Whats the point of 35s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kamille.bidan, Aug 7, 2019.
  1. Aug 7, 2019 at 8:10 AM
    Kamille.bidan
    Kamille.bidan [OP] Well-Known Member
    2017 Blue TRD OR MT
    I want to get more into off-roading but I am not sure if I need to get 35s or not
    why do you actually need 35s?
    Last week I drove through miles of washboard through different Reno trails, and I also drove through the miles of trails in the el dorado national forest. Stock suspension and stock tires. I got through everything with some challenges.
    I see the need for better tires because I got stuck going uphill. I see the need for a lift because I banged up my TRD skid pretty badly. I see the need for better suspension because my shocks faded and the ride quality was terrible overall. However, there wasn’t a single instance where I felt I needed 35s.
    I have never tried to crawl rocks, but are 35s absolutely necessary for that exercise?
    GillyLink, monkeyface and Gunshot-6A like this.
  2. Aug 7, 2019 at 8:13 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    If you have to ask you don't need them... People on 35s are doing much more extreme trails than washerboard forest road driving
    EDIT: People USING their 35s are doing much more extreme trails
  3. Aug 7, 2019 at 8:15 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    You can look really cool at the mall!!
    G.
  4. Aug 7, 2019 at 8:18 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    This is truly one of those "if you have to ask" scenarios.
    Sounds like you would be well served with a set of upgraded bilsteins, and a set of good AT tires. Maybe go up a size to 265/75/16 from 265/70/16
  5. Aug 7, 2019 at 8:20 AM
    awdj
    awdj Well-Known Member
    20' Tacoma TRD PRO
    Corrected.
  6. Aug 7, 2019 at 8:20 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Ground clearance.
  7. Aug 7, 2019 at 8:21 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Not true. Don't use this man's advice
  8. Aug 7, 2019 at 8:26 AM
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    For the most part I've had 33" tires and just recently upgraded to 35". My friends rigs with 35"+ tires always performed better in snow and rock crawling.
  9. Aug 7, 2019 at 8:26 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    You said you banged up your skid pretty bad. Going bigger tires gives you ground clearance. Getting a lift does nothing for your ground clearance of the axles and drive train.
    A good upgrade for what you're looking into is some shocks with resivoirs to prevent shock fade, some beefier skids (BAMF 1/4" steel), sliders, and 33's. Challenge yourself on 33's and if you find you need more, you can move to 35's eventually. But that takes a lot of cutting, banging and trimming of the cab mount, pinch weld and wheel wells.
    Make sense?
  10. Aug 7, 2019 at 8:28 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Exactly. My wife likes me just a little bit less. :pout:
  11. Aug 7, 2019 at 8:31 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Those are the chicks that like dudes with skinny jeans and man buns.
    Hot chicks like 44's. :anonymous::crapstorm:
  12. Aug 7, 2019 at 8:32 AM
    LameOtter
    LameOtter Well-Known Member
    Bill
    18' Tacoma SR5
    Get a Jeep TJ or CJ...31's, no lift, no problem including some rock crawling and tighter places than any tacoma will do...:anonymous:
    TomTwo, Junkhead, MtnFisher and 4 others like this.
  13. Aug 7, 2019 at 8:32 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    "I see the need for a lift because I banged up my TRD skid pretty badly"
    that statement alone says YOU don't need 35s...
  14. Aug 7, 2019 at 8:38 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
  15. Aug 7, 2019 at 8:39 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    The obvious answer is ground clearance.
    You are right that 35s are overkill for the stuff you listed - washboards, dirt trails, small rock gardens, etc. If you stick to that, stock size tires should be plenty good.
    But not all dirt trails are flat and easy. The video below is an example of what you could possibly run into while exploring new trails. It's not "crawling up a rock", but still a tough obstacle for your stock tires to handle.
    https://www.youtube.com/watch?v=9GpAzDyr8o4
    Agreed. If you have to ask ...
    EDIT: didnt realize it was a bait thread lol ... carry on
  16. Aug 7, 2019 at 8:41 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    this post has gotten zero likes, also what's that on the front of this truck, does that provide some kinda protection? From what, bugs? hmmm
  17. Aug 7, 2019 at 8:41 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Having 35's on a Tacoma is for more Intagram followers. :)
    I feel the sweet spot for the Tacoma is 34" tires. 285/75/17. I can go do all the trails with a Tacoma with 35" tires with less rubbing and strain on the axles as well.
  18. Aug 7, 2019 at 8:42 AM
    Not Active
    Not Active Member
    Wisconsin
    2008 AC 4X4 6spd V6
    You can only truly raise pumpkin clearance with taller tires.
    MattCowsmasher and monkeyface like this.
  19. Aug 7, 2019 at 8:42 AM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  20. Aug 7, 2019 at 8:44 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Do I need the winch? Asking means you’re wondering if you get stuck. Been stuck too many times without one, do I need one, yes.
    Do I need 35’s, getting stuck because you’re framing out?
    MattCowsmasher likes this.
