What's my next move?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2toys, May 12, 2011.
  1. May 12, 2011 at 11:28 AM
    2toys
    2toys [OP] Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    My 2001 2.7 has been throwing p0300 & p0303 (misfire) codes for the last couple weeks. Here's what I've done so far.
    Replaced fuel filter.
    Checked plugs - ok
    Swapped coil packs - no change
    compression test - #3 about 5% off but within limits
    Leak down - slight leak in #3, no bubbles in rad, no noise in oil or exhaust!
    Seafoamed in break vac line - lots of white smokeand ran a bit smoother.
    Bottle of Seafoam in current tank of gas.
    What's next? I'm thinking injector swap, but I guess I need to find o rings.
    Maybe sticky valve? Idk there. Bad Cat?
    any help appreciate!
    UPDATE:
    I have now cleaned the throttle body real well.
    Added some seafoam to the crankcase.
    Replaced the fuel injectors
    Replaced spark plugs (denso oem, .043 gap)
    All the above with no real noticeable improvement, though a bit more throttle response. A p0303 code will still come on, sometimes at a cold startup. A flashing CEL will happen under load conditions such as climbing a grade.
  2. May 12, 2011 at 2:13 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    What codes are those?
  3. May 12, 2011 at 4:45 PM
    2toys
    Los Angeles
    300 = random misfire
    303 = misfire cylinder #3
  4. May 14, 2011 at 9:19 AM
    2toys
    Los Angeles
    Just an update.
    I've cleaned the MAF sensors and checked by washable filter. All there looks OK and made little to no difference. I'm still throwing a p0303 daily. I did take it on the freeway last night and really stomped on it! No codes and it felt like it was more responsive, still working through the tank with the Seafoam. If this tank goes and still is throwing the 303, I'll look to pull the #3 injector. I have 160k on this truck and to my knowledge nothing has been done with the injectors. Do the injectors need an annual maintenance or something?
  5. May 14, 2011 at 9:44 AM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    check the plug wires
  6. May 14, 2011 at 10:37 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    You said you checked plugs, however one may still be bad and it looks good, trying replacing the plugs
  7. May 14, 2011 at 1:32 PM
    glamis3000
    glamis3000 Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    mine did this and it was because my spark plug boot would come off it was cracked and you couldnt see it. i bought all new spark plugs and wires and since then never have had a misfire since. it would also run funny, thats how i knew something was wrong. the rpm range was way off due to one cylinder not firing right.
  8. May 14, 2011 at 8:50 PM
    2toys
    Los Angeles
    Thanks for all the suggestions, I have some plugs on order.
    Today I added 1/3 Seafoam to the crankcase in hopes that something is gunked up in there. I did the paper at the tailpipe trick, and it didn't suck in so I thought that was good.
    Also I cleaned up the throttle body. I looked in there first and it didn't look too bad. But I sprayed some cleaner in there and WOW! I cleaned and cleaned, as best I could without taking it off (as I don't have a gasket). Well this made a marked improvement. The RPMs are much more steady and the idle much more smooth. So far no codes.
    I will report back more after I change the plugs.
    Thanks!
  9. May 15, 2011 at 6:32 AM
    sourdough44
    sourdough44 Member
    WI
    Sold my 2000 Tacoma
    I had an ignition problem a while back on my 2.7 ltr 2000 Tacoma. The main issue was a bad plug wire.
  10. May 15, 2011 at 9:20 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    If you put denso platinum plugs in it then that made mine misfire. I put the regular ngk's in it and presto all fixed. I got 196,xxx on mine. That engine doesn't like high dollar plugs. When I pulled the platinum plugs they looked fine too.
    Murph
  11. May 21, 2011 at 9:26 AM
    2toys
    Los Angeles
    (I've updated the first post to reflect my "progress" if you will.)
    Yesterday I did the following:
    All the above with no real noticeable improvement, though a bit more throttle response. A p0303 code will still come on, has been coming on at a cold startup. A flashing CEL will happen under load conditions such as climbing a grade. Engine still runs rough especially at idle. I can post vids if that would be of interest... The plugs and injectors looked ok, but the #3 plug was a lot more brown (plug read guides show "normal") then the others. This after the seafoam in the last 400 miles.
    Also I pulled the plug on the #3 injector when running and it stumbles, so I know I'm getting fuel there. Also pulled the #3 spark wire and again stumbled and turned off, so apparently it's firing.
    Also sprayed some carb cleaner to look for a vac leak, but found nothing.
    I'm thinking of trying to clean the o2 sensors. Maybe their getting a bad reading to the ECU?
