What's In Your Oil Filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotajax, Nov 29, 2021.
  1. Nov 29, 2021 at 3:47 PM
    hotajax
    hotajax [OP] Well-Known Member
    09 TRD Off Road
    How can you get an unbiased assessment of what manufacturers use premium filration, such as synthetic fibers or the glass? Been using Hastings and Baldwin for years, might be nice to know what's inside. Thanks. Website doesn't say.
  2. Nov 29, 2021 at 3:50 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
  3. Nov 29, 2021 at 3:59 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    wi_taco likes this.
  4. Nov 29, 2021 at 5:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There is a guy on YouTube that has a whole series dedicated to oil filters.
    I think it’s Nates Auto or something?
    Anyways, he is not the only one to compare filters.
    Hours upon hours of oil filter content on YouTube.
  5. Nov 29, 2021 at 7:07 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The type of media material doesn't matter too much.
    The key numbers, for any filter, is the size of the particle that will pass (micron rating) and the capture rating (aka filtration efficiency).
    After these key items is the construction, bypass valve, anti-drain back valve, media core, seals.......
    Be prepared to jump into a deep rabbit hole.
    IMHO, some of the best filters are WIX, NAPA Gold, Bosch and ACDelco.
    Good Luck doing the research.
    Rob MacRuger likes this.
  6. Nov 29, 2021 at 11:21 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    Oil
    Taco 422 and MattCowsmasher like this.
  7. Nov 29, 2021 at 11:45 PM
    TacoTuesday1
    SD CA
    Never heard of Hasty Ballsack
    been running OEM filter $5/ea
    90915-YZZD3
    works pretty well, the engine runs
    $5 filter + $12 5qt jug synthetic Mobil 1
    not really much to complain about
    It's a metal canister. Not a Mercedes. It's not a plastic cap housing with removable fleece filter that you can physically look at.
    I will admit though. The OE filter is very tiny. It's almost like Toyota didn't give a shit. Same approach they took with certain other things on the truck.
    Many other passenger cars, whether metal canister or fleece/paper, have much larger filters.
  8. Nov 29, 2021 at 11:49 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    The TOY CONNECTION uses what the TOY CONNECTION uses. I love my shop!! Going in weds
  9. Nov 30, 2021 at 12:08 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    It's just too simple to click on an Amazon link from a dealer selling a 10-pack for $44...
  10. Nov 30, 2021 at 12:41 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    where are you getting 5 qts of mobil synthetic for $12? I just paid $30 at walmart.
    Rob MacRuger and plurpimpin like this.
  11. Nov 30, 2021 at 1:06 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I’m gonna wager either BS/typo or not actually running synthetic. That’s half of the price when it’s on sale!
  12. Nov 30, 2021 at 6:35 PM
    TacoTuesday1
    SD CA
    during the rebate promotion they've been running for 5+ concurrent years
    you would normally buy it for $23-24 at WalMart then provide reciept proof to Mobil who then mails out a $12 check per large jug.
    (which is what most people never do)
    to each his own, some people like to spend more, their personal business not mine
    to be clear, I am not saying I recommend it.
    Even if you buy it for $12, in the professional world including rich Porsche racers, it has a reputation for being garbage and watered down. People usually go for higher/anything but, such as Motul, Amsoil, Fuchs, Castrol, Royal Purple, LiquiMoly, Motul, and so on. Which also cost more. Retail on a big jug of Motul has been seen for $44.
    Unless however, your goal is to proudly say the word "synthetic" at the next barbeque. Then it is possibly the most affordable way of doing that.
  13. Nov 30, 2021 at 7:26 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Mexican newspaper or whatever Fram uses.
    b_r_o likes this.
  14. Nov 30, 2021 at 7:34 PM
    Taco 422
    USA
    :fingerscrossed:
  15. Nov 30, 2021 at 7:35 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Plastic
  16. Dec 4, 2021 at 5:44 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  17. Dec 4, 2021 at 5:58 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    983BA9D8-ADB0-4F4A-BE84-CC458D9A475E.jpg I got the stainless steel metal mesh
    TnShooter likes this.
  18. Dec 4, 2021 at 6:05 PM
    TnShooter
    Deogee
    STOCK
    Somebody got tired of jamming a bottle under the filter housing to catch the oil, didn’t they?:rofl:
    The SC had nothing to do with reason you went remote. Admit it……:cool:
    Nice setup:thumbsup:
    Xmplry808[QUOTED] likes this.
  19. Dec 4, 2021 at 6:11 PM
    Xmplry808
    sorry bad angle on the first picture. It’s actually for an oil cooler set up but as for my oil filter I’m using K&n (pure power) reusable oil filter that’s a stainless steel mesh
    thanks for the compliment tho :D
    TnShooter[QUOTED] likes this.
  20. Dec 4, 2021 at 6:13 PM
    TnShooter
    Deogee
    STOCK
    I see now. :thumbsup:
    I like it.
    Can’t say I’ve ever seen that on a Tacoma before, but I haven’t seen many SC Tacoma’s.
    Just pictures here on TW.
