What's the best kit for a Winch/Bumper combo?
Discussion in 'Suspension' started by copenhagen, Aug 4, 2011.
  1. Aug 4, 2011 at 6:13 PM
    copenhagen
    copenhagen [OP] Well-Known Member
    South Carolina
    2011 TRD OFFROAD 4x4 SIX SPEED MANUAL AC
    I started this thread here: http://www.tacomaworld.com/forum/suspension/170311-ome-2-inch-05-tacoma-heavy-kit-questions.html
    I was under the impression that the OME heavy suspension lift kit would provide what I needed to ready my truck for an ARB bumper and WARN winch? Evidently it does not.
    In light of that, I have the following questions:
    Is there a QUALITY kit in existence which will provide EVERYTHING that I need to PROPERLY ready my 2011 AC Tacoma for an ARB Bumper and WARN 8000lb winch? I did notice that Total Chaos has a kit that comes with UCA's, but it includes Fox shocks. I do not know if they will be heavy enough for the bumper and winch. Is it really necessary to order separately every individual part needed to properly modify one's suspension to accommodate the bumper and winch? Surely there must be a quality kit out there that I am missing (UCA's and the necessary hardware to prevent vibrations, etc). A nice set of instructions would be handy too.
  2. Aug 4, 2011 at 6:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How did you conclude that the 886 lift is no good for the ARB bumper and winch ? They were designed for that bumper .
  3. Aug 4, 2011 at 6:56 PM
    copenhagen
    South Carolina
    The kit is marketed as including everything that you need. It does not include spacers or UCAs which both appear to be necessary to utilize it properly. Therefore it is not what I am looking for. I am looking for a kit that comes with all that I need and instructions. If this does not exist then I will go with what we talked about in the other thread.
  4. Aug 4, 2011 at 11:17 PM
    OZ-T
    Peter North
    British Columbia
    The kit does include the OME CB drop . It is the FK29 Fitting kit .
    I think the only place that supplies the bushings for the Dakars with them is Wheelers .
    As for the UCA's , nobody includes them , with this kit , or any other as far as I know ( with the exception of the TC kit you mentioned above )
    As for the little stuff like axle shims and centre pin collars , I think you will find most places carry that type of stuff but again they are not included as a comprehensive kit
    IMO , you are going about this wrong if you are more concerned that everything comes in one easy package rather than getting the components best suited for your planned needs
  5. Aug 5, 2011 at 4:39 AM
    copenhagen
    South Carolina
    Well, in my opinion, there is not much sense in packaging items as a kit if you only provide a portion of the parts needed to complete the stated objective of the kit. It makes me wonder about the quality of the items if the marketing behind them is misleading.
  6. Aug 5, 2011 at 4:54 AM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    The "kit" provides you with all equipment you need to lift your truck. Shims, UCA, bushings, diff drops are all "extras" in the sense they are good to have to avoid vibrations and odd driving characteristics resulting from the lift. They are not part of a lift kit as they are not doing any of the lifting. UCA 's are more important since they allow your vehicle to have a better chance if getting back into factory specifications, making your vehicle safer to drive and hopefully keeping things like tires from wearing prematurely.
    Edit- Also, the OME kit also has several "rear" lift options and depending on what option is selected ie blocks, single AAL or new leaf pack, different installation and hardware is required. Another reason why a full 100% inclusive kit is not available with one click of the mouse.
    Find the best price on the OME kit call up the company and ask them to add whatever else they recommend. If you don't develop vibrations or driveline shudders, simply return some of the extras.
  7. Aug 6, 2011 at 2:43 PM
    copenhagen
    South Carolina
    Is there any good kit available that will simply beef up the front suspension in order to support a winch and bumper (I don't see the point in buying new rear suspension for my purposes)? I am not really interested in a lift kit if I don't have to get one to properly support my winch/bumper as I have sufficient height for all realistic off-roading with the TRD Offroad package already. Can the factory Bilsteins reasonably handle the added weight? A leveling/shim kit was suggested to me, but I am worried about how much travel I would lose and rather the front shocks would be more prone to bottom out. Anybody with experience in compensating for your bumper/winch: I would appreciate your response/suggestions.
  8. Aug 6, 2011 at 3:06 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    You can do the kitty litter test. Take a large bag of kitty litter (50-80 lbs) and put it on your front bumper. This will simulate the weight of the arb. Nobody on this site is a fan of shim/spacer lifts. No one makes a one click kit because very few people want one. Some people prefer one brand of coil overs, and another brand of uca's. I'd buy the the lift kit, install it and see if you have any vibrations. If you do then buy some uca's.
