What to buy : SR5 or TRD ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LarryB, Mar 17, 2014.
  1. Mar 17, 2014 at 5:54 AM
    LarryB
    LarryB [OP] Member
    Northern QC Canada
    TRD-SR5
    Hey guys,
    I'm shopping to buy a Tacoma (2010 to 2012) within the next few weeks (by spring anyway) and I have to make a decision.
    I have a 18.5 ft Shadow Cruiser travel trailer (only 2500 lbs empty). Presently I pull it with my 2002 Sienna. The old Sienna now has 414,000 kms (257,000 miles) It gets good gas mileage alone but hook up the trailer and I only get 250 kms or 150 miles per tank.
    So now I've decided to buy a truck for work that can also pull my trailer across the country with the least gas. Now I only pull my trailer around 2 or 3 times a year but it's usually a good distance ( here to Florida - 3 days; here to fishing camp 3 hours; here to Toronto 9 hours ). The rest of the time I'll be running basicly empty. I had decided that the SR5 was the choice since it is partially boosted for towing yet wasn't geared down like the TRD (hence - better gas mileage, right?), but then I stumbled onto this forum and decided to throw the question out to a bunch of TACOMA OWNERS...
    So guys... what's the decision ? SR5 or TRD ?
  2. Mar 17, 2014 at 5:59 AM
    Large
    Large Red
    You might not even be happy with the MPG in the truck's stock form :laugh:, Whenever I tow a trailer on the highway I struggle to get 10 mpg.
  3. Mar 17, 2014 at 6:14 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You're going to need to define what you mean by ^^^ this. The SR5 and the TRD models all have the same engine, transmission and final drive gearing. For towing, the only difference is if you have the tow package installed or not.
  4. Mar 17, 2014 at 6:18 AM
    LarryB
    LarryB [OP] Member
    Northern QC Canada
    TRD-SR5
    According to the Toyota web site, the TRD (which always has the tow package if I understand correctly) can pull 6500 lbs (900 lbs more than the other models) and THEY say it gets less mpg than the other models. Even with the tow package the SR5 is listed with less towing capacity and better mpg.
    Hey, I'm no mechanic, I've just been shopping and reading for a month.
  5. Mar 17, 2014 at 6:31 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I wouldn't put too much credence in their listing of fuel mileage. A lot of people aren't getting the claimed mpgs anyway.
  6. Mar 17, 2014 at 6:43 AM
    LarryB
    LarryB [OP] Member
    Northern QC Canada
    TRD-SR5
    Ok here's my dilema :
    I would drive around in my v6 Sienna with my ultra light travel trailer and get 10 - 12 mpg.
    And I would meet all kinds of big V8 pick-ups pulling 35 ft 5th-wheelers and they would supposedly be getting 10 - 15 mpg - in totally awesome comfort !
    So I figured that if I get a slightly bigger motor which is also better adapted to towing I should get 15mpg and up with my light little travel trailer - or are the gas-gods out to get me?
  7. Mar 17, 2014 at 6:46 AM
    LarryB
    LarryB [OP] Member
    Northern QC Canada
    TRD-SR5
    Nice truck! I need 4 doors too - still have kids. What kind of mpg do YOU get ?
  8. Mar 17, 2014 at 6:51 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Not all TRD packaged trucks come with the tow package. It is still an option you can add or leave off from the TRD package.
  9. Mar 17, 2014 at 6:52 AM
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    I have the 2014 SR5. I don't get the claimed mpg running stock with no load or trailer. If gas mileage is important, then you may want to consider something other than Tacoma.
  10. Mar 17, 2014 at 6:58 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You might want to verify the actual contents of the packages with another source. The points below are coming from past looks and posts on this board:
    o The V6 auto milage is the same for prerunner and 4x4
    o the V6 manual milage is a bit lower
    o the 4 cyl milage is higher, but I don't think you can get a 4 cyl 4x4
    o I don't think the tow package is standard on the TRDs, unless that has changed
    o I had thought that the SR5 and TRD tow ratings were the same, only difference is whether the tow package was installed or not.
    o as far as tow ratings and milage is concerned, make sure that the numbers you are getting are for the engine/tranny, and base/prerunner/4x4 you want, you may be getting some 4-cyl numbers and model differences
    Again, I have not looked too close at the 14 models and contents though.
  11. Mar 17, 2014 at 7:02 AM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    The mileage is listed as lower for the TRD because you can't get a single cab TRD package equipped truck. So, those numbers aren't an apples-to-apples comparison. If you look at the double cabs, 4x4, PreRunner, TRD, SR5, the mileage is the same for all of them. I have a 4x4 DCSB V6 SR5 and get the exact mileage listed on the EPA estimates.
  12. Mar 17, 2014 at 7:15 AM
    LarryB
    LarryB [OP] Member
    Northern QC Canada
    TRD-SR5
    Just so everyone knows, I will definitely be getting a double-cab (kids) and definitely a 4X4.
    With that in mind : is there no difference in gas economy between an SR5 and a TRD with the same tow-package options ?
  13. Mar 17, 2014 at 7:17 AM
    Carlemil
    Carlemil Member
    Ontario
    12 DC V6 SR5
    I was in the same situation two years ago and decided for SR5. The tow package is the same for both but TRD comes in Canada only with 5-ft bed. Dealer would charge me about $2k more for TRD and I was really interested only in two features from that option package (got one installed by dealer and one installed lately myself).
    As per mpg, you can do research on fuelly.com to to get an idea what people are getting on other trucks.
  14. Mar 17, 2014 at 7:18 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
  15. Mar 17, 2014 at 7:19 AM
    aubi1414
    Justin
    Pensacola, FL
    I have a 2010 TRD Sport 4x4 with larger tires and a slight lift and get 17ish around town
  16. Mar 17, 2014 at 7:23 AM
    10splaya22
    10splaya22 Well-Known Member
    Drew
    Blacksburg, Va
    2012 TRD Sport 4x4 DCSB
    Nope it's the exact same.
  17. Mar 17, 2014 at 7:24 AM
    LarryB
    LarryB [OP] Member
    Northern QC Canada
    TRD-SR5
    If I get that I'll be perfectly happy! That's about what I get with my old Sienna.
    Do you tow anything? If so, what does it do to your mpg?
  18. Mar 17, 2014 at 7:31 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    BTW, asking for people about their milage without asking about their driving patterns is setting yourself up for bad info. My DCSB SR5 can vary between 15 and 21 depending on the driving I do on that tank.
  19. Mar 17, 2014 at 7:51 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    What does that mean?
    And mileage is all over the place depending on driver habits, location, winter/real gas, as well as if the trucks even broken in.
    Mileage gets better for those of u worried about mileage with brand new trucks.
    Much does have to do with the peanut behind the wheel and how he handles the gas pedal.
    I can get 21ish......... With lift, thru canyons, with 500lbs worth of people, another hundo in tools and toolbox, 30lbs in luggage, and probably around 100 more HP than a stock 4.0 Tacoma.
    Or I can destroy a tank of gas with no passengers, and no luggage in no time depending on how much fun I'm having.
  20. Mar 17, 2014 at 7:54 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    If you're buying on mileage alone these trucks are not the best and get about the same as the full size trucks with bigger engines.
    Several people report better mileage on the highway with the supercharger and automatic trans due to less downshifting on hills when towing.
