What Tires will fit for my Tacoma?
Discussion in 'Wheels & Tires' started by Ponkan, Aug 10, 2019.
  1. Aug 10, 2019 at 10:40 PM
    Ponkan
    Ponkan [OP] Member
    Moose Jaw, SK
    2017 Inferno Orange Tacoma TRD Sport DCLB
    I've been at the forum reading thread by thread about tires t, lots of answer but it doesn't satisfy me. I'm new at this so please be patience with me.
    I have TRD Sport 17 DCLB
    front suspension 5100 with 887 (I have spacer for the taco lean)
    back suspension OEM
    OEM wheel trd sport 17x7.5 +30
    just want to know the size of tires I can use without rubbing or slightly rubbing.
    tires I can fit with little mod too.(cutting a little at my fender)
    thank you for anyone who will reply.
  2. Aug 10, 2019 at 10:46 PM
    Shellshock
    Iowa
    265/70/17 fit easily
    Larger than that typically requires cutting and / or massaging.
    Kwisak likes this.
  3. Aug 10, 2019 at 10:47 PM
    Kwisak
    Kwisak Well-Known Member
    Jon
    Arizona
    2024 Tundra Limited off-road 2018 Inferno Tacoma Off Road MT
    Pro grill Joying radio with wireless car play Hood decal Bed decal Pro skid Pro wheels 285/70/17 Sliders Blackout emblems Pro exhaust Pro intake Painted engine cover Ditch lights Tint Tacoma letters glove box Off-road wether tech inserts Lock box console Blackvue Orange trim Orange inserts Katzskin Weather tech Bed mat Hilift Tire locks Extra switch Rotopax Fox 2.5 fronts with 700lbs Kings Fox 2.0 rears with resi Icon rxt springs Icon Delta UCAs Meso side markers Meso gashole On order —— Avid bed rack SSO bumper Morimoto headlights and fogs Meso map lights and done light
    This or the Pizzia cutters, then you can get into 33. 255/80/17 I think goes no issue.
    tcjacado likes this.
  4. Aug 10, 2019 at 10:47 PM
    tcjacado
    tcjacado Well-Known Member
    255/80/17 will work also I believe
  5. Aug 10, 2019 at 10:49 PM
    Kwisak
    Jon
    Arizona
    Updated mine just as you posted, had to go look at that size again. Honestly I keep wondering if I should have done that with all the freeway I have been getting for work. 200-500 miles a day is a bit crazy but should end soon
    tcjacado[QUOTED] likes this.
  6. Aug 11, 2019 at 6:36 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Yep
    Yep
    Like those guys mentioned, a bunch of us have 255/85/16s and it’s been a great way to get 33s on a stock 3rd Gen suspension (255/80/17 is the same total size but more wheel / less meat on the tires)…..with no trimming / chopping whatsoever.....and the spare tire fits under a short bed without having to move the bracket (you might have to do some finagling with your long bed, a few have made it work)
    https://www.tacomaworld.com/threads/put-255-85-16s-on-stock-or-wheels-and-suspension.491079/
    Kwisak[QUOTED] likes this.
  7. Aug 11, 2019 at 7:28 AM
    Kwisak
    Jon
    Arizona
    This is a important point, I went 285/70:17 and fitting the spare tire was a pain in the ass. You have to bend brackets. Also the 285 sucks on freeway, wasn’t an issue when I got it but recently work has me driving a lot
  8. Aug 11, 2019 at 10:54 AM
    Ponkan
    Ponkan [OP] Member
    Moose Jaw, SK
    what do you mean by Pizza cutter, is it how the tire looks like? 255/80/17 fits with out trimming? thanks for he respond.
  9. Aug 11, 2019 at 11:00 AM
    ETsemaj
    ETsemaj @Koditten Pirate Radio member #001
    James
    Cape Canveral, FL
    2018 Cement Tacoma Off Road
    speaker and tweater upgrade DMM phone mount and a large wishlist
    others might be able to better explain, but from what i have read, pizza cutters are large but thin tires. so they arnt as wide as normal tires and will require less to work to fit since they wont reach as far out when fully turned. again, others might be able to better explain.
    Ponkan[QUOTED][OP] likes this.
  10. Aug 11, 2019 at 11:01 AM
    Ponkan
    Ponkan [OP] Member
    Moose Jaw, SK
    thank you for your respond. will keep that in mind. does it effect with the lift i at the front?
  11. Aug 11, 2019 at 11:04 AM
    Ponkan
    Ponkan [OP] Member
    Moose Jaw, SK
    oh men. I usually drive 6hrs at highway. is it really that bad? how about at winter(if you ever tried).
  12. Aug 11, 2019 at 11:33 AM
    Kwisak
    Jon
    Arizona
    Thinner taller tires lovingly called Pizzia cutter because they are 33 but thinner then most 33s. Arguments all over but they seem liked by those that have them, just a term for the look although I think they look good. Maybe minor trim or cut but last 3 people I saw said no trim or cutting with those.
  13. Aug 11, 2019 at 11:36 AM
    Kwisak
    Jon
    Arizona
    So I did 2.5 lift and out on ko2 285/70/17 with higher plys for tougher off-road use. Yes the ride is worse. This is with fox and icon gear. I drive a good bit of freeway and the control of the car is worse and now there is vibration, I’m suppose to be transitions back closer to home so I’m keeping it but if I had to drive with the current setup long drives all the time I would have keptstock. That said I did a 13 hour drive up to a few national parks a few weeks back and it was fine, just not as comfortable as the stock setup which I really liked. Again this is with new suspension, 2.5 lift, and 285 tires. Sorry no experience in winter yet. Put them on start of summer and we haven’t gotten anything but rain. All that said I have a bumper coming that I think may help as I have stiffer spring on it currently to prepare for the bumper.
  14. Aug 12, 2019 at 6:22 PM
    Ponkan
    Ponkan [OP] Member
    Moose Jaw, SK
    hey guy how about 255/75r17 will it still fit?
