What would be a better choice first?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TRDsport, Nov 28, 2007.
  1. Nov 28, 2007 at 2:23 PM
    07TRDsport
    07TRDsport [OP] Carolina Alliance
    id like to know what would give me better milage and horsepower...
    I found a AFE magnum intake for $330
    oooor
    The JBA headers for $349
    which should i buy first... or any other brands you think are betteR?
  2. Nov 28, 2007 at 3:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the afe is a pretty good set-up i hear, just not so sure for $330. i also hear that the jba headers arent really worth the money, and the doug thorley headers are good. no experience myself with any of these, just what i hear.
    probably, the best "bang for your buck" would be to go with urd's tcai and maf calibrator. a little on the expensive side, but awesome results i hear. send a pm to pb2themax, as he has this setup, and see what he has to say about it.
  3. Nov 28, 2007 at 8:50 PM
    morcheez
    morcheez Well-Known Member
    San Antonio
    05 XRunner BSP
    A BUNCH
  4. Nov 29, 2007 at 4:49 PM
    07TRDsport
    do they take out the cats? may i ask why you think they'd be better than the jba's?
  5. Nov 29, 2007 at 5:03 PM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    i heard the jba's don't have a very good fit, but i haven't tried them so i don't know for sure. the CAI will give you more power and gas mileage than the headers would when used with a stock intake system, so get the CAI first and go from there. i'd also do a cat-back exhaust before the headers, and i removed the rear 2 converters from my V6 and it gave me a little bump in throttle response and power, or it felt like it did anyway. the shorter the exhaust system the better, if you want to copy off of my side exhast feel free . i wouldn't pull off all 4 converters, reason being you still need some backpressure on a naturally aspirated engine, plus the removal of the first 2 converters will present the need for a CEL eliminator. the 4 o2 sensors are just before and after the first 2 cats, so removal of the 2nd pair for me created no other issues
  6. Nov 29, 2007 at 5:32 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the ones on the c2c site say that they remove the front 2 cats and will throw a CEL
  7. Nov 29, 2007 at 5:47 PM
    TuRDTACO
    joliet, il
    you can always try using spark plug non-foulers to fix the CEL lights, they have worked on every car of mine that needed them
  8. Nov 29, 2007 at 6:30 PM
    The_Hodge
    SC
    i'd get the doug thorley headers if i were getting any...just based on word of mouth reviews
  9. Nov 29, 2007 at 6:44 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    The JBA's require welding. The DT headers are bolt it and remove 2 of your 4 cats.
    I've been very happy so far with my URD intake. I'm about to also install the URD MAF calibration unit which is supposed to further help out.
  10. Nov 29, 2007 at 9:00 PM
    TuRDTACO
    joliet, il
    i want an intake soon but i don't know which way i'll end up going, i've heard good things about the k&n one too and it's way cheaper
  11. Nov 29, 2007 at 9:07 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm not a big fan of the oiled filters. I've heard too much about the oil in the filter foiling the MAF sensor. The URD has a dry filter.
  12. Nov 29, 2007 at 9:10 PM
    TuRDTACO
    joliet, il
    yea i've heard that a few times but i've also talked to a couple people that never had a problem with it, so i dunno what way to go. kind of the same issue with front spacers, i need them now that the TSB was done
