Whats the deal with cheap Toyota paint?
Discussion in 'Southern California' started by TacomaTyler_2002, Nov 25, 2019.
  1. Jan 1, 2020 at 2:29 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Very true cash is king, I definitely believe that. There are lots of things I’ve gotten great prices on cause I was rolling the green paper.
    Empty_Lord[QUOTED] likes this.
  2. Jan 1, 2020 at 2:32 PM
    NM Lance
    NM Lance Well-Known Member
    I use paste wax twice a year. Constant sun and exposure. There is a lot to be said for using good wax, even on modern paint. No issues with pealing, but the color is getting lighter. Truck is 17 years old.
    Muddycoinwash likes this.
  3. Jan 1, 2020 at 2:40 PM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    Have the same with the hood and roof on my gen 1. Cant see spending the money on a nice paint job just to enhance it with desert pin striping. Leaning more towards raptor lining it for a few hundred bucks, and a lot of labor.
  4. Jan 1, 2020 at 4:52 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Hey since you're thinking of doing this I'll throw in some more details. I'm in the middle of fixing a fender so am up to date on this for now. At first, I disliked duplicolor paint because it seemed really weak an would scrape off with a fingernail. Then I found/read you have to sand with 800 (not finer, too slick for poor adhesion) before putting it down so it sticks mechanically and also that you have to not let it dry for more for 2 hrs between coats or wait >5 days for it to properly cure between coats. That is, if you wait say a day between coats the last one is partially cured and the next one will not properly adhere. You also have to work with the surface tension of duplicolor, for my cans at least it makes 3D drops when sprayed and you have to add enough for all the drops to connect and pull itself into a single smooth liquid layer. I guess this is logical, but had to think about it first time and now just expect it. Now that I'm used to it, I actually really like duplicolor as it is hard when sprayed correctly and allowed to cure for a week- it doesn't pick off with a fingernail at all and when wetsanded up to 2000-3000, gives a mirror-like color finish under that 2K clear coat. I started with rustoleum clear coat from home depot and ended up sanding it off. Not only was it yellow, but was easily scratched off even after curing 2 weeks and dirt tended to stick to it and show, even after wetsanding up to 3000 grit.
    Also I found the blue plastic razor blades that house painters use are perfect to clean up the failed clear coat at the edges. They scrape similarly to the edge of a credit card, but the plastic is harder and they are sharp enough that they actually cut the clear coat layer unlike a credit card that just peels it back more in comparison.
    If you have a full assortment of wet or dry I guess the magic erasers aren't necessary, but they are another piece of the puzzle of tools I am using to try to get things right. I get the extra-strength ones that don't fall apart as fast from home depot. They seem better for cleanup of the edges of the failed clearcoat than using sandpaper.
    Some quick links for what is working for me:
    2k clearcoat
    https://www.amazon.com/gp/product/B0043B7UQY/
    Use a respirator good for organic vapors with this. It emits cyanide.
    3M flexible wetordry backing pad, works perf
    https://www.amazon.com/gp/product/B000PEPCGI/
    blue plastic razor blades to work edges of failed clear coat
    https://www.amazon.com/Plastic-Razor-Blades-Double-Polycarbonate/dp/B00LBDLKYK/
    Wetordry assortment up to 1k grit
    https://www.amazon.com/gp/product/B000CQ49X6/
    Wetordry assortment up to 2500 grit
    https://www.amazon.com/3M-Wetordry-Sandpaper-03006-Assorted/dp/B005JPGTNI/
    Djmjay2[QUOTED] likes this.
  5. Jan 7, 2020 at 4:23 PM
    Spades4Lif3
    Spades4Lif3 Well-Known Member
    San Diego
    2016 Tacoma TRD OR 4x4
    I’ve come across to many used cars that I would’ve bought if it wasn’t for the liner. Not hating, just not my style.
  6. Jan 8, 2020 at 7:51 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Considering giving this a shot on our Lexus.
    Low mile, great running car that the clear is coming off of in sheets on the hood and roof. I did a quickie test spot with non 2K clear and it came out OK.
    Sadly, my X-Runner is getting the telltale haze on the center of the hood and leading edge of the roof. It has always been well cared for but living outside up until last year has taken a toll on it. That one I will probably have a shop handle.
  7. Jan 21, 2020 at 6:12 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I wash, clay bar, wipeout, polish, black light, sealant, butter wet wax, then Ceramic coat. All products from chemical guys. I did that over a year ago and haven’t washed my truck since. I just use waterless car wash again from chemical guys. My truck still has the original paint. So a little bit of work ( or spend $500-$1000 in a paint correction detail) and your truck will shine 18 years after I bought it.
    Twize and Trd420 like this.
  8. Jan 22, 2020 at 2:35 PM
    Trd420
    Trd420 2nd gen 03
    Tony
    Compton california
    Tacoma trd off road
    Icon stage 4 method wheels
    Love there product I have all that and mudders car wash take the dirt right off
    e.deCastro[QUOTED] likes this.
  9. Jan 24, 2020 at 3:25 PM
    HoustonMike
    HoustonMike Well-Known Member
    05 Tacoma TRD OR 4x4; One-owner, 230,000 mi
    On an older truck, overall good condition but peeling paint, is a good full paint job worth the money?
  10. Jan 24, 2020 at 3:32 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    My truck sits out in the sun all year round. It might be a little bit faded, but no clear coat issues whatsoever. Twenty years and 192K miles and still looks good! Just lucky I guess!
    tacoma_ca likes this.
  11. Jan 24, 2020 at 3:35 PM
    tacoma_ca
    Sure if you like your truck. I was looking at new Tacomas and decided I’d be happier with a paint job and some relatively new 3rd gen 4-runner seats. Aside from the miles, that would essentially make it a new truck ;)
    jackn7 likes this.
  12. Jan 24, 2020 at 3:42 PM
    HoustonMike
    I love my truck, 05 TRD Off-road that I have had since new, but the question is if I love it thaaat much. It really only needs the roof done, but after 15 years and typical chips and scratches elsewhere, i wonder about doing the whole thing.
  13. Jan 24, 2020 at 3:44 PM
    gotoman1969
    Imo yes. Figure 5k paint or 35k new truck. Especially if your planning on keeping it.
  14. Jan 24, 2020 at 4:19 PM
    tacoma_ca
    I brought my 04 to the body shop last month for a paint job. They said they would fix it up for $500 and said my paint didn’t need a redo. Cutting compound, touch ups using the correct PPG brand urethane 3-component paint, and a polish and it looks like a new truck to me. I don’t have a clearcoat on white, but they can fix clearcoat peeling areas too. After getting to know the process, I wonder what a decent quote would be just to fix the problem areas.
    You can clean up and re-spray clearcoat yourself too. Check the 2k clearcoat on Amazon for ~$20 per can. That is what my body shop uses for small areas, it is the real thing.
    jackn7 likes this.
  15. Jan 24, 2020 at 4:27 PM
    #35
    tacoma_ca
    My dad sold his perfect 69 GTO for a 72 Pinto Wagon to haul the kids, wish I was joking. Seemed like a good idea at the time. Selling a Taco you like may be similar one day.
  16. Jan 24, 2020 at 4:35 PM
    #36
    HoustonMike
    Ouch. Maybe the minivan for the family is not worth it. o_O
    jackn7 likes this.
