What should I do next with my 3.4L engine?
Discussion in '1st Gen. Tacomas (1995-2004)' started by btu44, Oct 10, 2016.
  1. Oct 10, 2016 at 10:08 PM
    btu44
    btu44 [OP] Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Hello all,
    This one of my first posts so excuse me please for it being kind of long.
    I purchased an 04 Tacoma Double Cab Off Road 4x4 in July. She had a good amount of miles at 175K but is cosmetically excellent. I felt really good I made a good purchase.
    When I've had the time, I'm going through the truck and fixing any issues and changing fluids.
    This weekend I started changing the timing belt. Glad I did, the crank shaft bolt came off very easily. Must not have been torqued to spec by the prior mechanic.
    The water pump is in pretty bad shape. There was big pile of coolant crust at the bottom too.
    No biggy I had a new water pump with the timing belt kit.
    But here is what really has me worried. Evidently some rock pebbles had made there way into the air box. These pebbles were down at the bottom and were keeping the air filter from sealing properly. The amount grit through out the intake system look like it has been this way for a long time.
    And the worst discovery. This head gasket leak is near the #4 cylinder. I'm so bummed.
    I just sold an 89 Toyota PU 4x4 with the 3.0L. I was not expecting this on the 3.4L
    The spark plugs show a lot of electrode wear but are almost completely clean. Almost no deposits. Could it be that all the cylinder are leaking coolant or does this engine run very clean?
    I really wish I had checked the oil pressure and compression before I had take the engine so far apart. The engine runs great. No loose bearing knock or blue smoke out the tail pipe. It passed Cali smog so I'm guessing the bottom end is okay and the compression is good.
    Since this ugly discovery I have been doing a lot of reading. I understand that these motor have tendency to have cracked heads.
    I would like to ask the engine builders out there what is your opinion of this engine? Is it likely toast? Is it worth spending $80 on a leak down tester before pulling the heads?
    All I have left to do is remove the lower intake manifold, exhaust manifolds and cams before the heads come off.
    Any advice is appreciated.
    Barry
  2. Oct 11, 2016 at 5:46 AM
    Treedin
    Treedin Well-Known Member
    2002 Tacoma 2.4L
    Excellent pics and write up. Sorry I cant help but there is a vast amount of knowledgeable people on here that should have some great suggestions. Nice looking truck and good luck.
  3. Oct 11, 2016 at 7:03 AM
    04rktaco
    04rktaco Well-Known Member
    Lee
    California City, Ca.
    '04 4x4 xtra cab 4x4 TRD. 2014 Tundra crewmax TRD 4x4
    All Pro UCAs King coil-overs All Pro rear springs Modified All Pro Bumpers. Home made skids and sliders. Lefty 4.7 transfer case. Stock e locker rear stock 4:10's Tundra Brakes 285/75/16 Falcon Wildpeak AT3W stock wheels with 1.25 spacers BAMF lca skids. 2014 Tundra crewmax TRD 4x4 5.7 v-8 with leather interior. RCI Metalworks full set aluminum skidplates All Pro rock sliders
    My 3.4 has been doing that for close to 100,000 miles and still runs perfect. Looks like the same exact place too. As long as your oil looks good and you can do a compression check and if the numbers are good then it's nothing to worry about it's just leaking out. I have to add a little coolant about every 3 months and that's only about 8oz so very little probably normal amount for evaporation. If I clean it off after a few weeks it gets the crust again and that's it. I wouldn't worry about it.
    btu44[OP] and MTopp like this.
  4. Oct 11, 2016 at 8:06 AM
    btu44
    Long Beach area, Ca
    This is good to hear. A guy I worked with said the same thing. I like to hear the same opinion a few times before I tend to believe things.
    It looks like we go wheeling in the same area. If the truck wasn't down I would have done Red Rock Canyon with TTORA last weekend.
    Would you have any reservation about taking your truck full length of the Mojave Trail or some gnarly trail near Big Bear.
  5. Oct 11, 2016 at 9:31 AM
    eon_blue
    eon_blue Most Improved Member
    The 3.4l is a very stout motor, arguably the best V6 Toyota has ever made (the 4.0l is tried and true as well). Cracked heads and blown gaskets plagued the 3.4l's predecessor, the 3.0l V6 of the late 80's/early to mid 90's. That was probably the worst motor Toyota has made, lol. They learned their lesson with the 3.4l and it's not really a motor you ever have to worry about if it's been well taken care of.
    I'd get a compression check done like mentioned above to be sure everything is working as it should
    MTopp likes this.
