What years have VSC?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rustytoys, Dec 5, 2019.
  1. Dec 5, 2019 at 3:24 PM
    rustytoys
    rustytoys [OP] Active Member
    USA
    1999 Toyota Prerunner
    Was VSC (Vehicle Stability Control) standard from 05 and on, or still optional on some Tacomas? How can you identify? Looking at buying mostly a Prerunner or 4wd, ideally 4cyl - would like to avoid VSC if possible.
  2. Dec 12, 2019 at 10:57 AM
    96carboard
    96carboard Well-Known Member
    You do NOT want to avoid VSC.
    1) It is disabled with the push of a button,
    2) It is responsible also for ALSD/TRAC function, which gives you more traction when needed.
    All that it is, is yaw sensor and a special program that runs on the ECU that controls the ABS, so not having it does NOT give you any reliability improvements (**EVERY ONE of them has ABS). I believe it was around 2009 when it became standard programming.
    Consider situation; you pull off the road on an uphill slope. On the side of the road is ice, but the driver's side wheels are on pavement with good traction. You try to go.
    Without VSC/TRAC: you spin wheel on the ice and start sliding backwards.
    WITH VSC/TRAC: you drive forward and up the hill.
  3. Dec 12, 2019 at 1:18 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I have an 07 and do not have VSC. I think it was introduced from 09 and up. My buddy has the same trim as mine but 2011 and he does have VSC.
    Marc70 likes this.
  4. Dec 12, 2019 at 2:05 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    09+ VSC was on all models.
    05-08 was an option.
    Marc70 and SR-71A like this.
  5. Dec 12, 2019 at 2:10 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I wish I had vsc or trac or at least an lsd. open diffs suck balls in the winter
  6. Dec 12, 2019 at 2:12 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    My 2010 have VSC.
  7. Dec 12, 2019 at 3:22 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    VSC doesn't change the fact that ABS will still actuate and modulate the rear brakes when in a low traction situation. I think the ABS switch mod may be down your alley.
    I did the abs mod myself a year ago and it is quite a lifesaver, especially down here in the coast when I get into pretty hairy situations at the beach.
  8. Dec 12, 2019 at 3:24 PM
    coopcooper
    alberta canada
    what does abs have to do with forward traction?
    Marc70 likes this.
  9. Dec 12, 2019 at 3:29 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
  10. Dec 12, 2019 at 3:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A lot IF you are stopping.
    But in our case. We are not stopping. We are attempting to achieve forward progress.
    Once a tire breaks free, it spins freely until we let off the gas or apply the brakes.
    BTW, I’m not disagreeing with you. I know what you are talking about.
    I believe we have pretty much the same truck?
    coopcooper[QUOTED] likes this.
  11. Dec 13, 2019 at 7:28 AM
    coopcooper
    alberta canada
    yeah im just talking off the line traction on ice. before I had winter tires I wouldn't even need to give it gas just let off the brakes and my tires, well one tire would start spinning.
  12. Dec 13, 2019 at 9:48 AM
    96carboard
    VSC, TRAC/ALSD, and ABS are all just routines within the same program on the same piece of hardware.
  13. Dec 13, 2019 at 9:53 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    ^^^This. I purchased my 2009 model year tacoma in Sept 2008, it has VSC. It's on 2009+ VSC is standard equipment.
    Marc70 likes this.
  14. Dec 13, 2019 at 11:30 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    As was said, optional on 2005-2008 (depending on model, wasn’t available on the X-Runner until 2007 for instance,
    VSC OFF switch was added for 2007 models.
    Jeff
  15. Dec 13, 2019 at 2:06 PM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Dunno about the VSC, but it goes hand in hand with A-TRAC which is pretty cool. Works like a quasi-front locking diff as it attempts (very successfully if used within its intended parameters) to stop the spinning wheel, directing the power to the non-slipping wheel. The downside is that it can overheat the ABS pump during hard/continuous use.
    JC15Taco likes this.
