Whats with the beeping???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kris77, Jun 3, 2008.
  1. Jun 3, 2008 at 8:40 AM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I dont remember reading about this anywhere, but in 4 low, it constantly beeps. Is there a way to turn that off? It got real annoying when i was pulling out an old stump yesterday.
    What is the purpose of this anyway? You have to push in on the selector to even get to 4 low. Maybe 5 or 10 beeps to let you know your in 4 low, but to keep beeping and beeping....thats crazy!!!!!
    Ok...I feel better...Ive been waiting all day to get that off my chest...:D
    Oh, just a little fact about my taco. After i pulled the stump out, i had to fill the hole it was in and the connecting ditch with gravel. On my 08 DC short bed, I had exactly 1.65 ton of gravel in the bed. Could barely tell it was on there. I was SHOCKED. I was expecting the truck to be all over the road, but it handled VERY nicely. Never bottomed out either. I was expecting to have to have the rear leaf TSB done on this truck, but i had no problem at all with my springs. I guess they did fix the problem on the newer 08's.
  2. Jun 3, 2008 at 8:53 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    1.65 ton?? ARE you sure it wasn't something else
    And no sag, you must have the super taco because when I put 850lbs in the back of my 08 before the TSB it was on the stops. Not to say it didn't ride ok but that is over 3,000lbs that your saying so no way.....and if your springs weren't bad before they probably are now.
  3. Jun 3, 2008 at 8:56 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    nah, I think that he actually has an F-450.
  4. Jun 3, 2008 at 8:57 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    1.65 ton?? then i guess the beeping was because your tacoma is gonna explode from the load....hehe
    but seriously what ive read about that beeping is that the 4lo is not engaged thats why it beeps.....
  5. Jun 3, 2008 at 8:57 AM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    well it does say 3500 lb capacity on the bed so maybe hes got the god of alltacomas
    i plan to buy some concrete
    any ideas how many i can put in the truck?
  6. Jun 3, 2008 at 9:03 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    18 80# bags, distributed evenly over the bed.
  7. Jun 3, 2008 at 9:26 AM
    kris77
    West Virginia
    I never said "NO sag"...I was talking about driving wise. I thought it would be sitting straight up in the air and it wasnt nearly as bad as i thought it was. I figured i would be all over the road, and i wasnt. It wasnt bad at all. I was impressed.
    I had the bed level to about 1 inch below the rails on the sides and a graveyard hump in the middle.
    You guys had me second guessing myself so i went and got out the reciept from the gravel yard. I guess im dyslexic today...
    Actual load....1.56 ton 3109 lbs.
    You guys dont believe me, i have to get another load this week sometime....Might not be as much as the first, but i guarantee it'll be over 2500lbs. I'll take some pics and post.
    Then let the appologies begin...
    EDIT:
    The beeping is because the 4 low wasnt engaged? It pulled the stump out just fine. Maybe it was stuck in 4 hi and i didnt realize it? I probably should have been able to realize i wasnt in low range...I really need to start paying more attention to things...
  8. Jun 3, 2008 at 9:28 AM
    eordonez
    Ed
    Chihuahua, Mexico
    do that man! i want to see it.... its not that i don't believe you, im just impressed....:eek:
  9. Jun 3, 2008 at 9:31 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you sure you were in 4lo?
    You can tell when you're in 4lo or not - the gearing is different and the truck doesn't move nearly as fast in 4lo as 4hi.
    If you keep getting that beeping sound - stop the vehicle, put it in neutral or park and sit for a few seconds until the beeping stops and the truck engages into 4lo.
    That's my guess....
    How many total leaf springs do you have-including the overload spring?
  10. Jun 3, 2008 at 9:42 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    the beeping means you are not in 4lo. if it beeped the whole time that means you were in 4hi the whole time.
    as far as 1.65 tons of gravel in the bed.... i dont believe that. you can TOW that much in a trailer but you cant HAUL that much in your bed. thats double of what the beds are rated for. even if you were driving the full size you would at least notice that much weight
  11. Jun 3, 2008 at 9:47 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    No it doesn't. The load capacity of the BED is 1300lbs or so. The bumper tow capacity is 3500lbs. As in, put a ball on the bumper instead of the hitch under the bumper.
    And as others mentioned, beeping in 4lo means it's not engaged.
