what should i do
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98Tacoma, Nov 19, 2009.
  1. Nov 19, 2009 at 12:57 PM
    98Tacoma
    98Tacoma [OP] Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    i have a 1998 tacoma and have been searching for a nice lift. i have heard alot of good things abour ome lifts and wondering what yall think about it? or any others suggestions about what may be a good lift. i wheel every once in awhile and especially during hunting season. i want a good suspension feel and a aggressive look. and any pics of a ome lift would be great thanks. also what are yalls take on body lifts and spacer lifts?
    here is the lift im thinkin about
  2. Nov 19, 2009 at 1:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    The OME is an excellent all round choice. So are Billy's on the corners with an AAL. Stay away from blocks and spacers.
  3. Nov 19, 2009 at 1:40 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    ill have to check out billys. yea im not a big fan of body lifts or spacers havemt really heard good things about them
  4. Nov 20, 2009 at 7:40 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
  5. Nov 20, 2009 at 7:50 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Give us a budget and how you are going to use your truck. Thanks.
  6. Nov 20, 2009 at 8:38 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    im lookin to spend 600-800. i will be using it for mainly on the road but i also wheel some. and i will go off road alot during hunting season also. ive looked into coilover but i dont think i wheel hard enough for that. but i like the ome lift because it allows me to replace 11 year old shocks and springs.
    thanks, adam
  7. Nov 20, 2009 at 8:40 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Full OME kit with discount. 664. Toytec. Contact Neubs through PM.
  8. Nov 20, 2009 at 10:43 AM
    tmolina
    tmolina Well-Known Member
    Thomas
    AZ
    '02 Tacoma dbl cab Prerunner
    2 inch lift with SAW's on front, AAL on rear
    GO with the OME lift you posted the link on. Get 881's for coils unless you have a heavy front bumper and winch then go with 882's...
  9. Nov 20, 2009 at 3:54 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i saw some where that the shocks may have to replaced in about 5 years is that true? im sure that for people who wheel real hard
  10. Nov 21, 2009 at 9:39 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    OME gear does tend to wear out faster than some of the other gear out there does. '
    Like Bilstein for example. They believe in their shock so much, they offer a life time warranty on them.
    If you still have the stock susupension, I would highly recommend replacing both the shock and coil up front. With your budget amount, I would probably stick with the OME stuff also. They do only offer a limited two year warranty. .
    If you want to save a little bit for the , we do offer a life time warranty on the gear, and I know the shocks will last longer than 5 years under normal use. (not abused).
    Hope that helps a little bit..
  11. Nov 21, 2009 at 2:38 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    well im just looking for something that is not going to be needing replacement for a long time would rather spen a little more at the beginning than alot more down the road. i didnt know that they only had a 2 year warranty on ome shocks.
    well even when i get a lift im sure i wont abuse the suspension more than i do now i love my truck to much to hurt it.:)
    its just a hard decision to make.
  12. Nov 22, 2009 at 3:56 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i just have a westin brushguard on the front. are the 882s real stiff?
  13. Nov 23, 2009 at 9:02 AM
    Toytec Lifts
    Rocky Mountains
    I hear ya on hurting your truck!
    yap, just a couple years.
    I do know how hard it is.
    Good luck deciding. :)
  14. Nov 23, 2009 at 9:05 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    I have full OME. It's absolutely awesome, recommended for anyone. I have 881s and an ARB bull bar, so you don't need 882s. The 881 coils will work just as well.
  15. Nov 23, 2009 at 9:07 AM
    Toytec Lifts
    Rocky Mountains
    The 882s can be a bit stiff if you don't have the right amount of weight on them. ToyTec has taken a different industry standard on these springs. With our own research, we have determined that the 883 will work better for more of a medium coil and the 882's for more of a heavy spring.
    The spring rate is the same from 881 to 882, just a longer coil with more coils on it. 883's jump up in spring rate, but keep the exact coil height of the 881s.
    weird I know ;)
    So, depending how much that westin brushguard weighs, you might be just fine with the 881s.
  16. Nov 23, 2009 at 9:17 AM
    Toytec Lifts
    Rocky Mountains
    I'm very excited that is working out for you, but normally, the bull bar usually requires a heavier spring to handle the weight appropriately.
  17. Nov 23, 2009 at 12:16 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    do you have any pics with the lift before/after? also why did you choose the ome insted of a kit like the toytec ultimate kit? just trying to hear a few things that might help me make my decision
  18. Nov 23, 2009 at 7:12 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    I was told by 4x4connection that 880s would be too soft and 881s would work perfectly. ARB also said the same thing. I have the stiff nitrocharger shocks, though. I also do not have a winch, so the bar itself is heavy, but not overly heavy.
    I bought the truck with a shitty rough country lift kit (spacers, rear shocks, extended shackles) on the stock suspension, which SUCKED. I have always wanted a Tacoma with an ARB bar, so I just chose OME in the front to handle that weight.
    The rear suspension came as a result of breaking a rear leafs due to repeated mulch and compost loads, so I decided to beef it up. I needed new springs and shocks anyways, so I just decided to complete the OME suspension.
  19. Nov 23, 2009 at 10:28 PM
    Broditaco
    Broditaco New Member
    Alaska
    taco
    K,N cold air, downy header, straight pipe, 6 inch lift 33X12.5s
    look on for a 6 inch fabtech or pro comp unless you like the questions "is that thing lifted?"
  20. Dec 18, 2009 at 8:45 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i have been looking at bilstein 5100s and i read that you can adjust them to get 1-2.5 inches of lift. does that just have a perch that compreses the spring to give the lift? if someone could explain this to me it would be great and maybe some pics also.
