What soldering iron are you using?
Discussion in 'Technical Chat' started by CantSitStill, Apr 10, 2012.
  1. Apr 10, 2012 at 10:29 AM
    CantSitStill
    CantSitStill [OP] Well-Known Member
    FTR
    CNY
    I need to upgrade from my cheapy cheap Radio Shack 25w soldering iron.
    It just doesn't heat up fast enough, or maybe even enough in general.
    What are you using, or even better, what do you think I should buy?
    Thanks guys.
  2. Apr 10, 2012 at 10:32 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I bought the cheapest, 2 part soldering iron from the local electrical shop. Will try to grab a link... Wish I bought the auto temp ones I have used for ~80-150 though... Mine was ~40.
    Mine is this one, works good but have to adjust the temp every now and then, not the biggest deal but a pain.
    http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UC
    Have used this type before and wish I would have bought this... Used for many projects, from small projects to large stuff
    http://www.amazon.com/Weller-WESD51-Digital-Soldering-Station/dp/B000ARU9PO/ref=pd_cp_hi_0
  3. Apr 10, 2012 at 10:35 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Most of the places I've worked have had Edsyn irons. They seem to be pretty good quality. I've got an adjustable Tenma that I've had for about 10 years or so. It was cheaper than a weller or hakko and has been pretty good.
  4. Apr 10, 2012 at 10:36 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    have you tried a new tip? i have the same one you do and that did the trick for me.
  5. Apr 10, 2012 at 10:40 AM
    CantSitStill
    FTR
    CNY
    Maybe I should try this first!!! Back to the Shack
  6. Apr 10, 2012 at 10:41 AM
    jpneely
    Charleston, SC
    haha i like to start cheap and if that doesnt work then get a new one!
  7. Apr 10, 2012 at 11:46 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  8. Apr 10, 2012 at 5:25 PM
    CantSitStill
    FTR
    CNY
    So, I got a new tip at Radio Shack but I haven't tried it yet since I decided to further my education and bought an electronics learning lab. Just built a circuit to make an LED flash. Now I just need to figure out why it flashes. ImageUploadedByTapatalk1334103911.913339.jpg
    I feel like a little kid!
  9. Apr 10, 2012 at 6:25 PM
    CantSitStill
    FTR
    CNY
    Those soldering stations are pretty cool. That may be the way I go if this new tip doesn't work. I'm all for buying more tool than you need right now and growing into it.
  10. Apr 11, 2012 at 5:27 AM
    afd23a
    The Dynamo of Dixie
    A good iron will make a big difference in the quality of solder joints. I've had a couple real cheap ones (one from Radio Shack) and they just aren't very good at all when compared to a quality iron.
  11. Apr 11, 2012 at 8:09 AM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Capacitor charging and discharging. I think that is what I see on there.
  12. Apr 11, 2012 at 8:12 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    i use one for the shack as well...been using the same one for 65+ clusters on tacomas and ive only kept changing out the tips
  13. Apr 11, 2012 at 6:52 PM
    CantSitStill
    FTR
    CNY
    Hey, thanks! I'm hoping as I get further along, I learn more about the "why"
  14. Apr 11, 2012 at 7:00 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I have one of the new Cold Heat devices. Believe it or not, it works great! And it's cold to the touch in a fraction of a second after you let go of the trigger.
  15. Apr 11, 2012 at 7:10 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
  16. Apr 11, 2012 at 7:19 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i use a gas soldering iron at work. made by power probe. its freakin awesome
  17. Apr 11, 2012 at 7:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Weller.
    40w, 15w, and a small pocket butane for field work.
  18. Apr 12, 2012 at 8:39 AM
    CantSitStill
    FTR
    CNY
    ImageUploadedByTapatalk1334245173.716466.jpgHow about this?
  19. Apr 12, 2012 at 9:03 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    that looks like one of the portable gas ones ;)
  20. Apr 12, 2012 at 9:31 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    Do you know which one? My dad has an older one and says it sucks. I'm desperate for anything that can improve my soldering skills. I've even been practicing by trying to put old broken led flashlights back together. Everything I touch either doesn't stick or looks like I was sweating copper pipes... before it comes loose.:mad:
