What size tires on your TRD pro?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jake slatnick, Jan 30, 2017.
  1. Jan 31, 2017 at 4:23 AM
    tfree
    tfree Well-Known Member
    Nebraska
    2017 TRD ORAC
    My ride is great. I don't drive too crazy. There is more momentum.
    Unsprung weight doesn't hurt mpg more than other weight unless it is rotational or moving it up and down a lot. It does increase tire wear however.
  2. Jan 31, 2017 at 4:56 AM
    Sixgun CO
    Sixgun CO Well-Known Member
    16 Tocoma TRD off-road
    Brand new 07-28
    I am experienceing much more happiness after re-gearing.
  3. Feb 20, 2018 at 8:22 PM
    MGMTaco17
    MGMTaco17 Well-Known Member
    Orange County, CA
    2017 Tacoma DCSB TRD Sport
    2017 DCSB TRD Sport. TRD Pro Grille. Morimoto Elite 35W HID Headlights. Morimoto XB LED Fog Lights. Clazzio All Black Leather Seat Covers. 32" LED Light Bar Bumper Stealth Mount. BHLM. Raptor Light Kit. Leer 100R. Bilstein 6112/5100 set at 3rd notch. LT275/70-17 C-Load Hercules Terra Trac AT2. Bora .750" Wheel Spacers.
    Looks awesome. How do you like it? Did you get the C load range? Any issue with low end torque from the 285s? Rubbing??
  4. Feb 21, 2018 at 10:30 AM
    SirRoytzz
    SirRoytzz Taco Enthusiast
    Pro owner here. I'd go 265/75/16 if you have the stock pro wheels on the car. No rubbing. No trimming required. You can fit 285s but under full lock you could rub. If you don't really off road then maybe you won't even notice.
  5. Feb 21, 2018 at 7:43 PM
    09tacohb
    09tacohb Well-Known Member
    Huntington Beach, CA
    2018 TRD Pro
    920C4E2B-2DDF-4AB4-A18C-A35BE795FBC1.jpg 265/75r16 Nitto Terrgrapplers. Like the ride and truck drives the same as stock to me with no issues.
    Murdoch33 likes this.
  6. Mar 21, 2018 at 7:42 PM
    CAPacificSurfliner
    CAPacificSurfliner Active Member
    William
    Pacific Coast (NorCal & SoCal)
    2017 Cement Tacoma TRD Pro
    Nice ride man. I think I’ll go with that tire size once these puppies wear out. I’m just up the road (relatively speaking) in Marina del Rey. What up!
    09tacohb[QUOTED] and Murdoch33 like this.
  7. Mar 22, 2018 at 2:00 AM
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    I will be running 285/70R17 KO2 in the C rating. If they made the 275/70R17 KO2 in C rating I would buy that size butthe C rated 285 is 5lbs lighter per corner so the truck should handle them a little better I hope. I do have the SSP which will help with the heat hunting.
