what ucas for 6 inch drop bracket lift? and do they help with the wandering?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 75thrangertaco, May 23, 2010.
  1. May 23, 2010 at 8:53 AM
    75thrangertaco
    75thrangertaco [OP] Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    i was needing some oppinions on what upper control arms you guys with 6 inch lifts are running. and does it really help with the wandering issues ? my front end is tight but my taco is all over the road. i read the sticky about lift kits ..and it said ucas would correct this. i have priced light racing at 450, total chaos with the heim joints for 950 wow, and all pro for 650. i dont mind spending the money to make it right just dont want to waste bux on somthing that wont help. im running a procomp 6 inch drop bracket, co, and 305/55/20 tires @ 35 psi.also if anyone has a set for sale let me know
  2. May 23, 2010 at 9:23 AM
    06stex
    06stex Well-Known Member
    Alex
    Corpus Christi, Texas 361
    06' TRD 6" Fabtech..limo tint
    6 inch Fabtech, Dirt Logic 2.5 coilovers, Light Racing UCAs 17x9 XD spy, 305 65 17 Extreme ATs, Limo all around, Kicker speakers,Kicker L5 10 inch sub, 400 watt kicker mono amp In dash Pioneer with Ipod cable, Flowmaster 50, bedmat, toolbox, K N Filter, cheapo seat covers, 6000k HIDs upfront, bhlm,DDM 5000K fogs, tailgate mod, and many more to come.
    Good question, i was wondering the same thing. Im in need of some UCAs as well. Was really considering the LR UCAs, they seem to be working for everyone else. Interested in what is to be said also.
    Not to hijack the thread but im interested in some UCAs as well and if anyone has some good used ones for sale PM me too. Thanks
  3. May 23, 2010 at 10:07 AM
    75thrangertaco
    charles
    casper wyoming
    what are lr ucas
  4. May 23, 2010 at 10:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Light Racing.
  5. May 23, 2010 at 10:10 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Are you sure its not the wind at highway speeds, mine gets blown around pretty good in the wind and sometimes it gets shakey
  6. May 23, 2010 at 11:21 AM
    75thrangertaco
    charles
    casper wyoming
    no it does that too but even in town it wants to go with the road all the time. just all over depending on the surface
  7. May 23, 2010 at 11:35 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    i have the same lift and i dont have wandering problems at all. im running nitto trail grapplers in 295 70 17. have you had your alignment and camber checked?
  8. Aug 29, 2010 at 10:56 PM
    TBK224
    TBK224 ~THE LIGHT GUY~ Vendor
    Tim
    Phoenix, AZ
    BADASS TACO
    6" Pro Comp Stage One Lift Kit and 35" Toyo Open Country M/T's riding on 18" XD Addict Wheels
    I have a 6" Pro Comp lift with 35"x12.50"x18" Toyo Open Country Mud Terrains and it does the same thing. Ive had 3 different shops try to align it and they all say they cant bring the caster into spec. My truck wanders quite a bit. It gets real bad on rough roads. Maybe we need to get a group buy together for the guys who need UCA's. Can anyone make this happen??? lol
  9. Aug 29, 2010 at 11:04 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Get the LR UCA's and have them set your caster up at about 3* (It is higher than the factory specs) but your tires are bigger then the factory tires.;)
    My truck was solid as a rock at 3* but I had to lower it to pass Recon here in Hawaii. I have it set at 2.7* and on rough surfaces over 65 mph it wanders slightly. When I have the time I will take my truck in and have my Caster put back up to 3.0*.
    Funny how just .3* can make a difference.
    LR UCA's work the best for the Fabtech set up because for some reason?? Fabtech makes the spindle 1" shorter then it should be.:mad:
    Good Luck guys!:headbang:
  10. May 17, 2011 at 9:41 PM
    dvd0020
    dvd0020 Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
    Sorry to bring back an old thread. Is there a separate LR UCA for the 6" lift like the TC ones?
  11. Aug 12, 2011 at 2:43 PM
    KingofRedwood
    KingofRedwood Member
    Cuong
    Castro Valley
    2011 Tacoma 4x4 TrdSport
  12. Nov 30, 2011 at 7:16 AM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    I have heard dynabeads help with alignment. I have them in my 33s. Everything seems tiptop...
  13. Nov 30, 2011 at 7:22 AM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    With a 6 inch lift a lot of you guys are running a 33-35+ inch tire. Those wider tires tend to follow grooves and patterns on rough/textured roads more than narrower ones. If (big "if") your alignment is okay, then the tires themselves may be contributing to the wandering.
