Whats the difference between a class III and IV hitch?
Discussion in 'Towing' started by dougmays, Feb 2, 2009.
  1. Feb 2, 2009 at 7:08 PM
    dougmays
    dougmays [OP] Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    seems like everywhere i look, they group the 3's and 4's together. what is the real difference. And is this what actually gives the truck with towing package the 6500lbs over the 4000lbs limit?
  2. Feb 2, 2009 at 8:07 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Along with that....
    Don't forget - receivers & balls have weight ratings also. ;)
    If/when you buy a receiver & ball - make sure they are properly rated for your setup.
  3. Feb 3, 2009 at 6:36 AM
    dougmays
    Doug
    Gainesville, FL
    thanks for the clarifications. so in theory, since the toytoa tow packages comes with a class IV hitch, the truck could "hold" 10,000 lbs and 1000 tongue weight (assuming the proper ball of course). But the truck isn't made to "tow" that much.
    It could hold the weight, just cant tow that weight?
  4. Feb 3, 2009 at 6:54 AM
    Janster
    Jandy
    Lancaster, PA
    No.....
    When you have a 6500lb towing capacity, it EXCEEDS the max capacity of a Class III hitch - and why Toyota uses Class IV.
    The truck can tow/haul whatever is classified in the owners manual. Surely - you can try to tow/haul more than that, but in the world of paperwork, legalities, and lawsuits....That's all toyota cares about - is what's in the manual.
  5. Feb 3, 2009 at 7:05 AM
    dougmays
    Doug
    Gainesville, FL
    sorry, what i was trying to say was. with my truck sitting in place, not towing or even moving. i could, in theory, put 10,000lbs trailer on. But not try to tow it.
  6. Feb 3, 2009 at 7:11 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Depending on tongue weight, you'll probably bottom out just sitting there... :D
  7. Feb 3, 2009 at 7:32 AM
    Janster
    Jandy
    Lancaster, PA
    Delmarva is right....
    The way you are explaining it (in theory) - has nothing to do with anything but tonque weight.
    A hitch is rated for the hitch only. What you install that hitch on is a totally different animal. Towing/hauling is a lot more than just the hitch. Surely - the engine itself could tow/haul a lot more - but there are other things involved. Things like, frame & vehicle structure, driveline/axles, braking, steering & controllability.
  8. Feb 3, 2009 at 12:40 PM
    dougmays
    Doug
    Gainesville, FL
    haha sorry...i was pretty much thinking outloud with the whole "just sitting there" thing.
    thanks for all the info!
  9. Jul 1, 2009 at 1:07 PM
    Starshadow
    Starshadow New Member
    Mustang, OK
    Red, 08, Prerunner, 4x2
    Running boards, Toneau Cover, Class III Hitch
    I really appreciate your information on the differences between the class III & class IV, but now I have a question. I just had a class III installed last week, but it attached to both the frame and the bumper. Do I have a problem? Is this a faulty install? or the wrong hitch? I was planning to rent a small trailer or pop up & go camping in another week, but now I'm not so sure.
  10. Jul 9, 2009 at 3:45 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The Gen 2 hitch uses some of the same mounts that the rear bumper uses. No problem with the hitch attached to the bumper.
