What's the big deal with the rear e locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eagle Rock, Aug 6, 2020.
  1. Aug 7, 2020 at 8:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    mattvivsound[QUOTED] likes this.
  2. Aug 7, 2020 at 8:33 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
  3. Aug 7, 2020 at 8:44 AM
    paetersen
    paetersen Well-Known Member
    It's better than a Type R sticker or a CAI.
    RoughRder and TengoTaco like this.
  4. Aug 7, 2020 at 10:07 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    My nearly 20 year old truck has the locker. I never give this any thought but I have to ask-is it bad that I literally have only engaged the locker one single time just to see what it felt like? I did it when the truck was only a year old in gravel. I haven't touched that switch since. Should I be working the locker every once in a while to keep it viable? I know it's kind of a dumb question after having neglected it for almost two decades but this thread got me curious.
    JJ04TACO likes this.
  5. Aug 7, 2020 at 10:12 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I would, and do. I have seen them seize up. It's recommended that you engage the 4WD every now and then as well. Say what you will about it. But it makes sense. I try to get several miles in 4WD and I'll engage the locker about once a month. I do it on pavement but only going straight. I NEVER turn. If you have dirt roads I'd recommend that. I live in DFW so dirt is a hard thing to find.
    RoughRder, QMEDJoe and Ridgerunner like this.
  6. Aug 7, 2020 at 10:17 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I recall that even in that loose gravel, I engaged it and then hit a little gas as I just slightly turned, and I wasn't thrilled with the awful sounds it made like a stick was caught up in the gears or something. Even the rear end bucked a little. Was that normal? Anyway, I think I need to give this thing a try soon as I have the truck out now.
  7. Aug 7, 2020 at 10:44 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    As long as you are on loose terrain you'll be ok. Dirt, gravel, sand. The tighter you turn, the bigger the difference in wheel speeds at the corners, the more slipping you will notice (or binding on pavement). I try to avoid really tight turns in 4WD unless in mud and sand. But generally speaking if you have a way for the wheels to spin and unload the drivetrain, you'll be ok. Just don't test the steering radius.
    Edit: Watch that video. But yes try to exercise your transfer case and locker.
  8. Aug 7, 2020 at 11:02 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Had to throw my 2 cents in here.
    1. E locker is the coolest option on my truck. It gets you unstuck when all 4 wheels are spinning, especially in snow.
    2. I caution all who only use it rarely, the solenoid will stick and it won't engauge if it is not excercised regularly.
    RoughRder, Wyoming09 and JJ04TACO like this.
  9. Aug 7, 2020 at 11:10 AM
    suzuguru
    suzuguru Well-Known Member
    Eric
    Nashville, TN
    2001 Tacoma 4WD, 1996 Land Cruiser HDJ80, 1985 Pickup 4WD
    A rear locker is very important if you do much off roading. You can go more places in a 2-wheel drive with a rear locker, than you can with a 4-wheel drive with open diffs.
    05prerun82 and Chako like this.
  10. Aug 7, 2020 at 11:21 AM
    paetersen
    Fixed it for ya.
  11. Aug 7, 2020 at 11:33 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    LOL ain't nothin' going to help you with all 4 spinning... :thumbsup: Nice catch.
  12. Aug 7, 2020 at 12:48 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It all comes down to how or what you use the truck for.
    Mechanical electrical device it needs to be engaged just like your 4x4 from time to time.
    We hear of people having 4x4 failing to engage because they only tired it once 5 years ago freak blizzard in Key West now it does not work.
  13. Aug 7, 2020 at 1:15 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Ah the concensus says my question was not so dumb! Good info y'all. My truck's 2wd with locker. So now I have to figure out where I can exercise this thing around here. I hope it doesn't get stuck in the engaged position when I do-is that possible too?
  14. Aug 7, 2020 at 1:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Never been stuck for me before; then again I replaced all fluids in my truck when I took ownership of it.
    Ridgerunner[QUOTED] likes this.
  15. Aug 7, 2020 at 1:22 PM
    #35
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Next thing on the build list is re-gearing and locking front and rear. :drool:
    :spending:
    suzuguru, Kwikvette and cruiserguy like this.
  16. Aug 7, 2020 at 1:26 PM
    #36
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Excuse me, troll post are scheduled for Friday's good sir
  17. Aug 7, 2020 at 2:25 PM
    #37
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Quoted for truth with addendum: grey wire mod is also awesome.
  18. Aug 7, 2020 at 6:41 PM
    #38
    QMEDJoe
    Joe
    A couple of years ago I lived in Coppell. I drive to work in Louisiana and went a couple of years without ever putting in 4WD. It wouldn't engage and after dropping it off at Toyota, the mechanic said he got it to finally work. Now that I live in Western North Carolina I wheel as frequently as I can so it hasn't been a problem.
  19. Aug 8, 2020 at 9:46 AM
    #39
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Coppell huh? I lived in Lewisville close to Coppell for a long time. Pretty close. Now I'm in Corinth.
    Lol I was just in NC last month for a wedding in Atlantic Beach. Drove through WNC on the way back to see the Smokey Mountain NP. Stopped in Hildebran (Near Hickory) where a cousin by marriage was raised and got us some livermush per his recommendation.
    All and all NC was pretty nice. Glad you get to wheel. As you know there isn't much to do around here. It sucks.
    QMEDJoe likes this.
  20. Aug 8, 2020 at 10:07 AM
    #40
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Yet again a video that gets differential fundamentals regarding outputs of torques and speeds completely wrong. I've covered it many times on this forum and videos like this that present as quality information on the topic yet get the details wrong just frustrates me. Be mindful of the misinformation the video contains.
