what tire psi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by graphicideas1, Apr 18, 2011.
  1. Apr 18, 2011 at 5:08 PM
    graphicideas1
    graphicideas1 [OP] Member
    illinois
    08 prerunner
    I installed new rims / tires and lift. I have Nitto 285/70 -17 Terra grapplers. What psi should I keep the tires at?
  2. Apr 18, 2011 at 5:10 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What Brock said- Search the site for the chalk line test...Follow those directions and you'll be all set!!
  3. Apr 18, 2011 at 5:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. Apr 18, 2011 at 5:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
  5. Apr 18, 2011 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    But I included a link :cool:
  6. Apr 18, 2011 at 5:13 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Chalk test :cool:
  7. Apr 18, 2011 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :p
  8. Apr 18, 2011 at 5:14 PM
    graphicideas1
    illinois
    08 prerunner
    With these tires on 100's of trucks on this forum I was hopeing for input from other who already have made adjustments
  9. Apr 18, 2011 at 5:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Sooo...Work harder and slower??
  10. Apr 18, 2011 at 5:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can run a basic random PSI if you want, but every truck is going to be different weight wise, so to get the best wear for YOUR truck, the chalk method is the most accurate.
  11. Apr 18, 2011 at 5:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Accurate. :cool:
  12. Apr 18, 2011 at 5:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    100's of trucks aren't loaded the same way yours is loaded in the environment yours is in. And 100's of trucks have worn theirs down and have tires from different times of year/with minor differences in specific compounds.
    You gotta put in the time to make sure you are getting the best wear out of your tires.
  13. Apr 18, 2011 at 5:17 PM
    TexasTacoma37
    Good thinking, in fact with 100s of trucks on here running that size, it's even possible someone has asked this before.
  14. Apr 18, 2011 at 6:39 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    34 psi front
    26 psi rear
