Whats the heaviest your taco has towed???
Discussion in 'Towing' started by MillerMan06, Apr 3, 2011.
  1. Aug 16, 2012 at 9:58 AM
    #101
    ccm75
    ccm75 New Member
    texas
    tacoma sport v6 TRD
    must pick up trucks have a tow/hawl button, but the tacoma does not, how do you guys pull stuff? I mean with the automatic transmission, In D or in 4?
  2. Aug 16, 2012 at 1:53 PM
    #102
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    On flat terrain I leave it in D. If I know I'm going over hills where it will want to constantly shift I will put it in 4.
  3. Aug 17, 2012 at 9:58 PM
    #103
    AndrewPiering
    AndrewPiering Well-Known Member
    Andrew
    Dallas, Texas
    2011 Tacoma Prerunner SR5
    No, I do not have the tow package. Just a hitch from Uhaul.
  4. Aug 20, 2012 at 8:11 PM
    #104
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    You have a goose neck in the truck?
  5. Aug 21, 2012 at 6:32 AM
    #105
    Phillywill
    Phillywill Member
    Will
    Philadelphia, PA
    11 PreRunner 4X2 V6
    TRD Off-Road Extra Value Package
    Did you do the work yourself? If so, was it difficult to do? I'm not sure if I should attempt this or have it done professionally. Or if I should even have it done at all. I think the heaviest I'll ever tow is around 3000 Lbs.
    Thanks,
    Will
  6. Aug 22, 2012 at 11:42 AM
    #106
    bott8961
    bott8961 New Member
    David
    Suffolk, VA
    08 Prerunner
    Hitch, trailer wiring, oil cooler, transmission cooler, brake controller
    Yes. The Hitch and the Timbrens were easy just follow the instructions. The oil and transmission cooler were a little more complex. Had to modify the half cup that surrounds the oil filter to route the oil lines the most direct route and since I don't like the retainer straps that come with the coolers I fabricated brackets to mount them just behind the grill. Running the lines back and forth to the coolers was a little tricky to keep them off the sharp edges and various sensors. Where needed I made some brackets and other places I used short pieces of slighly larger hose wrapped around the actual lines to protect from sharp edges. Wiring was the only part I consider hard but most anybody could do it with a little study and taking it slow. If I never intended to pull more than 3500 pounds I would not bother with the oil cooler but you still need the hitch, transmission cooler (IMO) and the wiring.
    The transmission cooler adds another problem and that is the amount of transmission fluid you need to add to the system to make up for the little bit lost when you break the system open and the volume of the cooler and line themselves. Toyota's sealed system with no dipstick makes this more difficult. I made my best guess and added 3 cups of fluid at the transmission and so far so good. I still plan on checking the level properly using the procedure I found here. Just as a side note there's a thread on here that talks about checking the transmission level and one of the reoccurring questions if whether or not the 2 wheel drive prerunners have the transmission oil temp light on the dash. My 08 does have the light and it will light when you follow the posted procedure.
  7. Aug 22, 2012 at 12:01 PM
    #107
    bott8961
    bott8961 New Member
    David
    Suffolk, VA
    08 Prerunner
    Sorry not to get back to you for a couple of days. Your right its 23' plus a little. It has a rear slide that only extends while parked. The dry weight is 4300. I need to check the loaded weight but I think I am around 5000 to 5300 fully loaded and headed out. I do have weight distribution and sway control. I have the Equalizer Hitch and it works like a champ, only down side is it is very heavy.
  8. Aug 22, 2012 at 12:19 PM
    #108
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I recall some recommended advice from a boat dealer one time that said you should never pull more than 85% of the rated capacity of the vehicle. If that is true then a V6 with towing package should never pull more than 5,525 lbs safely. Has anyone else heard of this rule before?
  9. Aug 22, 2012 at 4:21 PM
    #109
    tractng
    tractng Well-Known Member
    It just his opinion. The engineers already tested and know better than all of the so call experts. Cars, trucks in Asia has way higher ratings...
    Numbers in the US are understated.
  10. Aug 22, 2012 at 4:26 PM
    #110
    bott8961
    bott8961 New Member
    David
    Suffolk, VA
    08 Prerunner
    Do you have the V6? I have no experience with the I4 but with my experience with the V6 I think it is quite safe and your truck will pull that "A liner" all day with no problem. By going with a pop up most of the body of the trailer will be behind your truck which will cut way down on the drag and the truck can easily handle the weight of the trailer. Like I said in the previous post all you need is the frame mounted hitch, transmission cooler and wiring.
