Whats going on with my brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OCTaco, Mar 31, 2010.
  1. Mar 31, 2010 at 11:11 AM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    Tw my brakes are all jacked up,
    My pedal was traveling super far almost to the floor so i brought the truck to toyota. They checked and said my brakes were out of adjustment so i had them fix'm. Anyways, driving home brakes felt fine but now, one week later, they are doing the same shit again. WTF!!! I need to take them back to toyota but does anyone have any idea what this could be?
  2. Mar 31, 2010 at 11:15 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    leak in the lines?
  3. Mar 31, 2010 at 11:16 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    +1
    It sounds like you're getting air in the system.
  4. Mar 31, 2010 at 12:26 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Brakes are at 90%. I dont see any leaks and my brake fluid is full. ABS system also seems to be ok. Plus, toyota dealer didnt see any leaks either.
  5. Mar 31, 2010 at 12:43 PM
    wooddogg922
    wooddogg922 Well-Known Member
    15 DCLB TRD Sport PreRunner
    Could be a bad brake booster. Check the vacuum check valve that it's not clogged.
    Guess I should of asked if you have VSC, if you do then it's hydraulic, and won't have a check valve. you would need a guage to check the pressure, and it looks like a long process on TIS.
  6. Mar 31, 2010 at 12:59 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    What i dont understand is why when the dealer "adjusted" the rear brakes everything was fine, and now all of a sudden it's not? Is there a possibility that the adjustment mechanism on my brakes is broken?
  7. Mar 31, 2010 at 1:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    Going with this too.
  8. Mar 31, 2010 at 1:09 PM
    wooddogg922
    It could also be as simple as air in the brake lines, and you just need to have them bleed the brakes. I'm not totally sure on your truck, but the booster push rod could be out of alignment. Could be as involved as a worn or damaged piston or seal in the booster/master cylinder.
  9. Mar 31, 2010 at 1:15 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    This sucks, i can't even drive my truck. Well, i guess ill have to see what toyota says. Wish me luck.
  10. Mar 31, 2010 at 6:08 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I am going to ask silly question that was not ask here but....
    you have 06 and you did not state how many miles but regardless when and if you had replaced your brake fluid. 4 year old car (could be 5 if purchased in 05 as 06 model) usually needs brake fluid replacement.
  11. Mar 31, 2010 at 10:45 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    This is where I'd be looking too.
  12. Apr 1, 2010 at 7:01 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    If it were the brake booster, the brakes would be hard not spungey. It's not the master cylinder because pumping the brakes has no effect on them. I cound maybe air in the line, or a leak somewhere. I'm going to ask toyota to do this today since they are replacing my exhaust manifold anyway.
