what type of oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by robpad, Aug 2, 2007.
  1. Aug 2, 2007 at 12:14 PM
    robpad
    robpad [OP] Member
    what type of oil do you use in your taco? is it ok to change from regular oil to synthetic?
  2. Aug 2, 2007 at 12:26 PM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    Not a bad idea to do. I just switched mine to Mobil 1 on the first oil change.
  3. Aug 2, 2007 at 2:50 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Yes, should be OK.
  4. Aug 2, 2007 at 2:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    BTW, I use Amsoil, Pennzoil Platinum or Mobil 1.
  5. Aug 3, 2007 at 5:29 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Ditto. Although I started on Castrol Full Synthetic
  6. Aug 3, 2007 at 5:48 AM
    Bfmco7
    Bfmco7 Well-Known Member
    I use the recommended weight Mobile 1 synthetic oil as well. I have always heard good things and it seems to have proven itself. Little pricy but that is all I will ever run in my truck.
  7. Aug 3, 2007 at 5:53 AM
    isusww
    isusww Well-Known Member
    Amsoil here.
  8. Aug 3, 2007 at 5:56 AM
    Bfmco7
    Amsoil is SSOO high dollar. Do you really think that is is that spectacular of an oil compared to all other brands of synthetic. Honestly...
  9. Aug 3, 2007 at 1:15 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    how miles you run on synthetic before you change the oil?
  10. Aug 3, 2007 at 1:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    stick with 5000 miles on synthetic.
  11. Aug 3, 2007 at 1:42 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I run roughly 5000 miles on synthetic (+/-500)
  12. Aug 3, 2007 at 8:41 PM
    Taco95
    Taco95 Active Member
    straight 50. ha ha.
    cheaper than amsoil, does the same thing.
    I'm kiddin! Amsoil is what i run in my Crf450 and i dont find the need to run that expensive of oil in a 4 cylinder tacoma ha ha thats stupid if you asked me, just find some 20 50 or 10 40 at autozone dump it in and go.
  13. Aug 4, 2007 at 5:40 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    True. On your 95' 2.7L that engine can take just about anything.
    However the new 4.0L and 2.7L engines with VVTi are made to much tighter tolerances. They require a thinner oil to correctly lube throught the entire engine. 10w40 and 20w50 are not recommended oils for the 05+ Tacomas. I believe the recommended oil is 5w30.
    As for Amsoil, I used Amsoil on my 94' Suburban 4X2 w/ 350ci V8. I saw improvements in gas mileage and the engine ran well over 200,000 miles without any major work. If I had a local Amsoil dealer and the time to change my own oil, I would do it again.
  14. Aug 4, 2007 at 9:43 AM
    tazinfo
    tazinfo New Member
    Amsiol here also, along with Amsoil filter in an 05 extended cab 56 speed. Did see a small improvement in gas mileage. Change it 3-5K miles even though it's rated at 10K miles. Would like to switch the tran and rear to Amsoil but don't have the time or tools to do it.
  15. Aug 5, 2007 at 3:00 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have ran mobil 1 in the 2 tacos I have I have a 95 with 188,000 on it and a n 04 with 54,000 and I have had no problems with either one and I go 7,500 miles at 5,000 it is not even dirty yet maybe thats too long but I have been doing it for so long I think its ok I have a hard time finding ams where I live unless I find it on e-bay but thats just my 2 cents :D
  16. Aug 23, 2007 at 5:28 AM
    FRiZzO
    FRiZzO New Member
    2005 Tacoma Access Cab, Super White, TRD Off Road package
    2005 Tacoma Access Cab, Super White, TRD Off Road package, Production Date:07/01/05, Model Code:UU42NP CA //// Viper 791xv Alarm/Remote Start / Panasonic CQ-C5310U // K&N Intake with AEM Dryfilter // TRD Exhaust
    Mobil 1 isn't what it use to be. I'm not going to say its worse then what it was before. Here's a link and you can draw your own conclusion. I personally use German Castrol Syntec 0w30 also known as GC. Anyway here's the link with info in regards to Mobil 1 changing.
    http://forums.evolutionm.net/showthread.php?t=232827
  17. Aug 24, 2007 at 6:30 AM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    well I guess its back to ams for me too or royal purple thanks for that info :(
  18. Aug 24, 2007 at 10:03 AM
    Bfmco7
    Dont worry about that stuff man, everyone has their own opinion about things. If you have been using mobile continue to use it... I have never heard one person say a bad thing about mobile till now. Its all he said she said. Just check out the facts.
  19. Aug 24, 2007 at 11:03 AM
    FRiZzO
    FRiZzO New Member
    The facts are in an oil analysis. Every engine likes a different kind of oil better then the others. The best place for real world info is to start reading the forums over at bobistheoilguy.com that is , the place to go on this subject.
  20. Aug 24, 2007 at 12:49 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    yea screw it Ill just stay with mobil 1 like ill keep it 200,000 miles anyway :D
