What size tires do i need?
Discussion in 'Wheels & Tires' started by prestontaco07, Feb 6, 2009.
  1. Feb 6, 2009 at 9:34 AM
    prestontaco07
    prestontaco07 [OP] New Member
    Inman South Carolina
    07 tacoma mini
    I have a 2007 Toyota Tacoma Reg Cab 4x2. i am wanting to get a more offroad look to my truck. does anybody know what is the biggest size tires i would need to put on my stock rims without buying a lift?
  2. Feb 6, 2009 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma World!!
    Is your truck a 5 lug, or 6?
  3. Feb 6, 2009 at 9:38 AM
    garage_monkey
    garage_monkey You're dumber than stupid.
    Carlsbad, NM
    Silver '08 and Lunar '22 DCs
    Murdered Out the Rims, ARB Bumper, OME upgrade
    I would search through past threads, but my guess would 265's tops without getting a lift kit or a leveling kit.
  4. Feb 6, 2009 at 9:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Unless its a 5 lugger.
  5. Feb 7, 2009 at 4:41 PM
    prestontaco07
    07 tacoma mini
    its a 5 lugger
  6. Feb 9, 2009 at 9:11 AM
    jwjknorr
    jwjknorr Well-Known Member
    NJ
    09 TACO Sr5 Wish i got a 4x4
    Intake,Exhaust, short shifter, ReadyLift
    also wondering i have a five lug and i want the biggest tire i can have without rubing im getting a 3 inch lift
  7. Feb 9, 2009 at 9:47 AM
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    With a 3" the biggest you can go is 31". I have 31x10.5x15. You'll have to remove the "black box," but you'll probably end up doing that anyway. It's just a few bolts, and they have no purpose.
  8. Feb 9, 2009 at 9:52 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    What is the limiting factor on the 5 luggers. Are they rubbing the control arms or just too much stuff to cut? Also what is the balck box? I don't have a 5 lug just curious.
  9. Feb 9, 2009 at 9:56 AM
    BioMed80
    09 Regular Cab
    Not sure what makes the difference between the 5 lugs and 6. Chris can probably answer that.
    The black box is a small black metal box in the fender well, under the plastic. It pops out just enough to rub when you have bigger tires. You take out the bolts, trim the plastic, and you're done.
  10. Feb 9, 2009 at 10:05 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Cool man thanks, I was curious as I haven't seen any 5 luggers in person that have been modded in any way.
  11. Feb 10, 2009 at 6:28 AM
    prestontaco07
    07 tacoma mini
    so 265 are probably my biggest option without the lift?
  12. Feb 10, 2009 at 6:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your probably only going to be able to fit a tire 1 size larger than stock with no lift. 265 is a tire width, so more info on the tire is needed, i.e., 265/75/15, etc.
