What's under the black plastic strips???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DaveEli, Jun 15, 2012.
  1. Jun 15, 2012 at 6:28 PM
    DaveEli
    DaveEli [OP] Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Hey, what is under the black plastic strips on the roof of a 2011 Tacoma Access cab? Do they come off? Are there factory threaded inserts on the access cabs? I was looking at a Baja Rack. Dave
  2. Jun 15, 2012 at 7:10 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Access cabs have sheet metal and a couple clips to hold the black rubber trim on, no nuts for a roof rack. yes they come off, there is no reason to remove them.
  3. Jun 15, 2012 at 7:45 PM
    Tcomaboy
    Tcomaboy Well-Known Member
    Texas
    2010 DCLB TRD Sport Prerunner
    it's the placeholders for the roof rack.... I added the OEM roof racks onto my tacoma and had to peel those rubber strips off
  4. Jun 15, 2012 at 7:57 PM
    Ryanv
    15 4Runner
    Correct you have a double cab he is asking about an access cab totally different body.
  5. Jun 15, 2012 at 8:30 PM
    DaveEli
    David
    Virginia Beach
    Thanks, I guess I am out of luck. Dave
  6. Jun 16, 2012 at 3:53 AM
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    so many it turned into a GMC
    I can simply take off the black rubber strips that are on the roof of my 2012 DC and add a roof rack to existing holes?
    F'ing sweet
    I love this site
  7. Jun 16, 2012 at 4:34 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    There has been a couple of guys here who have done a mod on the access cab to fit the factory racks, so there may be some answers here as to what can be done.
