Whats safe without a Brake controller?
Discussion in 'Towing' started by michaelg589, May 29, 2012.
  1. May 29, 2012 at 3:32 PM
    michaelg589
    michaelg589 [OP] Well-Known Member
    I didnt want to make a whole thread about this but I searched and couldnt find a definitive answer. I am planning on picking up a Honda Civic. Its approximately 100 miles away. To avoid paying for a Uhaul dolly or trailer, I want to use my friends dual axle flat bed trailer. I believe its mostly steel construction with wood planks as a floor and steel ramps. Im going guess and say it weighs 1000 lbs. The civics curb weight is around 2600 lbs. That puts the whole situation at 3600 but just to make sure Im nt under estimating, call it 3800. I do not think the trailer has electric brakes. My friend pulled it with his Chevy 1500 pickup WITHOUT a controller, so I assume no trailer brakes. However, is 3800 lbs. safe to tow with a Tacoma and no trailer brakes?
    My vehicle is in my sig. Factory Tow package.
    Thanks!
  2. May 29, 2012 at 5:28 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    NO.
    According to the "book of Tacoma", brakes for any load over 1000 pounds. Realistically, 2000-2500 max. Check about the trailer. Flat bed car haulers are usually more than 1000 pounds. Think closer to 2000. Verify status of trailer brakes, maybe the trailer has hydraulic brakes? If that is the case, then no brake controller is needed.
  3. May 29, 2012 at 6:06 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    NO, I was in the trailer business for 15 years and you can jackknife so easy, killing you or someone else.
    that kind of weight, will have a mind of its own.
    and if you get stopped, in some states, they will make you park it on the road, will throw the book at you. and I have heard stories from people that they impounded the trailer and load, and you don't want that.
  4. May 29, 2012 at 6:19 PM
    michaelg589
    I was with my friend when he made about the same trip in his 1500. Granted it is a full size, the overall weight of the truck and the braking performance are quite close to a V6 Double Cab Tacoma. He handled it fine with a car that might weigh more (1968 Mustang Convertible).
    Again, Im unsure how the trailer is setup. Its a 7 pin. Theres another safety line that gets attached to the truck. I think this safety line is meant to enage the brakes if the trailer became disconnected. But how would that work???
  5. May 29, 2012 at 6:24 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The trailer has brakes. That extra line is a breakaway. If the trailer gets disconnected from the truck, that extra line pulls the brakes on the trailer so it comes to a stop.
    I generally agree with Knucklehead, realistically 3,000 lbs is the max I'd tow without brakes and that's only if you're experienced, less if you're not familiar with towing a trailer.
  6. May 30, 2012 at 5:23 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've done it, but I don't recommend it.
    Allow a lot of stopping distance at all speeds - even from 10 mph. Especially from 10 mph.
    I'd slowed to a creep and went to put on the brakes to stop the load the rest of the way. The truck brakes locked up and the trailer pushed me an additional 5 feet beyond where I'd planned on stopping.
  7. May 30, 2012 at 5:46 PM
    michaelg589
    Good to know. About how much weight were you pulling?
  8. May 30, 2012 at 6:18 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    one more thing to remember if you are going to do this, make sure there is NO chance of rain.
  9. May 30, 2012 at 9:31 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I towed 3000-3500 for 6 hours. No problem at all.
    Trailer had brakes but were not operating at the time due to a cut brake line.
    Since then have the brakes hooked up and you can tell they help but would not have any concern doing it again in my eyes.
    When ever I trailer I leave more room and place all eyes on the road with extra attention.
    In city traffic it can get hairy around rush hour and added braking is never a bad thing to have.
  10. May 30, 2012 at 9:57 PM
    1C271
    1C271 Well-Known Member
    Tennessee
    2007 4x4 TRD Off Road
    Yes you can. I regularly tow up to 6000 lbs or so with mine. Most double axle wood floor car haulers are about 1600lbs. I towed my Double axle when I first bought it with my corvette on it from Kansas to Tennessee, about 780 miles with no controller because I had not installed one yet. Just DON'T brake hard or suddenly and give yourself ALOT of extra time to slow down, coast and downshift as much as possible. It will be just fine, especially for just 100 miles.
  11. May 30, 2012 at 10:17 PM
    1C271
    Tennessee
    WTF?!?!? Come on now you can't be serious? SO your brakes weren't working at all or you were towing the USS Missouri.....which is it? Cause I tow anywhere up to 6000 lbs and even when my brakes were worn I could always stop....
  12. May 31, 2012 at 6:06 AM
    Pugga
    Massachusetts
    You tow 6,000 lbs without trailer brakes? :eek:
  13. May 31, 2012 at 6:08 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ballsy fucker hey?
    I've fulled 5000+lbs with brakes and even then it's a new experience.
    Get a controller. Rent one. Do something. Is 3800lbs horrible? No. But if you're not used to pulling anything with your truck last thing you want is to write off your truck or worse, kill someone.
  14. May 31, 2012 at 6:13 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The trailer most likely has surge brakes which does not require a brake controller since they are activated by centrifugal force and not electric current. If this is the case you're golden. The safety cable actuates the trailer brakes if the tow vehicle and trailer become separated.
  15. May 31, 2012 at 6:17 AM
    Pugga
    Massachusetts
    Surge brakes are activated by a hydraulic piston that's in the trailer tongue. Truck stops, trailer's weight and momentum compresses the piston, forcing fluid to the brakes. There's nothing spinning that creates centrifugal forces.
    I still think the trailer has electric brakes because it has a 7-pin connection. If it had surge brakes only, it'd most likely be a 4-pin as the other 3 pins wouldn't be necessary.
  16. May 31, 2012 at 7:59 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    The 7th pin that 6 pin and fewer plugs lack, is reverse signal. Surge brakes require a reverse signal to lock out the brakes when backing up. Electric brakes only require 5 pin.
  17. May 31, 2012 at 8:25 AM
    Pugga
    Massachusetts
    Not all, I've never seen a trailer with surge brakes and a 7-pin plug. I know what you mean, it's a reverse lock out so you can actually back the trailer up but every surge brake equipped trailer I've ever towed has only had a 4-pin connection. They were all Uhauls.
  18. May 31, 2012 at 11:27 AM
    1C271
    Tennessee
    I've pulled about 4700 with no trailer brakes, drove 780 miles just fine, no problems at all. And since moose never answered me I call BS on his post, there is no way that whatever you could pull with your Tacoma would keep pushing you with your brakes fully applied. Unless your brakes were not bled properly and had air in them or you were trying to stop on an ice rink.
    lol
  19. May 31, 2012 at 11:39 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I've towed my boat which is 1500lbs before counting motor and trailer. no issues with that but if it weighed much more I'd want brakes.
  20. May 31, 2012 at 11:59 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    hyd. surge brakes has a release in the hubs to back the trailer up.
    sold,built and towed them for 15 years.
