what to do about flares?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bryman1645, Apr 7, 2011.
  1. Apr 7, 2011 at 10:52 AM
    bryman1645
    bryman1645 [OP] Active Member
    Tucson, Arizona
    99 4x4 SR5 TRD
    i have a 99 tacoma trd sr5 4x4 and i love it emmensely. the only qualm i have with the extrior is that the oem fender flares are scratched and the white fiberglass(?) is showing through. i would prefer to buy new ones, that is if i wasnt a starving college student! is there an easy way to paint the originals? or are there cheap ones out there on the market? im trying to build the truck on a budget and slowly am getting there.
    thank you for you help.
  2. Apr 7, 2011 at 10:54 AM
    Camo23
    Camo23 Well-Known Member
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    i personally took my flares off...
  3. Apr 7, 2011 at 10:55 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    there are ~6 10mm bolts holding each one on. take those off and you can clean 'em and hit 'em with some flat black spray paint and they'll look good as new. this is one of the first things i did when I picked up my 2000. no issues after 1.5 years -- they still look great!
  4. Apr 7, 2011 at 10:59 AM
    bryman1645
    Tucson, Arizona
    99 4x4 SR5 TRD
    thanks! was there any specific brand of paint you used or should just any flat black primer work? also, did you have to sand them first?
  5. Apr 7, 2011 at 11:00 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    If you want to bulletproof them you can coat them with bedliner covering. Someone here did that a while back and really liked it, can't remember who though.
  6. Apr 7, 2011 at 12:00 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    i cleaned them really well, but they didn't need any sanding in my case. i used a few coats of rustoleum flat black paint, no primer. pretty easy job.
  7. Apr 7, 2011 at 1:15 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Plasti dip spray works great too! Very durable and you can peel it off if you dont like it.
  8. Apr 7, 2011 at 1:17 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    u fenderless whore
  9. Apr 8, 2011 at 1:03 PM
    bryman1645
    Tucson, Arizona
    99 4x4 SR5 TRD
    thanks so much for all your help:)