  6. Oct 11, 2016 at 9:54 AM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    i would try to torch the bolts on the valve cover gaskets that'll tighten the head down on the gasket it fixed my coolant leak when i had 270k on original gaskets
  7. Oct 11, 2016 at 1:08 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I wouldn't even worry about that dried accumulation honestly. It doesn't even appear to be wet. I have a very similar dried residue pile near the thermostat housing which doesn't seem to leak or have any other issues. If it were constantly wet/ leaking into the cyl/ out the side of the block then that would be something to address. Are you saying that you already have the engine torn down to do the work?
  8. Oct 11, 2016 at 6:08 PM
    04rktaco
    Lee
    I have no reservation taking my truck anywhere. Have been to Moab several times and ran the harder trails like Behind the Rocks and Golden spike and most of the local harder trails like Nightmare Gultch after a rain when it was still open with no problems. These trucks will go just about anywhere they just flat out work even when stock and you don't have to worry about breaking down.
  9. Oct 11, 2016 at 6:18 PM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    Like your truck - wish mine was a 4 door.
    Just drive it. That sounds simplistic but it's a legendary engine and if it's running smooth and cool just drive it. Either that or go ahead and bite the bullet and do the heads for peace of mind. I replace plenty of stuff for peace of mind. I know of no tendency for 3.4's to have cracked heads - you may be thinking about the 3.0 which preceded it. Mine has 180K on it, is sludged (that's a thing) and was neglected by the PO, and it still runs like a scalded dog. I just take care of it and don't worry about it.
  10. Oct 11, 2016 at 6:43 PM
    btu44
    Long Beach area, Ca
    Thanks everybody for the great replies. Yes, I do have a strong tendency to replace things for piece of mind but this case I'll resist. I'll buy a leak down tester and if everything checks okay I'll leave the HG alone.
    What's your opinion of the spark plugs from this engine. They look very clean to me. But since they are all pretty much the same I'm not thinking it is a coolant stream cleaning issue. Would you guys say they look normal?
    Another question about spark plugs is I understand that Toyota went with these duel electrode spark plugs because this engine design has a wasted spark (the plugs spark every stoke instead of just at the power stroke). So the duel plugs would give longer life. But now with the long life of iridium plugs could they be used? Has anyone had good experience with iridium plugs?
  11. Oct 12, 2016 at 4:35 PM
    OneWheelPeel
    Phoenix, AZ
    Those plugs look great, very new. Throw them back in and get another 50k out of them. 90% of people on here will recommend you the factory spark plugs because they seem to work just fine without Boost. They're not expensive either.
  12. Oct 12, 2016 at 4:42 PM
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    id say replace your front shocks with 5100's
  13. Oct 12, 2016 at 7:08 PM
    btu44
    Long Beach area, Ca
    If I had zoomed into one of the plugs closely you can see a fair amount electrode erosion so I think they have quite a few miles on them. That why I'm surprised there so clean.
    I had 5100's on a 89 Toyota Xtra Cab 4wd and they were awesome. The truck floated over the rough stuff and all the gear stayed in the bed. I just had the ICONs revalved so I hope there as good as the Bilstein's. Just have to get the truck mobile again. :)
  14. Oct 13, 2016 at 11:53 AM
    eon_blue
    Iridium plugs should really only be used on forced induction applications (i.e. if you're running the TRD supercharger). The 3.4l motor was designed to run on copper plugs so I would stick with those.
  15. Oct 13, 2016 at 1:42 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    what?
  16. Oct 13, 2016 at 3:58 PM
    btu44
    Long Beach area, Ca
    I agree that the OEM plugs are the way to go. I would like to know if the lack of deposits on my plugs are normal. I usually see a light brown deposit on plugs but this engine is new to me.
    +1
  17. Oct 13, 2016 at 4:06 PM
    eon_blue
    I'm not that well-versed in spark plug health by the looks of them but hopefully this chart helps
    edit: just realized it's hard to read the screenshot, here's the link to the page it's from...
    http://3.bp.blogspot.com/-5aOlZoHEn...niUCG_5I/s1600/check_spark_plug_condition.jpg
  18. Oct 13, 2016 at 4:08 PM
    eon_blue
    Kind of hard to see the pic you posted of your's but based on what I can see versus the chart above, they look like they've worn normally
  19. Oct 13, 2016 at 4:25 PM
    btu44
    Long Beach area, Ca
    Yea their nothing like in the chart (I think that chart is a Clymer Manual staple). The plugs are just very clean like the engine is running lean. When I get it all back together if there's no ping then I figure all is good.
    Thanks
  20. Oct 16, 2016 at 7:48 PM
    VeeSix
    Tennessee, USA
    2011 Tacoma 4x4
    You put a torch on your valve cover bolts...to stop a leak...
    ...of coolant.
