What size block for NON-Leaf TSB with 5100's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bsons, Jul 25, 2013.
  1. Jul 25, 2013 at 3:41 PM
    bsons
    bsons [OP] Member
    I am thinking of setting my 5100's at 1.75" up front. In the rear, since I do not have a leaf spring TSB nor do I want to spend the $$ on getting a set, I am going to add a block to the back.
    My biggest fear is having my front end higher than my back end.
    Everyone on here seems to have the rear leaf tsb, but I do not. I have a 2006 Sport 2WD extra cab radiant red beauty. Hope this can help out everyone else who doesn't have the free leaf TSB.
    My questions is: Will a 1" Ready lift block level out the back? or because I don't have the extra leaf will I need a larger block?
  2. Jul 25, 2013 at 3:47 PM
    PinkTaco24
    PinkTaco24 Well-Known Member
    NC
    06 prerunner
    5100s all around -- 1.75 fronts, 1.5 aal, spidertraxs, grillcraft mx, derped scoop & badges, AVID step bars....need.more.money.
    1". I had that with 5100s at 1.75 and it was level.
  3. Jul 25, 2013 at 3:47 PM
    PinkTaco24
    NC
    06 prerunner
    I'm 06 Prerunner btw
  4. Jul 25, 2013 at 3:55 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    I would go with a 1.5 and reason I say this is the 1.5 block has a taper where as the 1" block doesn't. Helps a lil on your driveshaft angle to eliminate any vibes.
  5. Jul 25, 2013 at 4:06 PM
    bsons
    bsons [OP] Member
    You guys are awesome. Thank you so much!
  6. Jul 26, 2013 at 4:51 AM
    PinkTaco24
    NC
    06 prerunner
    I never had any vibes at all with a 1", but I know all tacomas are different. Good luck OP.
  7. Jul 26, 2013 at 4:54 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Like dis? \/
    Or dis \/
