What would you like in aftermarket flares for 05+?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The_Hodge, Oct 29, 2010.
  1. Sep 17, 2011 at 2:29 PM
    #301
    The_Hodge
    The_Hodge [OP] Volunteer Moderator
    SC
    1. stock flares were the standard phillips/hex screws w/ the clips on the body panels. easy to take off.
    2. The main mounting is the same screws you removed from the stock ones. the clips are not reused. you will have to get some sort of flexible, thin metal to attach the flare part that will go over your front bumper.
    3. you would onlt need the 4 part. the 6 part includes the pieces that match to the stock front bumper.
    4. cutting them to sit flat against the rear bumper is thr harder part. what i did was pull in the top of the rear flare tighter to the inside and attached it so it would pull in the loose bottom part where it was cut off.
  2. Sep 18, 2011 at 6:07 AM
    #302
    Armsmaster
    Armsmaster Well-Known Member
    Bill
    New Jersey
    2006 TRD Sport 4x4 longbed
    Pro Comp 3 inch Lift, Total Chaos Upper Control Arm, and more to come...
    Nice post i'll make up my wish list and post it in a day or two.
  3. Sep 22, 2011 at 12:31 PM
    #303
    cotruckin
    cotruckin Well-Known Member
    Westminster, CO.
    Lifted 06 TRD Sport
    Bilstein 5100 Lift with rear 1" blocks, ARE Z series topper with Yakima rack and Rola basket, some audio equipment, some more goodies
    Here are some updated pictures of the fender flares. I am still working on perfect fitment but these flares went on pretty nicely.
    This is the fitment that I am working on, just need to do a little bit of trimming and it should lay right against the fender nicely. I am still working on the passenger side rear because that side is seeming to need a little bit more trimming to fit but no major modifications. I mounted mine with stainless steel hardware #10 and just drilled new holes. I have not put the lock nuts on the back of the hardware yet but that will come after all final trimming.
  4. Sep 22, 2011 at 2:23 PM
    #304
    The_Hodge
    SC
    there is no reason you shouldnt be able to use the stock screws and holes. you need to push in on the bottom of the flare to get the stock holes to fit where those indentions are. that pressure is what keeps the top against the body.
  5. Sep 23, 2011 at 7:45 AM
    #305
    cotruckin
    Westminster, CO.
    Lifted 06 TRD Sport
    This is absolutely correct jhodge83. I just chose this method to have the lock nut on the backside for extra security. There is no reason to not use the stock hardware as all of the indention do align with factory mounting locations.
  6. Sep 23, 2011 at 7:46 AM
    #306
    cotruckin
    Westminster, CO.
    Lifted 06 TRD Sport
    I have not seen any pictures of the bottom flares mounted yet, I would be interested just to see how it looks.
  7. Sep 24, 2011 at 8:05 PM
    #307
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Turned out great! looks like 285's with 4.5bs could get coverage with these flares-thanks for posting pics, what rims are those?
  8. Sep 26, 2011 at 11:38 AM
    #308
    cotruckin
    Westminster, CO.
    Lifted 06 TRD Sport
    The specs are correct, 285/70/17 on 17x9 XD Addicts with -12 offest...4.5"bs
  9. Sep 26, 2011 at 5:12 PM
    #309
    Blnd Squrrel
    Blnd Squrrel Member
    Frank
    Very Eastern Maine
    05 Sport
    Jungle Fender Flares, Spray Liner Rocker Panels and Lower Fenders
    This is the Jungle Fender Flare that goes on the front bumper.
    There is one spot to bolt to the flare to the bumper. I didn't see how that one bolt could hold the flare to the bumper. I tried to catch the inside lip of the bumper and screw it to the bumper lip, but the flare wouldn't line up with the main fender flare.
    I ended up fiberglassing a tab to the bumper flare so that I could get the bumper flare to line up with the main fender flare.
    I painted both flares with Dupli-Color Truck Bed Coating before I mounted them.
    I used 5/16 stainless bolts with lock nuts to mount the flares. It took some adjusting with washers and spacers to get everything to line up. All in all it wasn't to difficult of a project.
    I'll post more pics of rear flares when mounted and painted.
  10. Sep 30, 2011 at 12:44 PM
    #310
    grizz mv
    grizz mv Member
    Orem, Utah
    07 TRD Offroad SR5 Double Cab
    2" leveler
    What brand of spray on bed liner did you use?
  11. Oct 6, 2011 at 11:42 PM
    #311
    bladez
    bladez Well-Known Member
    Like Jamie, I also recommend using metal strapping to reach from the fender flare to the inner fender or bumper as shown here. Part of the beauty of fibreglass is that its so easily modified as you have done. Of course your fibreglass tab will work fine, but the metal strapping is just more convenient and less time-consuming. It can also be bent to get it positioned just how you need it as well. With only one mounting point, it will be very difficult to adjust it to get it in the correct position and lined up properly. I'd definitely loosen off your current mounting hardware, then add a second mounting point using metal strapping. That should allow you to get a much better fit on this front bumper mounted flare. Elongating the holes will also give you more room for fine-tuning adjustment.
  12. Oct 30, 2011 at 7:14 AM
    #312
    2chains
    Calgary, Alberta
    any word on the longbox flares?
  13. Nov 1, 2011 at 6:46 AM
    #313
    bladez
    Just see Cotruckin's last few posts above in this thread. He has successfully installed these flares on the long box.
  14. Nov 11, 2011 at 9:59 PM
    #314
    bladez
  15. Nov 12, 2011 at 9:32 AM
    #315
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
  16. Nov 12, 2011 at 6:19 PM
    #316
    2chains
    Calgary, Alberta
    Order placed! How long is shipping to Canada?
    *update--ordered on 12th arrived at my door via Canada Post on 24th they were shipped from Thailand!!*
  17. Nov 19, 2011 at 9:27 PM
    #317
    07Tacoma806
    07Tacoma806 Member
    Amarillo
    2" spacer, URD short throw shifter, headlight mod
    So what exactly did you trim to get the SB flares to fit on the LB? The flares or the actual fender?
  18. Nov 19, 2011 at 9:35 PM
    #318
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    That looks really good. Especially bc we have the same bumper, this is looking more like a go! Does anyone know how long the $280 special is good for?
  19. Nov 22, 2011 at 2:05 PM
    #319
    s2studio
    s2studio Well-Known Member
    Virginia
    06 Tacoma DC 4x4
    Wow! Great looking product.
  20. Dec 13, 2011 at 11:16 AM
    #320
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
    Love the lightbar with the hitch mount... Looks like Avid, any know where that can be found?
