what size?
Discussion in 'Wheels & Tires' started by jtaco, May 7, 2008.
  1. May 7, 2008 at 7:44 AM
    jtaco
    jtaco [OP] Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    how do i know if 285 75 16 size tires will fit on my 05 tacoma? i had a 2.5 inch suspension lift put on it ? got some rims on the way that are 16x8, -11 offset and 4" backspacing.
  2. May 14, 2008 at 4:07 PM
    tacodave06
    tacodave06 Active Member
    central valley
    06 dub cab 4x4 3" lift
    3" susp lift. weld wheels w/ mud terrains. mb quart 6x9's in front
    i got pro comp mud terrains 285/75/16 with a three inch revtek lift. looks good and doesnt rub. thats about as big as i can fit tho
  3. May 14, 2008 at 4:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    those tires will fit....but i'm not sure about the rims w/ those tires...i'm thinking ur gonna need at least 4.5" of backspacing...u might have to run some spacers
  4. May 14, 2008 at 4:59 PM
    jtaco
    from what camburg and every company that sells tires and rims tell me , 4 inch backspacing is more clearance from a-arm then 4.5 so why do i need spacers, especially with -11 offset? spacers for what?
    whats ur backspacing and offset tacodave06?
