what should my alignment specs. be?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mixaro, Feb 13, 2011.
  1. Feb 13, 2011 at 12:51 PM
    mixaro
    mixaro [OP] Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    ok my yota is finally going in for the frame change, and i was wondering what m alignment specs. should be, cause it's been a while since i aligned it. i have the LR upper control arms, billy 5100's at 0 with the ome 882 springs. along with the diff drop.
    Thanks in advance!
  2. Feb 13, 2011 at 5:04 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    They will align it automatically for you. No need to worry. Post pictures of the new frame when it's all said and done :)
  3. Feb 13, 2011 at 5:31 PM
    mixaro
    maine
    yeah but the last time i had them align it before i had the lift the f-ed everything up so i want to tell them what i want them to be.
  4. Feb 13, 2011 at 5:36 PM
    Supra TT
    Eric
    Indiana
    If they f it up. Make them re-do it. Tell them you feel unsafe and it's costing you $ in parts to replace the tires and suspension etc lol :D
  5. Feb 13, 2011 at 6:31 PM
    mixaro
    maine
    well the last time they did it was like 3 years ago, i had it aligned by my brother inlaw after the lift (best damn mechanic i've seen) and we did it at the ford garage he works at on a sunday (yeah i know i went to a ford garage). anyway it's going in for the frame tomorrow, and i'm just scared that they are going to f something up, cause my local toyota garage does not have the best rep. from my experience and from what other people have told me.
  6. Feb 13, 2011 at 6:33 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    I had my frame replaced and had ome 881, 5100s and icon aal put in by the dealership. Everything is good for me!
  7. Feb 13, 2011 at 6:35 PM
    mixaro
    maine
    well thats a sigh of relief cause all i heard about is the horror shows on here. i just want my truck back they way i left it.
  8. Feb 13, 2011 at 6:45 PM
    Supra TT
    Eric
    Indiana
    God damn stealerships... Well if all else fails, take it back to the ford and get it aligned. At least you know your brother in-law is repuable.
  9. Feb 13, 2011 at 6:54 PM
    mixaro
    maine
    ha ha true, but i shouldn't even half to worry about this bs
  10. Feb 13, 2011 at 6:56 PM
    Supra TT
    Eric
    Indiana
    Exactly. I guess just trust the stealership on this. And watch your treadware. Also make sure it drives straight.
  11. Feb 13, 2011 at 10:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Getting a high enough caster setting is usually the problem with stock UCAs. Your LR UCAs can be set at 2.0 degrees of positive caster to start with.
    Ask for a detailed report on what they set the alignment to. You do not have to accept that old line about how they were able to get into spec. Ask for the exact settings they used.
    Toe and camber should be 0 degrees for both sides. With your UCAs caster should be at least 2.4 degrees. Somewhere between 2.4 and 3.0 is ideal.
  12. Feb 14, 2011 at 7:43 AM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    How long did you have to wait before you received a call from the dealer to take your truck in for the frame replacement? I've been waiting since October and still no frame!!!!
  13. May 28, 2012 at 5:43 AM
    Namdis
    Namdis Bob
    Bob
    Rhode Island
    04 Tacoma
    Imagine you figured out the answer to this question (how long does it take for the dealership to get the replacement frame in) . My dealership gave me a 2012 Tacoma the day they looked at the frame. Took a total of 2 weeks for the regional rep to come down and ok the replacment and get the new frame in. Two more weeks to do the work.
  14. May 28, 2012 at 5:15 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Wow.. your irrelevant post on a 15 month old thread has led me to the answer to an alignment question I had .. nice work ! Haha
  15. May 28, 2012 at 5:24 PM
    mixaro
    maine
    ha ha ha ha:laugh:
