What size bit to use to bore the D-rings ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rendertrust, Feb 20, 2010.
  1. Feb 20, 2010 at 6:43 PM
    rendertrust
    rendertrust [OP] Member
  2. Feb 20, 2010 at 7:39 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
  3. Feb 20, 2010 at 11:08 PM
    nxtruck
    nxtruck Member
    No need for all that, I just used the biggest bit I had and widened out the hole until the stock bed bolt fit while in the middle of my driveway.
  4. Feb 21, 2010 at 5:23 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    That won't be quite big enough as the bolts have a section near the head that is wider than the threads. That's what keeps the washer captive. That's what I recall anyway.
    If you don't have a set of drill bits, I'm pretty sure that 1/2" would do the job. I don't have any metal bits larger than that.
  5. Feb 21, 2010 at 5:34 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
  6. Feb 21, 2010 at 5:44 AM
    SlurpeeBlueMetallic
    I managed to get them wide enough using a Unibit and didn't come anywhere near the top of the bit... it'll work.
    Getting the washers off the bolt... that's a pain in the rear, but widening the hole in the d-rings is easy.
  7. Feb 21, 2010 at 5:51 AM
    HankB
    Hank
    near Chicago
    bone stock
    I didn't remove the washer. I ground one side of it flat to fit the D-ring and touched it up with some black paint. I bought an angle grinder a couple months ago and I'm really surprised how often I use it. :D If all I had was a hammer, I guess it would have looked like a nail. :rolleyes:
  8. Feb 21, 2010 at 2:35 PM
    SlurpeeBlueMetallic
    I saw a write-up where the same thing was done (grind one side of the washer flat) and that turned out well. To your point, all I had was a hammer, a metal file and a vise (and a drill, and a step bit, etc but no grinder) so I got busy. :D
  9. Feb 21, 2010 at 2:38 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Inibit FTW
  10. Feb 21, 2010 at 6:33 PM
    austex
    austex Member
    Tom
    Texas
    Base
    I got the washers off by setting the bolt head-down in a 27mm socket on the floor, washer resting on the rim of the sockert, then hammering the end of the bolt. There are no threads at the end, so no worry about dinging them. Reinstalled the washers after adding the D-rings by slipping an piece of pipe over the bolt and driving them back on.
    I used OEM D-rings, took the plastic collar out and made some spacers from 1/2" id, 5/8" od tube to try to get the D-rings to swivel, like the ones at the rear. On tightening things down, the spacer bowed the big washer down into the hole in the bed, and the now-cupped washer caused the ring to bind, not swivel. Took out the spacer and will live with fixed position D-rings. Alternative would be to make longer spacers, but then the bolt head sticks up more than I want.
