What would be the best lift to fit 33" tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huntacoma96, Sep 6, 2012.
  1. Sep 6, 2012 at 7:45 PM
    Huntacoma96
    Huntacoma96 [OP] Member
    Hunter
    Tennessee
    White 01 Toyota Tacoma SR5 v6
    2" lift, all pro rear bumper, Rock sliders, wheels, exhaust, blacked out badges, HID's, Clear corner lights, bed rail, K&N CAI, tinted windows
    Im new to TC and was wondering what would be the best lift to fit 33" tires on my 1st gen double cab? I think it already has a 2" block lift and its terrible
  2. Sep 6, 2012 at 7:50 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I have 2 inches under the front of mine with 285s, I think it's fine. I'm about to go to 33s with 3 inches all the way around. 3 will look really good.
  3. Sep 6, 2012 at 7:51 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
  4. Sep 6, 2012 at 7:54 PM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    3 inch lift should be fine. not sure what kind or if itll need any trimming. lets just say i can basically run 32's stock on my 04 dbl cab trd and they only rub full turn. i think 3 inch with 33's is fine and most kits say they should clear 33's and sometimes they say with trimming
  5. Sep 6, 2012 at 8:00 PM
    Huntacoma96
    Hunter
    Tennessee
    Well I was thinking about getting the ome 3" lift with 881 coils or should i get 883's?
  6. Sep 6, 2012 at 8:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :laughing:
    881s won't give you 3'' of lift haha
    only 3'' lift coil is Eibachs
    882s with the trim spacer give ya close to 3'' tho.
    and i hope your ready to cut and bang the truck a bit to make them fit regardless of how much lift you have.
  7. Sep 6, 2012 at 8:18 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Yep, i have 5100s in the middle setting with my 881s and have a 3" lift but rubbed like crazy once i got the tires on. I had to trim the chrome part on the stock bumper, the plastic on the bottom part of the bumper, pinch weld, and the plastic that surrounds the wheel well. Doesnt matter how much lift especially if your offroading and stuffing them in the wheel wells
  8. Sep 6, 2012 at 8:20 PM
    Rebel Taco 22
    This
  9. Sep 6, 2012 at 8:21 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Your Gona need to 4 link the rear and sas the front. Then get triple bypass kings all around.
  10. Sep 6, 2012 at 8:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    WIN!
  11. Mar 11, 2019 at 7:36 PM
    Russ97SR5
    Russ97SR5 Member
    Russell
    Tulsa, Ok
    1997 Tacoma SR5
    5" tuff country suspension lift, 33" Maxxis Buckshot II tires
    I put a 5" tuff country suspension lift. Perfect for 33s. I've got a 97 sr5.
  12. Mar 12, 2019 at 4:47 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    I did a 3" lift (Donahoe coil-overs and Deaver springs) and 33" work great.
