What size tires on your TRD pro?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jake slatnick, Jan 30, 2017.
  1. Jan 30, 2017 at 11:15 AM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    Trying to pick a tire size for my stock 2017 TRD pro. Looking at the ko2 but nervous about putting on the 285/75r16 (33"), might be too wide. I've heard 255/85r16 (33") fits no problem on the stock pro but it's obviously quite a bit thinner than the ko2...
    The size down on the ko2 is a 31.5" which is smaller than I wanted to go with.
    What's everyone running?? Are you happy with it??
  2. Jan 30, 2017 at 11:18 AM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
  3. Jan 30, 2017 at 11:18 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I'd be more worried about the transmission. 285's are only 32 1/2. Did you search there are a few other threads about tire size on Pro's.
  4. Jan 30, 2017 at 11:21 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    What would worry you about the transmission?
    I've been searching and not finding much. I'll keep looking
  5. Jan 30, 2017 at 11:22 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
  6. Jan 30, 2017 at 11:22 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Low end torque sucks. So it will dog your truck down like a bitch unless you regear.
    bobrown14 likes this.
  7. Jan 30, 2017 at 11:23 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    What's it cost to regear?
  8. Jan 30, 2017 at 11:24 AM
    smitty99
    Scottsdale
    2 grand maybe more after parts and labor
  9. Jan 30, 2017 at 11:39 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Pro's have 1" front lift, so anything that fits a non Pro with 1" lift should fit.
    The problem is here, 5th and 6th are way to tall of gears, not sure what Toyota was thinking, besides mpgs.
    Top speed in 6th with 285's would be 258mph :rofl:
  10. Jan 30, 2017 at 11:46 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Lol no way...
  11. Jan 30, 2017 at 12:16 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Doesn't seem worth it over some tires. Would the regear just make it feel stock again?
  12. Jan 30, 2017 at 12:55 PM
    smitty99
    Scottsdale
    Talk to @Sixgun CO he regeared to 4.88s I believe because his tires were dogging his truck down so badly and the transmission was shifting like total crap. Remember with bigger heavier tires you are adding more rotational mass, more aggressive tread creates more rolling resistance, etc. It's going to hurt you in more ways than one. Are the "looks" worth it for you?
  13. Jan 30, 2017 at 2:46 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Yes that ^^^ by more rotational mass it comes down to "un-sprung weight". The un-sprung weight is the mass of the wheels, tires and brakes past the end of the axle shaft. The more un-sprung weight the less performance... it'll slow you down and lessen your MPGs.
    So take a close look at "C" rated tires as these are several pounds lighter that E load rating and C is what this truck is made for.
    First question is: How much off road wheeling are you going to do.... you want larger tires for a more radical look? or off road capabilities? K02s.. meh.... I don't think they have much of either but they are popular around these parts.
    I run Nitto Terra Grappler G2 265/70R17 ... these are great tires ... if you want to wheel off road there are others that folks here will suggest. I'll get the Nitto Ridge Grappler next..
    http://www.nittotire.com/light-truck-tires/ridge-grappler-light-truck-tire/
    smitty99[QUOTED] likes this.
  14. Jan 30, 2017 at 3:51 PM
    tfree
    tfree Well-Known Member
    Nebraska
    2017 TRD ORAC
    I have 275/70 17s and like it. BFG KO2s. Any bigger might be comical. I think it would probably work without a lift, but that would be tight. I sit about 2 inches higher in the front and back right now but will be down about another inch when the topper, PRINSU rack and trans/trans skids go on.
    I do notice the engine has to down shift more to get into the power band, and my speedo is about 3% off. I have a six speed automatic and rarely entered 6th gear so I am not sure putting 4.56 gears would help that much. I would run higher RPMs in each gear, but a lot of people already complain about that and I think the transmission is smart enough to put me in the proper gear for the pull on the engine. Again, it has 6 gears to choose from.
    I've never thought about putting larger on, but thought maybe 265/75 17s might have worked.
    SilverII likes this.
  15. Jan 30, 2017 at 4:44 PM
    smitty99
    Scottsdale
    4.88s
  16. Jan 30, 2017 at 10:43 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    But how much does it actually slow you down? For someone just casually driving will it really be that noticeable?
  17. Jan 30, 2017 at 10:51 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    So what you're saying is a 55lb 32" tire isn't compromising the ride? It's hard to tell because everyone says it slows you down so much... I totally get if you're critical on the performance, but for everyday casual use how much of an affect does it really have?
    By the way sick truck!
  18. Jan 30, 2017 at 10:55 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    @Sixgun CO what were you experiencing? What size tires are you running? How'd the regear do for you?
    Sixgun CO likes this.
  19. Jan 31, 2017 at 12:08 AM
    Smitty4699
    Smitty4699 Well-Known Member
    Brian
    2017 Cement TRD Pro
    IMG_0200.jpg 285/70/17 nitto terra grappler g2's
    Brostjoe, deemiller and SilverII like this.
  20. Jan 31, 2017 at 4:18 AM
    tfree
    Nebraska
    2017 TRD ORAC
    I think you could go with 285 on a quad cab but you really stretch the proportions visually. Fibanacci was the great designer of them all and we must follow his proportions.
