What shocks with AP expos?
Discussion in 'Suspension' started by Redgrom, Jun 10, 2012.
  1. Jun 10, 2012 at 6:22 PM
    Redgrom
    Redgrom [OP] http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Hello, just wanted to see what shocks those of you with allpro expos or standard leafs are running. Spoke with allpro and got their recommendation but thought id search around here and see what others recommend. I have Icons up front and was thinking the icon 2.5's but they are for a 0-2inch lift and the standard all pros give 3 inches of lift?
    Thanks for your help.
  2. Jun 10, 2012 at 6:28 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    I have expos with 10in icon 2.0 smooth bodies and there perfect... Fox has 9in wich are perfect for the standard all pro leafs but too short for expos
  3. Jun 10, 2012 at 8:55 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Measure your pack from shock mount to mount.....most of us are about 16-27". The RCD 5100s DSM sells are perfect but I'm saving for the 2.5" icons in the mean time. DSM has custom length icons and kings for "lifted" applications and are close to the needed lengths but they're custom order and think they charge $200.....so your looking at $1,000? :(
  4. Jun 10, 2012 at 9:17 PM
    Redgrom
    Brent
    san clemente
    I was really thinking about the 2.5 icons but looks like they might limit the travel by about a inch:confused: I like the idea of a custom length shock. I already rebuilt my rear back and have 5100's but really looking to upgrade my rear suspension but don't want to chop up the bed.
    Thanks for the replies.
  5. Jun 10, 2012 at 9:24 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Yup, that's where I'm at too! Marco will hook you up! When you find out more let me know! ;)
  6. Jun 11, 2012 at 7:41 AM
    buggin
    buggin Member
    Peter
    909
    09 4x4 Trail Camper DCLB
    King CO, Fox Rear w/ All Pro Expo, 285 BFG AT KO
    What was their reccomendation?
    I am seriously looking at getting the expo + fox kit that they sell. Is there a reason that you dont eant the kit? I figure all pro is going to put together a kit that is going to bolt on.
    I have a shell and plan on camping and 4x4ing with gear in the back. My only concern is having a stiff ride.while.the truck is empty and on the road.
  7. Jun 11, 2012 at 7:59 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    AP's kit it great but I believe the shocks are on the shorter end and will prevent "some" flex! It's hard to find a shock that's long enough but one that's also short enough to not bottom out at bump! AP's full kit is top notch and the Fox's have the compression adjusters so you can set them to your liking!
  8. Jun 11, 2012 at 11:38 AM
    Redgrom
    Brent
    san clemente
    Basically what mike said above. Also I was trying to find a 2.5 inch shock if possible.
  9. Jun 12, 2012 at 4:26 PM
    arlypoo
    arlypoo Well-Known Member
    Arlin
    Port Something
    2005 2.7 4x4
    I don't find the ride to be stiff at all. Mind you im used to early 80s mini trucks and landcruisers so my opinion may not count.
    I'm running a bilstein 5100 I found on their website based on my measurements, and they do not prevent flex at all.
  10. Jun 18, 2012 at 11:48 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    I just contacted DSM about this same issue today, I currently have King's OE rear shocks, went to All Pro Expo Leaf Pack and now the shocks have become the limiting factor ( along with the brake lines and ABS wire sensor; but I ordered new AP lines and got more slack on the ABS line ) DSM quoted me a bit under $1k for rear shocks OE bolt in but custom built to whatever length I need. Pretty hefty price, but I'm already running kings up front, so not sure if I want to mix/match. If i go Fox then I'd want to swap all of them out to Fox.
  11. Jun 19, 2012 at 5:42 AM
    Redgrom
    Brent
    san clemente
    Thanks for the reply, let us know what you decide.
    Thanks.