  9. Aug 6, 2011 at 3:15 PM
    OZ-T
    Peter North
    British Columbia
    The ARB weighs 165 lbs not including the winch and cable
    UCA's are to correct alignment issues , not cure vibes
  10. Aug 7, 2011 at 8:01 AM
    copenhagen
    South Carolina
    Well, that is rather depressing for me that no-one makes a kit to simply properly ready a truck for a winch and bumper. It seems as if they would because this is a very utilitarian item which many men will find a need for who do not find a need to become head over heels involved with their truck as their hobby. I wish I could afford/had the time to have multiple hobbies, but I cannot, and I was very much hoping that there would be a simple solution for properly installing a winch and bumper to a Toyota Tacoma.
  11. Aug 7, 2011 at 8:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You don't have to be head over heels into your truck. You can order all the parts you need from one place-You have to spend a few minutes talking to a sales rep or thinking for yourself about what parts you want.
    Making a "complete" package like that would pair parts from multiple sources into limited setups that the manufacturers probably won't allow. There is enuf mis-information going around about what parts work with what...They don't need people saying "You can only get these UCAs with those springs"
    Taking a truck offroad- I'd want the parts I was convinced were the best, not the parts that had the easiest installation or the best marketing.
  12. Aug 7, 2011 at 8:28 AM
    copenhagen
    South Carolina
    Surely there is a pair of coil-overs and shocks out there that can replace the factory front end ones and maintain a level ride within factory specifications when loaded with a winch/bumper. I have no need for a 2-3" lift, or to spend 2 grand re-doing the entire suspension on a brand new truck. Are there any specific recommendations for such a thing?
  13. Aug 7, 2011 at 8:29 AM
    OZ-T
    Peter North
    British Columbia
    You already had it figured out and got thrown by the fact that people suggested a few parts not included in your original kit .
    The OME 886 springs are designed specifically for the ARB bumper , having said that , they will lift the front about 2 1/2 - 3 " , which gets into the territory where you need to get aftermarket UCA's in order to get a correct alignment .
    The OME Dakar rear leaf springs in your original kit will lift the rear 2 3/4" .
    You will end up with the factory rake but approx 3" higher .
    Lifting the truck changes the geometry of the suspension and may introduce vibrations , that's why some people suggested the smaller items like centre pin collars , axle shims and the CB drop . These items can correct any vibrations you add by lifting the truck .
    Overall the OME kit is a good kit and is suited for what you want to do .
    I have the same kit but with the 885 springs as I am not running a heavy bumper and winch
  14. Aug 7, 2011 at 8:49 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I see what your going for OP. You want no lift but want the added stiffness in the front to carry an ARB bumper and winch. Am I correct in this assumption?
    You need a spring with a higher spring weight than stock. I would assume that either the Eibach springs or even the 885s might be your best option. Maybe someone will chime in but you may have to rephrase your thread topic to get the correct answer.
  15. Aug 7, 2011 at 8:53 AM
    OZ-T
    Peter North
    British Columbia
    The Eibach will still lift the front 1.6" and the 885's will get 2 1/2" less whatever they settle from the bumper weight
  16. Aug 7, 2011 at 10:11 AM
    TXBulldawg
    TXBulldawg Well-Known Member
    Texas
    2014 Silver 4Runner SR5 4x4
    In progress...
    Not with a bumper & winch installed. Might be worth looking at for the OP if he doesn't want to mess with anything else.
  17. Aug 7, 2011 at 10:22 AM
    OZ-T
    Peter North
    British Columbia
    True
    I meant to say both would settle under the bumpers weight
    Poorly worded by me
  18. Aug 8, 2011 at 8:44 AM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Not to derail the tread.
    I have 95.5 taco im going for the arb bumper and xp 9500 winch. I was looking at replacing the suspension.
    I have been looking at the NWOR kits that are adjustable in the front and rear springs. Nice one or 2 inch lift at most is all i want. Any one have feedback on this set up?
  19. Aug 8, 2011 at 9:08 AM
    copenhagen
    South Carolina
    So, ya'll think it may be possible just to replace the coil-overs, maintaining the factory lift?
  20. Aug 8, 2011 at 9:38 AM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yes, I think that if you replace the front struts with some adjustable coilovers you can just adjust the preload on the coilovers to compensate for the added weight while maintaining factory height.
