Whats this UCA business
Discussion in 'Suspension' started by frusteri4, Dec 1, 2014.
  1. Dec 1, 2014 at 8:42 PM
    frusteri4
    frusteri4 [OP] Well-Known Member
    Reno
    off road ACLB
    Pelfrey Front, CVT tiny, OME heavy,
    Just picked up a 2015 access cab, and am looking to do a 3" coilover lift in the front and eventually run 285/75 r16s. Preferably without trimming anything on my new truck (can it even be done?)
    I am aware the info is on here, I just can't seem to come up with the right choice of words in the search function.
    So would one of you mind pointing me to the right link to explain when and why I would need new UCAs and what specifically about them is needed to solve this "UCA problem" ( and what problem is it in the first place ).
    Also pros, cons, when's, why's, and contraindications for running wheels with various amounts of backspace.
    Again I know I'm being lazy about finding the info, I just know there's got to be the be all end all thread for this setup since I see it is fairly common
    Thanks in advance.:)
  2. Dec 1, 2014 at 8:46 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Right around 2.5" of lift is where you loose the ability to get the correct caster adjustment with factory ucas. Caster is the alignment of the suspension so as to angle it in a manner to make the tires trail in the direction you are driving. Think of a wheel caster on a shopping cart. Your handling is sacrificed when you can't get the correct caster adjustment.
  3. Dec 1, 2014 at 8:52 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I want to preface this by saying I am running a 3" lift on 285's.
    There's many links, but a lot of people run stock UCAs on 3" of lift with out issues. Others run into problems with the tire rubbing on the UCA.
    What I have read over and over is that if you put a lift kit on 2.5" or more, it is highly recommended you get new UCAs. You will not have rubbing of the tires on the UCAs and your alignment will be in spec. My thoughts are if you're spending the money, better get everything you need at once and have it installed all at once; buy once, cry once.
    You will have to trim a little running 285's just for on road driving alone. If you take it off road there is a whole lot more trimming and modifications needed. Such as a cab mount chop, beating/flattening the pinch weld, and trimming more plastic. For on road, I trimmed so little that I could hold all the pieces in one hand; not much at all. I have yet to test and flex off road but I can surely tell you, I am not done trimming.
  4. Dec 1, 2014 at 9:25 PM
    frusteri4
    Reno
    off road ACLB
    what specifically am I looking for when buying upper control arms? different length, bend, etc? I definitely will be doing off roading, not high speed race truck business, but lots of back road exploring.
  5. Dec 1, 2014 at 9:27 PM
    moondeath
    Pa, Gardners
    Just an adjustable uca. It will state that it's adjustable. Be sure to get a good brand. They are pricey unfortunately.
  6. Dec 1, 2014 at 9:40 PM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    Lifting the truck in that manner with stock UCAs results in low caster. This causes the truck to be twitchy and have a floaty feeling. Larger diameter tires and added rotational mass exaggerates this. UCAs move the top of the steering knuckle closer to the rear of the vehicle which adds caster.
  7. Dec 1, 2014 at 10:03 PM
    frusteri4
    Reno
    off road ACLB
    Thanks a lot, that answers a lot of questions. With 3" of lift up front, does anybody run into any other issues with their steering components, CV boots, drivelines, etc. And what could be done to fix these problems?
  8. Dec 1, 2014 at 10:04 PM
    geekhouse23
    For driveline vibes, OME/ARB FK29 kit.
  9. Dec 1, 2014 at 10:16 PM
    frusteri4
    Reno
    off road ACLB
    on tacomahq's ultimate tacoma lift guide it said: All front-end lift kits over 1.5″ should also include a differential drop kit". What is the story with that?
  10. Dec 1, 2014 at 10:16 PM
    wobble
    Ridgefield, WA
    2014 TRD OR
    Premature wear due to increased angles. I had to replace steering rack, lower ball joints, and tie rods. I did the CV boot mod and had no problems with boots. No issues with axles. Had driveline vibes, but not enough to concern me. Ran lift for about 50k.
  11. Dec 2, 2014 at 4:28 AM
    geekhouse23
    Diff drop on and 05+ is useless. It rotates the diff in a way where the internals no longer are getting the proper lubrication those causing damage in the diff. Does more harm than good.
