What the heck is this noise?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Junkhead, Nov 4, 2020.
  1. Nov 4, 2020 at 8:46 PM
    Junkhead
    Junkhead [OP] TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Hello TW!
    My truck has always done this since new. It only happens on speedbumps or when offroad. It hapens once, then doesnt happen again for a while. Takes like 10- 15 mins for it to happen again. Its on drivers side 100% and i can almost feel it with my feet.
    My ranger did the same drivers side clunk for 7 years and i never had an issue. Im just curious what it is and will bring it up to my dealer when i will come in for the new fuel pump.
    Its not brake slap 100%. Any ideas?
    Body mount?
    Sorry for wind noise.
    Edit: its the loud clunk/click at the end of the video.
    https://youtu.be/5shCfRHJeGg
  2. Nov 4, 2020 at 10:48 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Try it again without wind noise? Is it a clack or a clunk? Mine did it on stock OR suspension but went away after fox suspension. Could've been the sway bar spacer too though.
    Junkhead[OP] likes this.
  3. Nov 5, 2020 at 6:23 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    I will record again when i will get to drive my truck on the weekend. Its definitely a clunk. Best way to describe is 2 pots getting banged.
  4. Nov 5, 2020 at 6:24 AM
    Bishop84
    Bishop84 Well-Known Member
    I would snug up all skid plate bolts and check the lower control arm bolts for looseness.
    Fullsendcf and Junkhead[OP] like this.
  5. Nov 5, 2020 at 6:29 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Loud click or clunk at the end right? Have you replaced the front body mount yet?
  6. Nov 5, 2020 at 6:47 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    yes at the very end there, no i havent replaced body mount yet. They could come defective from the factory?
  7. Nov 5, 2020 at 6:47 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    I will take a look, thank you.
  8. Nov 5, 2020 at 6:50 AM
    Lt. Dangle
    Ohio
    Oh yeah. Search for body mount issues here. Now in fairness, it's usually more of a squeak, but it can clunk if it gets bound up metal to metal. I replaced mine with some Energy bushings if I recall correctly.
    https://www.tacomaworld.com/threads...at-noise-may-not-be-your-leaf-springs.464993/
  9. Nov 5, 2020 at 7:10 AM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    I had this same noise. If the body mount doesn't fix it. Is your front shock/coil assembly.
    Fought this with the dealer for about 20K. They replaced the front shocks/coils and didn't hear it again.
    MannyS and Junkhead[OP] like this.
  10. Nov 5, 2020 at 7:17 AM
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    My truck has done the same thing since almost new. Replaced front body mounts it didn't go away. Dealer blames it on cracked sheet metal above the body mount. Been waiting for more people to get this issue/find a solution before I spend the 2grand at a body shop to fix my cracks. Keep us posted
  11. Nov 5, 2020 at 7:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Does it happen when cornering hard?
    Junkhead[QUOTED][OP] likes this.
  12. Nov 5, 2020 at 7:22 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Lol that's your shocks bottoming out bc you're hitting that speed bump too fast
    wahoobie likes this.
  13. Nov 5, 2020 at 7:24 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Random thought here that is far less likely:
    Have you added anything new up front? When installed my LEDs, I heard this noise and thought for sure that I had the bushing issue. Even ordered them from Amazon (before cancelling because I jumped the gun). Turns out, I had positioned one of the LED drivers in such a place that it fell and was banging against the bumper over larger bumps. Tucked it up better and it hasn't been an issue.
    Can you recreate the noise by cycling the suspension when not moving?
  14. Nov 5, 2020 at 7:26 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Negative. I was going maybe 10 mph.
    RedWings44 likes this.
  15. Nov 5, 2020 at 7:27 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    No, i have only noticed it when going over speedbumps or when on bumpy roads off road.
    tonered[QUOTED] likes this.
  16. Nov 5, 2020 at 7:31 AM
    Taco_Coma
    South NJ
    2018 DCSB SR5
    wahoobie and Kerbouchard! like this.
  17. Nov 5, 2020 at 7:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cool. I will hear my pads shifting in the calipers from time to time. I definitely know that the calipers are fully backing off.
  18. Nov 5, 2020 at 7:55 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    His sound is the same as the one I had. Said it once, Ill say it again. It was after they replaced the front strut/coil assembly it was no longer an issue.
    Taco_Coma[QUOTED] likes this.
  19. Nov 5, 2020 at 7:59 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
  20. Nov 5, 2020 at 8:10 AM
    EvergreenOffroad
    EvergreenOffroad Well-Known Member
    Jacob
    Auburn, Wa
    2018 TRD OFF-ROAD
    I had a similar sound and it was my front stock skidplate hitting on another piece of metal when I would go over a bump. I just had to bend it a little bit and that fixed it.
