What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toytec Lifts, Oct 14, 2015.
  1. Oct 13, 2019 at 6:01 PM
    #3581
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
    Will this mess with the alignment
    CygnusX191 likes this.
  2. Oct 24, 2019 at 11:47 AM
    #3582
    BlueCornTaco
    BlueCornTaco Well-Known Member
    2018 Tacoma TRD Pro Cavalry Blue
    King Adjustable Front Coil Overs and Rear Shocks 3", SPC upper control arms, deavers stage 2 rear leaf springs, 285 75 Nitto Ridge Grapplers, Snugtop Super Sport Topper, Rhino Rack Backbone, Rhino Rack Platform on topper, roofnest tent and awning, CBI offroad front and rear bumpers, baja design fogs and light bar
    Kings are all you need to know!
    nattykanari and CygnusX191 like this.
  3. Oct 24, 2019 at 12:32 PM
    #3583
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :spending::spending::spending::D
  4. Oct 24, 2019 at 2:30 PM
    #3584
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    You will have to get your alignment re-done after lifting your vehicle.
    Kings are great! There are also a lot of different manufacturing companies out there that are just as good as King!
    Every product has its own purpose!
  5. Dec 3, 2019 at 7:07 AM
    #3585
    IMXPLRN
    IMXPLRN Well-Known Member
    Folsom, CA
    2003 Prerunner
    I'm trying to figure out what size tire I can run with the lift and wheels I just bought. I would love to be able to run 285/70-17 ko2's, but I see so much conflicting information. I would like to not have to do the CMC. Can you help clarify for me @Toytec Lifts ?
    Here is what I have:
    2019 DCLB TRD OR
    Toytec Boss with Aluma Series Coilovers, rear AAL.
    Icon Tubular Delta Joint UCA
    Icon Rebound Wheels - 17 x 8.5, 4.75" backspace
    mgmdclb likes this.
  6. Jan 21, 2020 at 2:19 PM
    #3586
    Au-sandman
    Au-sandman New Member
    did on mine
  7. Jan 23, 2020 at 3:40 PM
    #3587
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    See my signature for what I have to fit 285/70/17 tires.
  8. Jan 30, 2020 at 5:08 PM
    #3588
    keonigt
    keonigt Da Nurse
    Ewa Beach, HI
    2020 Tacoma TRD sport
    Anyone know if i'll have problems with alignment and trying to get to stock alignment with a 4" BDS lift kit for a 2WD tacoma?
    Or will I have to get control arms? or other parts that will further adjust the suspension for alignment?
    I really want to be able to lift my 3rd gen tacoma with the 4" lift kit and I would like to be able to get alignment near spec.
  9. Jan 30, 2020 at 5:33 PM
    #3589
    SSG (03)TACOMA
    Control arms are a recomendation any thing 3" and above.
  10. Jan 30, 2020 at 5:38 PM
    #3590
    keonigt
    keonigt Da Nurse
    Ewa Beach, HI
    So it would be impossible getting a feather within stock specs in alignment without control arms?
    thanks again for the help!
  11. Jan 31, 2020 at 9:51 AM
    #3591
    badfish_55
    badfish_55 Unknown Member
    OC-->TN
    '17 TRD Sport
    The ideal lift for 2wd is a spindle lift that’ll keep all your stock suspension geometry the same. You just need a simple CB spacer for the rear. Check out the maxtrac thread for more info https://www.tacomaworld.com/threads/3rd-gen-maxtrac-spindles.416793/
  12. Feb 13, 2020 at 2:52 PM
    #3592
    Bobcat Luke
    Bobcat Luke IT
    Austin, TX
    2020 Cement TRD Sport DCSB
    Hows the setup been fairing now that its been 2 years?
  13. Feb 14, 2020 at 12:18 PM
    #3593
    Solmimi
    Solmimi Well-Known Member
    SolSand
    League City, Tx
    2016 Tacoma TSS Double Cab
    6.5" Maxtrac w/ 5100 Billsteins all around
    FYI, for what it's worth, not sure what the advantage is or reasoning behind getting new UCA's, but I did the Maxtrac + Bilstein 6.5" lift and used my stock UCA's. 2 years later no issues whatsoever and my alignment is on point. Haven't had to touch it....
  14. Feb 14, 2020 at 12:30 PM
    #3594
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hmmm..... Gona doubt that, factory UCAs aren't good for much past 2.5", much less 6.5".... Might wanna get your CV boots looked at too. I'll be really impressed if that much lift hasn't caused problems.... Plus a diff drop bracket.
  15. Feb 14, 2020 at 9:07 PM
    #3595
    Solmimi
    SolSand
    League City, Tx
    @keonigt was referring to lifting a 2WD, CV joints or diff drop not an issue.
    CygnusX191[QUOTED] likes this.
  16. Feb 15, 2020 at 11:38 PM
    #3596
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Missed that detail. Cool beans :cool:
  17. Mar 16, 2020 at 8:27 AM
    #3597
    B619
    B619 Well-Known Member
    2020 DCSB OR Premium VooDoo Blue Tacoma
    TW family, Can someone please guide me and steer me into the right direction?
    I have a set of wheels on order 17x8.5 -20 with 265/70/17 tires. From those who have installed this setup said to be rubbing. One member had King's installed and adjusted to normal setting and is rubbing a bit.
    I was planning to keep the stock suspension but now considering getting the Bilstein 6112s front and 5100 rears. I was wondering what else I will need to purchase or do? Upper Control Arms, Add A Leafs, ETC? I am new to lifting and used to lowering cars. Thank you for all your response.
  18. Mar 16, 2020 at 9:25 AM
    #3598
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If you check out toyteclifts.com they've got some great package deals that have everything you need for various full suspensions, including the ability to customize a few things based on your needs. Great descriptions about what components do and why you might use one thing vs another.
    Rockoma5 likes this.
  19. May 13, 2020 at 5:04 PM
    #3599
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Ideally / minimally...
    How much down travel/ droop, should a Tacoma have left after a lift?
    Front and Rear?
  20. May 20, 2020 at 6:57 PM
    #3600
    JAFO
    JAFO Well-Known Member
    Thailand
    2016 Hilux 2.8L Turbo Diesel
    Toytec Lift, Zeon 8000-S Warn Winch, Rival Skid plates, Bilsten 5200 Gas shocks, TRD 17" Custom wheels. KR3 BFG Mud terrains
    I hope this is the right section. I live in Thailand and have a 2016 Toyota Hilux crew cab 4x4 2.8l diesel truck. Before I moved here for work I worked with Toytec for a lift kit which I brought over (Build thread here: Tacomaworld.com/threads/hilux-revo-2016-build.443364/ ).
    I have the Toytec Boss 2.5 set up on it and it works perfect. However with all these trucks they end up with the front end rake down and I would like to level it out. after measuring it all out I am considering the 3" leveling spacer which is about exactly what I need to level the truck.
    Can anyone offer inputs/comments/pros/cons? If there is a thread all about it let me know, I wasn't able to find one.
    Thanks
