what should i do to the rear??
Discussion in 'Suspension' started by cgarci42, Oct 22, 2010.
  1. Oct 22, 2010 at 9:01 AM
    cgarci42
    cgarci42 [OP] Active Member
    Cory
    el paso
    05 Prerunner TRD Sport
    if i were to set the bilsteins at 2.5" what would i need in the back to keep it level and not nose high? since i dont have the tsb and its probably not an option since the extended warranty is over [​IMG] i was looking at aals on toytec and not too sure which would i need? or what would i need??
  2. Oct 22, 2010 at 9:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Either of those will work just fine.
  3. Oct 22, 2010 at 9:06 AM
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    I did AAL 1.5 mines level
  4. Oct 22, 2010 at 9:34 AM
    cgarci42
    Cory
    el paso
    so then i could go with just the single AAL and not the whole pack and itd be fine?
    i noticed on the first link it had two is it one leaf per side or would i have to order another set?
  5. Oct 22, 2010 at 9:43 AM
    dirtytaco2010
    SR5 TRD Sport LB
    i got this one which is your first option it was 2'' not 1.5 my bad...it provides about 1.5'' of lift. it comes with one leaf for each side..easy install too there are some good write ups on here. be careful when lowering the rear diff my truck fell off the jack stands with me under it haha. just make sure youre on level ground and put blocks behind the front tires (which my dumbass didnt do..the one time i didnt do it too)
    it rides nice too and better load compacity
  6. Oct 22, 2010 at 9:44 AM
    dirtytaco2010
    SR5 TRD Sport LB
    and you wont need new U bolts
  7. Oct 22, 2010 at 11:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as he has an '05, it would be a good idea to replace them.
  8. Oct 22, 2010 at 11:24 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^
    my 5100's @ 2.5 and a 2" aal in back ...keeps it slightyl higher in rear....no tsb
  9. Oct 22, 2010 at 2:34 PM
    cgarci42
    Cory
    el paso
    would it be bad if i just got the single ones and not replacing?
  10. Oct 22, 2010 at 2:59 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    he means do the aal but replace the u bolts when u install it
    you will be happy and its easy to do.....
  11. Oct 22, 2010 at 7:09 PM
    cgarci42
    Cory
    el paso
    oh alright thanks for the help guys!
  12. Oct 24, 2010 at 11:47 AM
    dirtytaco2010
    SR5 TRD Sport LB
    good point
