What tires can I run?
Discussion in 'Wheels & Tires' started by Mrgoody86, Apr 19, 2009.
  1. Apr 19, 2009 at 11:10 PM
    Mrgoody86
    Mrgoody86 [OP] Well-Known Member
    Alex
    Lincoln, CA
    2009 Tacoma 4x4, DBL Cab, Sport Edition
    K&N CAI, Custom duel exhaust with jones muffler, Viper Alarm w/ remote start, Cobra radar detector hard wired and mounted above rear view mirror. Leather Arm rest mod, LED cabin light, Redline elite hood struts. Bilstien 5100's all around, front coilover set at 2.5", Toytec aal, and Total Chaos UCA's, Scangauge II, Front Diff Drop kit, Yellow Lamin-X fog light covers, 6K HID conversion Kit for Headlights
    Installing a Ultimate lift kit from toytec this weekend and was wondering what size tire I can run without having to trim the wells. Somebody told me I can run 265/70/17's was wondering if that right if thats cool than cool. Thanks before hand for the input.
  2. Apr 19, 2009 at 11:14 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    how much is the lift? 3?
    im running 285/75R16 and i just had to take the mudflaps off. and i did tho pinch weld mod.. but i dont know if its necessary, just recommended.
  3. Apr 19, 2009 at 11:14 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    265/70/17's may look a tad small, some 275/70/17's would be a little bigger and shouldnt rub at all still. 285's would look the best but a little front trimming would likely be required.
  4. Apr 19, 2009 at 11:20 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    x2, well said! couldn't simplify it any more
  5. Apr 19, 2009 at 11:21 PM
    Mrgoody86
    Alex
    Lincoln, CA
    Awsome! How is the trimming done exactly and would it help it i put on the spidertrax wheel spacers?
  6. Apr 20, 2009 at 9:27 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Spacers would help if you were having UCA rub problems. I think for the wheel rubbing the fenderwell, it would make it worse as the turning arc is larger.
  7. Apr 20, 2009 at 10:48 AM
    RelentlessFab
    Eric
    Sparks, NV
    +1. It depends on if you run the stock wheels, and then if not then it depends on the backspacing on the aftermarket ones. The larger tires with the stock wheels may have UCA contact issues which would need to be remedied by wheel spacers but may lead to some fender rub. If you have aftermarket wheels and get a little bit of fender rub, wheel spacers would just make it worse. If rubbing occurs and needs to be fixed, then these are some of the things that may need to be done:
    -mudflaps removed
    -'bump' in front part of inner fender plastic trimmed off or heated and molded
  8. Apr 20, 2009 at 2:03 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    im running y 285/75s of 16x8 Pro comp 1079.. i forget the BS. but i dont have any UCS problems.
    the only thing you would need to do would be mudflaps and it would help to do pinchweld. its really easy takes about 5 minutes to do all of it.
