What to look for when buy used LT kit?
Discussion in 'Long Travel Suspension' started by Sunner, Jan 29, 2012.
  1. Jan 29, 2012 at 10:12 AM
    Sunner
    Sunner [OP] Well-Known Member
    So I am stuck on going LT again after finally making a desicion on the MT setup I wanted. I am considering buying used when I am ready to, I haven't looked too hard for used kits for the 2nd Gen but they seem rare. If I do find one, what are the things that I need to look out for to make sure Im buying a decent kit. I am assuming that the Uppers and Lowers are pretty strong in most kits and I dont need worry about them being bent. What are some big wear or troubled spots on kits that I should pay attention to. I'll probably replace all the bushings and limit straps and what not, really just looking to score uppers and lowers, the steering extender things, the longer axle to retain 4x4. My preference in kit so far starts with TC>AP>AP 2">TC 2". Thanks guys!
  2. Jan 29, 2012 at 12:05 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Not really much of an issue if the suspension was built right. Mainly check the welded areas for cracks and even the LCA's for bends where there shouldn't be.
    I must warn you though, if you LT the front, you pretty much have to LT the rear.
  3. Jan 29, 2012 at 12:45 PM
    Sunner
    Yeah I know that you if you LT the front, there is no way you can use it to its full potential if the rear cant keep up, If I do LT the front I will do the rear for sure but it'll be down the road further, cant afford to do it all at once.
    Ive done all my research on LT already, was just looking for what I should look for in a used kit. I plan on building a LT truck for now, it will just be in stages, front first. Heck I might even drop back to MT if I can see a few of the trucks in action, I saw your post in the MTBS thread that you were pretty impressed with how the MT trucks did at superstition.
  4. Jan 29, 2012 at 1:27 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    here you go :http://youtu.be/Y1HlUyCvBJg ! stock arms up front , defined bolt-in SUA kit in the rear and some quality shocks = one badass stock width truck.
  5. Jan 29, 2012 at 1:32 PM
    Sunner
  6. Jan 29, 2012 at 1:37 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
  7. Jan 29, 2012 at 1:45 PM
    Sunner
  8. Jan 29, 2012 at 2:35 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    love this truck!
  9. Jan 29, 2012 at 10:23 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    do mid travel front with lt rear.
  10. Jan 29, 2012 at 10:25 PM
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    i want those damn tires!
  11. Jan 30, 2012 at 9:21 AM
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    i bought my kit used from a buddy so that sorta helps buying from a trusted friend.
    I would look for any cracks along welds, make sure the bushings in the LCA and UCA arent warped or messed up if it wasnt properly lubed. Check for any play in both the uniballs. Check the portion of the UCA that holds the unbiball and see if there arent any major dents due to someone not properly limit strapping the suspension. Make sure the L & R UCA and LCA are symmetrical. Cant really think of anything else
  12. Jan 30, 2012 at 9:27 AM
    Sunner
    Thats about what I was thinking. I have never seen a LT kit up close that is not on a truck, Ill try and see if I can get my hands on a new one just to see how it should feel. Thanks for the tips guys.
  13. Jan 30, 2012 at 9:50 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if you are getting a camburg kit make sure the uniballs on the lower arms arent shot.
  14. Jan 30, 2012 at 9:54 AM
    Sunner
    Wont be going the Camburg route, they dont all you to retain 4x4 right?
  15. Jan 30, 2012 at 10:00 AM
    97yota4wd
    Eric
    Mesa, AZ
    why not camburg? and yeah you can keep 4x4 with camburg
  16. Jan 30, 2012 at 10:04 AM
    Sunner
    Oh ok, I thought that you cannot have 4x4 with Camburg, must be Engage than. That was the only thing that was ruling them out for me. But also I think that the TC kits comes with more included than the Camburg kit.
  17. Jan 30, 2012 at 10:07 AM
    97yota4wd
    Eric
    Mesa, AZ
    the TC kits and the camburg kits come with the same stuff and cost close to the same.
    engage actually has 4x4 axels for the 2nd gens now too by the way.
  18. Jan 30, 2012 at 10:10 AM
    Sunner
    Wow ok, well looks like it has been a while since I have looked up these kits. Last I checked the Camburg kit doesnt come with limit straps and bump stops which I believe I had seen included in the TC kit, Ill have to double check everything now though. Thanks for that info. I have considered just going LT in the rear now and a solid MT in the front. I dont know much about rear yet so Ill be looking into it. Thanks for the tips guys.
  19. Jan 30, 2012 at 11:50 AM
    97yota4wd
    Eric
    Mesa, AZ
    a mid travel front and LT rear is the best/cheapest option personally.
    and they dont come with bumps but you can modify your stock ones to work or buy hydro bumps which i recommend.
    both kits come with the same thing.
    camburg- $2895
    • Upper and lower uni-ball A-arms
    • lower Uni-ball spindle adapter
    • brake lines
    • limit straps
    • steering extensions, coilover mounts
    • hardware.
    • Heim Steering upgrade $495.00
    • Heim joint upper arm pivot upgrade $249.00
    total chaos- price?? close to camburg
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Parts Included:
    [/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Upper A-Arms W/ Bushings, Uniballs, & Clips[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Lower A-Arms W/ Bushings, Shock Mounts[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Tie-Rod Extensions[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Tapered Spindle Sleeves[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Braided Stainless Brake Lines D.O.T. Approved[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Bolt-on Upper Shock Mounts - Specify Brand[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Hardware[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Adjustable Limit Straps & Mounts[/FONT][FONT=Arial, Helvetica, Geneva, Swiss, SunSans-Regular]Plated Upper A-Arm End Washers[/FONT][FONT=Arial, Helvetica, Geneva, Swiss, SunSans-Regular]Weld-on Bump Stop Spacers[/FONT][FONT=Arial, Helvetica, Geneva, Swiss, SunSans-Regular]Lower Uniball Conversion[/FONT]