    David
  11. Aug 22, 2012 at 4:29 PM
    #111
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    That is how most people pull gooseneck trailers. Lol
  12. Aug 22, 2012 at 6:41 PM
    #112
    kd8bao
    Henry
    Cleveland
    ROTFLMAO
  13. Aug 31, 2012 at 9:18 AM
    #113
    Curt7088
    Curt7088 ship jumper extraordinaire
    Curtis
    Jacksonville
    '15 Jeep JKU
    rubi sliders, 3.5" lift, HID headlights 35" nitto terra grapplers and the best... spider web shade
    I THINK I PISSED MYSELF A LIL... but seriously i think he meant that it is almost a little wierd to see a taco with a gooseneck,it's usually used for larger trailers with larger trucks!!! that was funny... KUDOS to you...
  14. Sep 5, 2012 at 7:40 PM
    #114
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
  15. Sep 5, 2012 at 8:00 PM
    #115
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Hey, that's a nice color and tire/rim combo. I like :cool:
  16. Sep 6, 2012 at 8:29 AM
    #116
    98cbtacoma
    98cbtacoma Well-Known Member
    Austin
    Boerne, Texas
    98 PreRunner white
    Cobra cb and 3' cb antennas, headache rack, bed rails, blacked out logos. Goodyear wrangler tires. Second gen Tailgate badge. Hella 500 series black magic lights and 500 series lights on top, led brake and turn lights on my headache rack. Custom Bumpers i built myself.
    Ive never seen a yota pull a gooseneck before... Seen a ranger do that but not a taco... Didnt know you could do that haha looks impressive
  17. Sep 6, 2012 at 9:20 PM
    #117
    Stone
    Stone New Member
    Texas
    2012 Tacoma double cab 4x4
    Gooseneck hitch
    I haul frieght,furniture, vehicles pallets of stone etc. With my 2012 tacoma. Today i loaded 6500lbs on my 3300lb gooseneck trailer i designed and built for my taco.
    Thats nearly 10k total weight. No problem. No one mfg a gooseneck hitch for a tacoma so i designed and built one. I believe i can safely pull 12k with this setup, maybe more. I haul cars weighing 4 to 6k for the local toyota dealer when they need a single car picked up or delivered. I also installed rear suspension air bags to handle the heavier loads.
    In the near future i plan to offer a tow package for tacoma owners wishing to get the most out of their truck. I will also offer custom gooseneck trailers as well. I built my trailer specific for my taco. Its a deck over, 18ft with 3 foot dovetail for 21 ft total with ramps. The gooseneck is alittle shorter and lower than standard and the deck is only 30.5 inches in height. Im still trying figure out how to post pics. When i do ill post pics.
  18. Sep 16, 2012 at 7:22 AM
    #118
    yota04
    yota04 Well-Known Member
    Cory
    GA
    04 Tacoma 4x4
    Leveling kit, all the plastic, UWS tool box! Don't plan to lift want it to be able to drive daily and work the woods as well!!
    Towed a roll back up a hill (4 wheel drive of course) very happy she did it!! i should have took a video it would have been epic for all the Tacoma's...and this is a 4cyl.
    good girl :turtleride:
  19. Sep 16, 2012 at 8:08 AM
    #119
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
  20. Sep 17, 2012 at 4:49 AM
    #120
    Blueanimal
    06 Prerunner Sport
    Lol. I think that's what he meant also but I couldn't help myself.
    Here's the pictures I have with a trailer.
    I've only pulled with a load twice, once was 600 miles when we picked up the white trailer with about 3k pounds of extra weight on it. It pulled fine through the hills. The second time was the red trailer and that was about 10 miles with a tractor on it, the brakes grabbed on that trailer so is was a pain. The white trailer is currently being repainted and getting a new deck as everything is still original from 1974 when it was built, then will be the true test as I'm supposed to go pick up a JD 4020 tractor and pull it 600 miles to my dads place.
    ImageUploadedByTapatalk1347882462.464347.jpgImageUploadedByTapatalk1347882508.789982.jpg
    surforegon likes this.
