What's with our USB ports!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silence9, Aug 7, 2015.
  1. Aug 7, 2015 at 3:17 PM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    Hi there everyone. I've had no problems or complaints with my Tacoma, well, one. What's with the USB ports!? It's never worked quite right, right from the factory. After some Googling it turns out several camry tundra highlander and Tacoma owners have problems with their USB. It used to choose when it felt like charging or syncing a phone, had to plug and unplug several times or turn truck off and on. Also used to charge my e cig, to now being completely dead as a doornail. Pissed me off cause my cig died at work today and the damn truck couldn't, charge it. Nothing charges, not my phone, e cigarette, nothing. I'm an electrician by trade, and an thinking of installing a dual USB port next to the USB aux one off its own 3 amp fuse so it can healthily handle charging whatever I throw at it. Who was the genius who thought .5A was enough power? Not to mention it's our only port so most people will be using a tap (adapter) to get two ports. Most devices take an amp or more @ 5 volts.
    In the meantime, what's with these? Does anyone know what fuse is in charge of the USB? Possibly that's popped? Thanks in advance.
  2. Aug 7, 2015 at 3:25 PM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
  3. Aug 7, 2015 at 3:27 PM
    Silence9
    Alberta, Canada
    Thanks buddy. I just think it looks awful using a 12v to USB adapter, its a 2013 and should have the technology to handle things. I don't really want a big bulky adapter hanging out ready to get torn out by my passenger's leg. If those dual USB ones fitted to size are legit I'll wire up one or two.
  4. Aug 7, 2015 at 3:30 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    I believe the USB is for media only. USB - Universal Serial Bus, it is convenient to have power available via USB, but USB is a data exchange first, not a power source.
  5. Aug 7, 2015 at 3:32 PM
    Silence9
    Alberta, Canada
    Strangest thing is, most of us have TRDs with 130amp alternators, more than enough to handle charging a piddly phone under full load, hell even the 100 amp non TRD. Unacceptable IMO.
    Arcticelf likes this.
  6. Aug 7, 2015 at 3:35 PM
    Silence9
    Alberta, Canada
    Pretty much any USB port you see, whether it's on a receiver to a sound system, on a printer, on a laptop, they all act as buses for 5v power. 4 pins on any usb. Data +, data -, 5V +, 5V -. They just limited it for some stupid reason.
    Does anyone know what fuse it is? Or is it pigtailed off other things like the radio?
  7. Aug 7, 2015 at 3:39 PM
    Toyko Joe
    I seem to remember when I installed my heated seats [and thus tearing apart the entire truck interior to put OEM variable resistors in the blank spots near the USB] that the USB was wired to the Radio.
    Silence9[QUOTED][OP] likes this.
  8. Aug 7, 2015 at 3:42 PM
    Silence9
    Alberta, Canada
    Makes sense, so it can communicate with the head unit. Just find it odd it's limited. Thing is, it doesn't even try on some devices. I know if you plug an iPhone for example into a laptop, it limits the current to .5amps. It will still charge, every single time, just twice as slow as 120v to USB adapter @ 1amp. Goofy IMO.
  9. Aug 7, 2015 at 3:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe smashing the USB port is in order
  10. Aug 7, 2015 at 3:44 PM
    Silence9
    Alberta, Canada
    Nah, it can stay there and take up space. I'll install some real ones. The USB port isn't nearly as stupid and greedy as Apple corporation, so no smashy.
  11. Aug 7, 2015 at 3:44 PM
    Toyko Joe
    With a hammer or a ham sandwich?
  12. Aug 7, 2015 at 5:07 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I got tired of the head unit starting to play the library on my iphone every time I plugged my phone into the USB port so I added my own dual USB outlet for charging in one of the blank spots next to it: http://www.ebay.com/itm/201326140614
  13. Aug 7, 2015 at 5:18 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Just use the plug in 12 volt for charging. Not an issue unless you are hauling around a bunch of drunks.
  14. Aug 7, 2015 at 5:25 PM
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    Hadn't seen the ebay item above before, thought the irreplaceable fuse is a drawback.
    I chopped up a couple chargers, stuffed them under the dash for hardwired chargers. Kind of a pain, but I couldn't find a high quality unit to hard wire all my chargers from. I used a bunch of connectors so when one breaks I can buy another 12vdc car charger, chop it up and connect it to the existing cables. I am running two amp fuses in each of the hardwired units, pigtailed off a 5amp fused add a tap.
    https://www.tacomaworld.com/threads/poindexters-2015-build.385616/
  15. Aug 7, 2015 at 5:31 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    They
    Fit perfect next to the factory USB and atrac button locations.
  16. Aug 7, 2015 at 5:46 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    What does that shown connector plug into?
  17. Aug 7, 2015 at 5:49 PM
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    Search Amazon: "Aukey 4.8A / 24W Dual USB Car Charger Adapter for Apple and Android Devices". They sit flush with the face of the lighter socket. They work fine. (I haven't been bothered to test their 2.4A claim, but I kinda doubt it.)
  18. Aug 7, 2015 at 5:50 PM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    I have a usb adaptor that goes into my 12v port
    It is really low profile and only sticks out of the port maybe a 1/2 inch?
    Though it doesn't solve your usb issue it might be a livable work around
  19. Aug 7, 2015 at 5:52 PM
    mdcmn7
    Chuck
    East Coast
  20. Aug 7, 2015 at 6:26 PM
    wsurunner
    Hadn't noticed that. I guess that if/when the fuse goes I'll either buy a replacement unit for $20 or take out the defective unit and return to the blanking plate.
    It's just the pigtail connector. Bare wires at the end for wiring to your truck; the pigtail connector allows you to disconnect the whole thing during installation/removal.
