What suspension lift for 255/80r17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lilallie, May 31, 2019.
  1. May 31, 2019 at 11:41 PM
    lilallie
    lilallie [OP] Active Member
    2019 Tacoma TRD OR
    New here and Lookin for some guidance.
    I drove my FJ 4x4 to death, great rig. 2008 3.5” sway-away Coil over with 285/70r17.
    and now I have a 2019 Tacoma OR 4door.
    I use my truck often off road in my summer job and for recreation. Rocks, dirt, snow in norther Az.
    Not real high speed off road stuff.
    Because the FJ is so much different than my new truck I need some advise on the
    Suspension.
    I am Not just lookin for a lift. Research so far is kinda pointing me to a Fox suspension but I’m open for ideas.
    I want to get some good clearance but not kill my mpg either so I’m thinkin 255/80r17 or 85r17’s so I’m wondering also the height I will need.
    Thanks for any help.
  2. Jun 1, 2019 at 1:30 AM
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
  3. Jun 1, 2019 at 5:58 AM
    lilallie
    2019 Tacoma TRD OR
    Ok so if I’m reading this right you are recommending the factory suspension TRD pro? That is 2.5” correct.
    Not just using the stock OR suspension.
    I have seen some posts that users are sayin 2.5 is not enough for the 33” height of the 255/80r
  4. Jun 1, 2019 at 5:59 AM
    Billy_trd
    Billy_trd Active Member
    2018 Tacoma TRD OR
    Ome is "old man emu". Oem would be the stock suspension
  5. Jun 1, 2019 at 6:03 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    One of the selling points of 255/80-17’s is you don’t need a lift or any mods (e.g., CMC etc). So keep it stock.
    MattCowsmasher likes this.
  6. Jun 1, 2019 at 6:03 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Depending on your budget and if any plans for armor.
    The Old Man Emu is a great affordable setup
    after that is the big name coilover makers which you seem familiar with.
  7. Jun 1, 2019 at 6:05 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
  8. Jun 1, 2019 at 6:10 AM
    lilallie
    2019 Tacoma TRD OR
  9. Jun 1, 2019 at 6:14 AM
    lilallie
    2019 Tacoma TRD OR
    I have read that.
    But I really am concerned that I’ll need the travel
  10. Jun 1, 2019 at 6:17 AM
    lilallie
    2019 Tacoma TRD OR
  11. Jun 1, 2019 at 6:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    Go with those tires, correct wheels, stock suspension.
    If you find in actual use you need something improved, do it then.
    These trucks can do way more than most think with a better set of tires and a skilled driver.
    Boghog1 and MattCowsmasher like this.
  12. Jun 1, 2019 at 6:21 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Anytime... good luck with your truck. Seems your set on Fox’s they ride great I’ve rode in several Tacoma’s with different setups being stockish to fully armored and all were a plush ride.
  13. Jun 1, 2019 at 7:36 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    If you are concerned with travel then you’ll want to go long travel. Even with aftermarket suspension and UCA you won’t get a huge increase in travel.
    Boghog1 likes this.
  14. Jun 1, 2019 at 8:25 AM
    lilallie
    2019 Tacoma TRD OR
    If I do go with Fox or icon any recommendations for the amount of suspension lift?
    As I mentioned my Job, I’m a wildland firefighter paramedic and often times im hikin the line with my gear but sometimes I’m drivin up a new dozer line fire break road to get where I need to go and smooth the road, if you can call it that is not
    I really appreciate all your all’s help. It’s as ya all know it’s an expensive mod so I’m Hopin I get it right the first time.
    Picking up some new skid plates too
  15. Jun 1, 2019 at 8:51 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I wouldn’t go anymore than 2.5-2.75 past that you run the risk of to much preload and riding like a pogo stick. My icons are set at 2.75 and it’s a wonderful ride considering I’ve got 10ply tires and full armor.
    But those shocks are adjustable to your liking with ride height. Out back you can get a 3 leaf aal for cheap compared to a replacement leafpack since your leafs are still new and have a arch. May need ucas as well all kinds of choices I’m running spc and they have been great.
  16. Jun 1, 2019 at 8:53 AM
    lilallie
    2019 Tacoma TRD OR
    Thanks cowsmasher :)
