Whats the cheapest way to lower the rear of my 95 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwall, Jun 22, 2012.
  1. Jun 22, 2012 at 1:51 PM
    bwall
    bwall [OP] Active Member
    Brantley
    South Carolina
    95 Tacoma 2.7 35" tsl Boggers 6" lift
    4.88s,
    1995 tacoma 4wd 6"lift with 35"tsl boggers. My truck its about a inch higher in the rear than the front and i want it to squat in the back about and inch lower than the front. I have a 3" body lift and a 2 inch coil spacer in the front with a 3 inch leaf block in the back. What are my options with lowering the rear with out spending any money?
  2. Jun 22, 2012 at 1:55 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    You could get a smaller block for the rear for not too much money, but it won't be free. You could try searching craigslist for a set of used blocks, they should be pretty cheap.
  3. Jun 22, 2012 at 1:58 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Take the block out, cut it in half, reinstall. Can't go wrong right?
  4. Jun 22, 2012 at 2:03 PM
    bwall
    Brantley
    South Carolina
    4.88s,
    Exactly what i wanted to hear i thought the same thing about cutting the block but i didnt want it to throw off the truck bed to the cab. Will it mess the flow up from the bed to the cab?
  5. Jun 22, 2012 at 2:06 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    remove a leaf
  6. Jun 22, 2012 at 2:10 PM
    MowTaco
    Kansas
    :confused: I'm talking about the leaf block. If you cut the back half of your body lift down, of course it will mess up the lines between body and cab. Cutting the leaf block will move the leaves closer to the leaf springs (where they're SUPPOSED to be :p ) and lower the rear end. The bed will stay mounted to the frame in exactly the same way as it is now.
  7. Jun 22, 2012 at 2:20 PM
    bwall
    Brantley
    South Carolina
    4.88s,
    ok that makes more sense now. thanks mow,
  8. Jun 22, 2012 at 3:42 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Yes, you can go wrong....
    The problem with cutting a block is that you will no longer have the bolt recess anymore and the block can actually slip out and that wouldnt be good.
    If you cut the block (the bottom portion since the top has an alignment pin) make sure you can drill a new hole the same size as the old one, sometimes they have the hloe drilled far enough to do so..
    However that being said aluminum blocks suck ass, I would NEVER use them for off-roading, I would upgrade to a steel block if I were to use an block at all. Ideally you should just try to lower it a bit by removing a leaf spring as long as it doesnt make the rear suspension too soft, being softer in the rear might actually be a good thing.
    IMO I would try the leaf removal and ditch the stupid blocks alltogether, they put a lot of torque on your leafs and will eventually ruin the arch, blocks are not good, creates a lot more leverage that allows way more axle wrap than stock, and that can ruin U-joints too.