    This is a half ton truck, not 1.5 ton or 3/4 ton or 2 ton.
  12. Jun 3, 2008 at 11:09 AM
    kris77
    West Virginia
    I had the switch in 4 lo...But like i said...I wasnt really doing all that much i just wanted to see what all you had to do to go from hi to lo. I've only had the truck a week...still trying to get used to everything...
    I didnt pay much attention to the gearing i wasnt driving very far...I just noticed that beeping and it drove me crazy. I'll check it again tonight when i get home. I'll check out the leaf springs as well.
    It may be a HALF ton truck, but this HALF ton truck will haul a ton and a HALF....I dont understand why everybody is in disbelief...Do you all not use your trucks as trucks? Has nobody ever tested the limits of their trucks? Is it so hard to believe that this truck will haul more than Toyota recommends?
    Wasnt there a picture on here a few months ago showing a taco pulling another taco on a trailer...how much does a truck weigh? 4000lbs? Plus what...another 300 - 500lbs for a trailer??? That is way over the 3500lb towing max and nobody questioned that.
    Not trying to be a dick or anything, just wondering why everybody is giving me a hard time....
  13. Jun 3, 2008 at 12:46 PM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Hey man I believe you....you probably just took some major years out of the rear wheel bearings, tranny, rearend, motor, springs etc. I would not do it again..but its your truck. Those pics will go along way, but don't wreck your truck. :D
  14. Jun 3, 2008 at 12:50 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Tacoma can pull 6,500lbs with the factory tow package. I would not do any more than that.
    Remember, that 6,500 includes your trailer, its contents, your gear, and your passengers.
  15. Jun 3, 2008 at 12:50 PM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
  16. Jun 3, 2008 at 1:24 PM
    Marioso
    Marioso Risueno
    San diego Ca
    thats like half my fam haha howd u get the pic? jk
  17. Jun 3, 2008 at 1:45 PM
    nd
    Nate
    Greenville, SC
    If you put the truck in 4lo and it beeps, that means 4lo is not engaged. you have to follow the procedure in the owners manual to get it in 4lo
    as for the weight, are you saying the weight was in the bed or being pulled in a trailer of some kind? if you are TOWING it behind the truck in a trailer, you can tow up to 6500 lbs and what you are saying woudl be completely believable. if you HAUL inside the bed, the weight the back end can handle is around 1300lbs, and thats pushing it. There is absolutely no way a tacoma had 1.5 tons inside the bed and handled fine. i doubt you could even fit that much gravel into one of these beds without it overflowing
  18. Jun 3, 2008 at 2:13 PM
    Wolfpack
    Wolfpack Well-Known Member
    Las Vegas
    08 Prerunner
    I just came out of an F-150 and there is no way I'd try and put 3500 pounds in that much less a Tacoma. I wouldn't try 1000 pounds in the '08 Tacoma I just bought. I'd like to see a pic of the receipt for the gravel. :)
    ETA....my trucks are all work trucks, they haul, tow and have to carry my work tools everyday. I don't baby them beyond the first month.
  19. Jun 3, 2008 at 2:30 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    You're wrong. 3600 tons of gravel will end up being about 1.3 cubic yards. A fully loaded bed can hold 1.6 cubic yards. In your face!
    I want to see the pancakes you call bump stops.
  20. Jun 3, 2008 at 2:33 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Because I've hauled 1600lbs of wood pellets once a month for the entire winter last year. I have a 3" lift so I have stronger springs in the back and it STILL was 1" off the bumps with HALF of what you're claiming to have hauled in the bed. There's no fucking way I would willing put over 3,000lbs in a bed rated for 1300. Fuck, even the tundra only hauls 2,000lbs in it's bed.
    And nobody questioned towing 3500lbs because the truck is rated for 5,000lbs stock, and 6,500lbs with the factory tow package. RTFM. :rolleyes: The 3,500lbs limit is if you put a ball on the bumper and hook a trailer to that.
    Not only that, but there's a BIG difference between a shit load in the bed and weight on a trailer. Trailer wieght is supported by the trailer's wheels, axles and brakes, balanced right, and just putting a fraction of the weight on the truck. I hope you don't think the 3,500lbs bumper tow capacity = bed capacity! :laugh: That 3500 trailer hooked to the bumper should apply less than 500lbs of actual weight pushing down on the back of the truck.
