What's better for 2" rear lift...shackles or AAL?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cvd2312, Nov 18, 2011.
  1. Nov 18, 2011 at 7:39 PM
    Cvd2312
    Cvd2312 [OP] Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    I'm working on putting together a lift, trying to decide on the rear portion.... can I get some feedback from people who have experience with shackles or AAL's? I'm mostly concerned with ride quality. Thanks!
  2. Nov 18, 2011 at 7:49 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    It depends on the condition of your springs. The stock ones are pretty weak so if yours are shot then use AAL (although that won't fix things...you would need new springs to fix that). Otherwise shackles aren't a bad way. I had lift shackles on my first truck and they worked well enough.
    Cheaply, I would do AAL>Shackles. I personally would get replacement lift springs though. I have OME and I love them.
  3. Nov 18, 2011 at 7:56 PM
    Cvd2312
    Cory
    Oregon
    2013 DCSB TRD OR
    Thanks for the input. I'm definitely not putting out the money for new springs. I want to lift it cheaply but without blocks.
  4. Nov 18, 2011 at 7:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Neither. A replacement spring pack is the better option.
    With worn out springs an add-a-leaf will eventually sag and you will be back to square one. And, while shackles will never lose their 2"s, when used with a worn out springs will cause the spring to sag that much quicker and possibly cause a leaf to break.
    If you are truly concerned about ride quality, get a replacement spring pack from wheelers offroad. If you are looking for a little lift, they have a a great 5 leaf pack made by Alcan that give about 1.5".
  5. Nov 18, 2011 at 8:33 PM
    Cvd2312
    Cory
    Oregon
    2013 DCSB TRD OR
    My rear springs are fine, my truck doesn't sag at all. I know that a replacement spring pack would truly give me the best ride, but I'm not going to spend the money for that. I'm just looking for the best option between shackles and AAL's.
  6. Nov 18, 2011 at 9:12 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Not sagging on 15 year old leaf springs? Are they original? If so, I can almost guarantee they are sagging. I have a totally flat arch on my springs on my 97.
    But, if you dont want to put in the cash for a leaf pack, get the Icon 3 leaf add a leaf. It will yield a better ride because they are progressive springs.
  7. Nov 18, 2011 at 9:39 PM
    Cvd2312
    Cory
    Oregon
    2013 DCSB TRD OR
    I'll re-phrase that... based on how the truck sits, the rear springs don't appear to be sagging. I've seen Toyota's that have obvious sag, and mine doesn't look like that. It has a good stock look to it, not a worn out truck look to it. Looking at my leaf springs, they do appear to be fairly flat, but I don't really have anything to compare it to, and I don't know a lot about suspension. I've only had the truck for a year so I don't know if they've ever been replaced, but I'm guessing they haven't. Anyway, thanks for the input!
  8. Nov 19, 2011 at 12:06 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just save up man and get some real leaf packs.
    AAL is better then a shackle tho..
    but again, do it right the first time, will be cheaper in the long run..
