What size leveling kit for 285/75/17 tires
Discussion in 'Wheels & Tires' started by jglott, May 12, 2013.
  1. May 12, 2013 at 9:33 AM
    jglott
    jglott [OP] New Member
    10 sr5 4x4 dbl. cab
    Hey. I'm trying to decide what size leveling kit (front and back if need be) is necessary to fit 285/75/17 size tires on my 2010 double cab 4x4 tacoma? I want to get BFG a/t and don't want any rubbing. Thanks
  2. May 12, 2013 at 9:52 AM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    ive got the 285 70 r17 with a 2" spacer up front and one extra leaf in the back...not sure what the lift is because it was on the truck when I bought it, but I get rubbing sometimes when turning and hitting a bump. I also had to do a little bit of trimming up front and removal of the front mud flaps. Since you are looking at getting tires bigger than mine, I would suggest getting a bigger suspension lift to avoid rubbage.
  3. May 12, 2013 at 10:24 AM
    jglott
    10 sr5 4x4 dbl. cab
    Ok. Thanks. From what I've read I was thinking a 3" up front and maybe a 2" in the back. I'm just not that familiar with rear kit sizes. I've got the TRD sport wheels, think I'll need to make a change? It's got 265/75/17's on there right now stock?
  4. May 12, 2013 at 10:37 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Don't forget if you are using stock wheels and 285s you will need wheel spacers or your tires will rub the upper control arm.
  5. May 12, 2013 at 11:48 AM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    285/75/17 is a 34" tire. If you want no rubbing you would probably need a 6" db lift. On a 3" lift you will definitely have to chop the cab mount, remove mud flaps and cut inner fenders a lot and you will probably still rub! Read this thread http://www.tacomaworld.com/forum/wh...hing-but-truth-bf-goodrich-km2-285-75r17.html
    Probably best to go with a 285/70R17 for less troubles unless you want to do lots of cutting
  6. May 12, 2013 at 1:18 PM
    jglott
    10 sr5 4x4 dbl. cab
    Thanks for the insight! I'll look into 70's instead of 75's. Don't really want to do a lot of trimming. Trying to keep it as simple a transition as possible
  7. May 12, 2013 at 8:43 PM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    And that is the answer I've been looking for. Thanks!
  8. May 14, 2013 at 9:50 AM
    DevL
    DevL Well-Known Member
    The lift does not change what tires and wheels fit, only the amount of compression you will have till they rub. The trimming for "no rubbing" is the same for stock and your leveling lift.
  9. May 14, 2013 at 7:01 PM
    NelsonTacoma
    Tucson, AZ
    :thumbsup:
