on.
  10. Jan 19, 2012 at 6:51 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    ok and any special tools to take the cap off?
  11. Jan 19, 2012 at 6:51 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  12. Jan 19, 2012 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    My rear diff took right at 3. And I use Mobil1 75w90 in both different and transfer case.
    I've never heard that about rp being shitty.
  13. Jan 19, 2012 at 6:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Front diff is a big allen head. Transfer case and rear diff fill and drain plugs are 24mm,and you do need the right crush washers.
  14. Jan 19, 2012 at 7:04 PM
    Rebel Taco 22
    What he said. Its nothing special, pretty dang easy. Front diff is a little bit more difficult and I used a funnel with a hose to make life easier pouring it in.
  15. Jan 19, 2012 at 7:12 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    As far as the fill/drain plugs go, best bet is to give them a crack with a hammer flush on their faces. 99% of the time they will become loose enough to remove without a wrench. BE SURE TO REMOVE FILL PLUGS FIRST!!!
